Ebyte, EoRa-S3-900TB (ESP32S3 + SX1262 Dev Board)
Ebyte EoRa-S3-900TB (EoRa Pi) — An Affordable ESP32-S3 + LoRa Dev Board
The EoRa-S3-900TB is a compact all-in-one development board from Ebyte combining an ESP32-S3 microcontroller with a SX1262-based LoRa radio (868/915 MHz). Priced around $18–20 USD, it packs a lot into a small 27×64mm footprint.
Key Hardware:
· MCU: ESP32-S3FH4R2 — dual-core LX7 @ 240 MHz, 4MB Flash, 2MB PSRAM, Wi-Fi, BLE 5.0
· LoRa: Ebyte E22-900MM22S (SX1262), 22 dBm, ~7 km range @ 915 MHz
· Onboard: 0.96" OLED, SD card slot, Li-ion charging circuit, USB Type-C
· Power: Two onboard LDOs — worth noting for low-power designs
Arduino / Software: Works with Arduino IDE via the ESP32-S3 board support package. RadioLib is the recommended library for the SX1262. Ebyte provides boards.h and utilities.h support files to place alongside your sketch.
One important hardware quirk: DIO1 is tied to GPIO33, which is not an RTC-capable wakeup pin. A workaround using a 74HC04N hex inverter routing to an RTC-capable GPIO is needed for WOR deep sleep operation. Note: a wire from DIO1 to GPIO_NUM_16 can be used.
Real-World Power Measurements (WOR, 915 MHz): Running Wake-on-Radio at a 1.4% active / 98.6% sleep duty cycle, measured with a Nordic PPK2:
· Deep sleep trough between listening spikes: 25.38 µA (close to Ebyte's spec of ~25 µA)
· Listening spike peak: ~8 mA
· Duty-cycle average: 179 µA
Nordic Power Profiler Kit II Observations
Regards,
William
Thanks for sharing!
Another set of NPPK II Observations from "EoRa-S3-900TB-with-FreeRTOS" project
Observation 1 of radio.sleep() between switch on and switch off.
Observation 2 of normal EXT0, deep sleep
William
Why the EoRa-S3-900TB?
Choosing the right hardware for a battery-powered, always-listening receiver isn't
just about picking a board with LoRa on it. The wrong board kills your battery in
days. The right one survives for months — or longer. Here's why the Ebyte
EoRa-S3-900TB earned its place in this project.
Everything in One Package
The EoRa-S3-900TB packs an ESP32-S3FH4R2 (dual-core LX7 @ 240 MHz, 4 MB Flash,
2 MB PSRAM, Wi-Fi, BLE 5.0) and an Ebyte E22-900MM22S LoRa module (SX1262, 22 dBm,
~7 km range) onto a single 27 × 64 mm board, along with a 0.96-inch OLED, SD card
slot, Type-C interface, and — critically — a built-in lithium battery charging
circuit. No separate modules to wire up. No charge IC to source. One board, one
LiPo connector, done.
A Power Architecture Built for Battery Life
This is the detail most Ebyte reviews skip over. The EoRa-S3-900TB uses two
separate LDO regulators
— LDOA and LDOB — feeding the ESP32 and the LoRa
peripherals on isolated 3.3 V rails:
Rail Regulator Powers Max Continuous Peak Pulse
LDOA HT7533 ESP32-S3 250 mA → 3.3 V 340 mA
LDOB ME6214 E22 LoRa + OLED + peripherals 150 mA → 3.3 V 100 mA
Why does this matter? The ESP32's Wi-Fi and Bluetooth transceiver draws sudden
300+ mA spikes. On a single-LDO board, those transients collapse the supply rail
just long enough to corrupt a LoRa packet in flight, or worse, trigger a false
wakeup. The split-rail design keeps the SX1262 on clean, isolated power — exactly
what you need when a false wakeup means the camera switches on at 3 AM with nobody
watching.
The OEM Spec vs. What You Actually Achieve
Ebyte's datasheet quotes a deep sleep floor of ~25 µA — measured with USB
disconnected, OLED off, LoRa radio in full sleep, no peripherals active, running
on battery alone. That's the theoretical minimum: just the ESP32 RTC domain alive,
waiting for an external wakeup event.
Real-world with Wake-on-Radio running, deep sleep is ~174 µA. That is not a
separate mode — it is deep sleep for this project. The SX1262 autoDutyCycle
wakes for 9.2 ms every duty cycle interval to sniff for a preamble, then the
system returns to the ESP32 RTC baseline. Those two states time-average to 174 µA:
  • 9.2 ms active sniff @ ~11 mA — SX1262 listening
  • Remainder of duty cycle @ ~25.38 µA — ESP32 RTC baseline
The 25.38 µA baseline, measured on the Nordic PPK2, validates the OEM ~25 µA spec
exactly. It is the floor beneath the duty cycle, not a separate operating mode.
Mode Current
OEM deep sleep floor spec (no USB, peripherals off, battery) ~25 µA
Deep sleep + WOR duty cycle — measured (Nordic PPK2) ~174 µA
Active sniff spike (9.2 ms, SX1262) ~11 mA
radio.sleep() — total system, 120 s viewing window (Nordic PPK2) 18.39 µA avg / 19.55 µA max
High activity — TX / processing 37–50 mA
That 174 µA — achieved on a development board with an OLED, SD slot, and
battery charger on the PCB — is the headline. Bare modules can go lower. This
board, with everything integrated, holds it to 174 µA. That's the number that
makes 13–19 months of field deployment on a 3000 mAh LiPo realistic.
One Complete Cycle — Power States in Sequence
Once a wake packet arrives and the camera switches on, the power profile shifts
entirely:
  1. Preamble detected — EXT0 fires on GPIO_NUM_16, ESP32 wakes from deep sleep
  2. Receive + ACK — ESP32 and SX1262 active, 37–50 mA
  3. Camera ON — KY-002S latching switch pulsed, power bank energised
  4. radio.sleep() called — total system current drops to a flat ~18.39 µA average (19.55 µA max, measured Nordic PPK2 ampere mode, in series with battery); SX1262 datasheet sleep spec is 600 nA–1.2 µA, so the ~18.39 µA is almost entirely the ESP32 RTC domain; ESP32 sets 120 s timer and holds in deep sleep for the full viewing window
  5. Timer fires — ESP32 wakes, pulses switch to power camera OFF
  6. WOR resumes — SX1262 returns to autoDutyCycle, system back to ~174 µA average
radio.sleep() only appears in step 4 — the quiet interval between camera ON and
camera OFF. It plays no part in the idle WOR listening phase.
The One Hardware Gotcha
The SX1262's DIO1 interrupt line — the pin that fires when a preamble is detected
— is wired to GPIO33 on the EoRa-S3-900TB. GPIO33 is not RTC-capable on the
ESP32-S3, so it cannot serve as an EXT0 deep sleep wakeup source.
The fix: a single jumper wire from the DIO1 pad to GPIO_NUM_16, which is
RTC-capable. No extra ICs, no inverter buffer circuit. One wire, and the SX1262
can wake the ESP32 directly from deep sleep the moment a valid preamble arrives.
Why Not a Bare Module?
A bare ESP32-S3 + separate SX1262 module would get you to a lower idle floor, but
you'd be designing your own LDO split, your own charge circuit, your own PCB
layout. The EoRa-S3-900TB ships with all of that already solved, at ~$18–20 USD,
in a form factor that fits in a weatherproof enclosure with room to spare. For a
field-deployed, battery-powered receiver with no mains power at the site, that
tradeoff is an easy one.
