i need to know where the data of sensor saved because i need signal from sensor andmove servo motors
i use this sheild
http://store.fut-electronics.com/111MED0002.html
http://store.fut-electronics.com/111MED0003.html
/* Demo program for: */
/* Board: SHIELD-EKG/EMG + Olimexino328 */
/* Manufacture: OLIMEX */
/* COPYRIGHT (C) 2012 */
/* Designed by: Penko Todorov Bozhkov */
/* Module Name: Sketch */
/* File Name: ShieldEkgEmgDemo.ino */
/* Revision: Rev.A */
/* -> Added is suppport for all Arduino boards. */
/* This code could be recompiled for all of them! */
/* Date: 19.12.2012 */
/* Built with Arduino C/C++ Compiler, version: 1.0.3 */
Purpose of this programme is to give you an easy way to
connect Olimexino328 to ElectricGuru(TM), see:
https://www.olimex.com/Products/EEG/OpenEEG/EEG-SMT/resources/ElecGuru40.zip
where you'll be able to observe yours own EKG or EMG signal.
It is based on:
* ModularEEG firmware for one-way transmission, v0.5.4-p2
* Copyright (c) 2002-2003, Joerg Hansmann, Jim Peters, Andreas Robinson
* License: GNU General Public License (GPL) v2
For proper communication packet format given below have to be supported:
////////// Packet Format Version 2 ////////////
// 17-byte packets are transmitted from Olimexino328 at 256Hz,
// using 1 start bit, 8 data bits, 1 stop bit, no parity, 57600 bits per second.
// Minimial transmission speed is 256Hz * sizeof(Olimexino328_packet) * 10 = 43520 bps.
struct Olimexino328_packet
uint8_t sync0; // = 0xa5
uint8_t sync1; // = 0x5a
uint8_t version; // = 2 (packet version)
uint8_t count; // packet counter. Increases by 1 each packet.
uint16_t data[6]; // 10-bit sample (= 0 - 1023) in big endian (Motorola) format.
uint8_t switches; // State of PD5 to PD2, in bits 3 to 0.
#include <compat/deprecated.h>
#include <FlexiTimer2.h>
//http://www.arduino.cc/playground/Main/FlexiTimer2
// All definitions
#define NUMCHANNELS 6
#define HEADERLEN 4
#define PACKETLEN (NUMCHANNELS * 2 + HEADERLEN + 1)
#define SAMPFREQ 256 // ADC sampling rate 256
#define TIMER2VAL (1024/(SAMPFREQ)) // Set 256Hz sampling frequency
#define LED1 13
#define CAL_SIG 9
// Global constants and variables
volatile unsigned char TXBuf[PACKETLEN]; //The transmission packet
volatile unsigned char TXIndex; //Next byte to write in the transmission packet.
volatile unsigned char CurrentCh; //Current channel being sampled.
volatile unsigned char counter = 0; //Additional divider used to generate CAL_SIG
volatile unsigned int ADC_Value = 0; //ADC current value
// Functions
/* Function name: Toggle_LED1 */
/* Parameters */
/* Input : No */
/* Output : No */
/* Action: Switches-over LED1. */
void Toggle_LED1(void){
if((digitalRead(LED1))==HIGH){ digitalWrite(LED1,LOW); }
else{ digitalWrite(LED1,HIGH); }
/* Function name: toggle_GAL_SIG */
/* Parameters */
/* Input : No */
/* Output : No */
/* Action: Switches-over GAL_SIG. */
void toggle_GAL_SIG(void){
if(digitalRead(CAL_SIG) == HIGH){ digitalWrite(CAL_SIG, LOW); }
else{ digitalWrite(CAL_SIG, HIGH); }
/* Function name: setup */
/* Parameters */
/* Input : No */
/* Output : No */
/* Action: Initializes all peripherals */
noInterrupts(); // Disable all interrupts before initialization
// LED1
pinMode(LED1, OUTPUT); //Setup LED1 direction
digitalWrite(LED1,LOW); //Setup LED1 state
pinMode(CAL_SIG, OUTPUT);
//Write packet header and footer
TXBuf[0] = 0xa5; //Sync 0
TXBuf[1] = 0x5a; //Sync 1
TXBuf[2] = 2; //Protocol version
TXBuf[3] = 0; //Packet counter
TXBuf[4] = 0x02; //CH1 High Byte
TXBuf[5] = 0x00; //CH1 Low Byte
TXBuf[6] = 0x02; //CH2 High Byte
TXBuf[7] = 0x00; //CH2 Low Byte
TXBuf[8] = 0x02; //CH3 High Byte
TXBuf[9] = 0x00; //CH3 Low Byte
TXBuf[10] = 0x02; //CH4 High Byte
TXBuf[11] = 0x00; //CH4 Low Byte
TXBuf[12] = 0x02; //CH5 High Byte
TXBuf[13] = 0x00; //CH5 Low Byte
TXBuf[14] = 0x02; //CH6 High Byte
TXBuf[15] = 0x00; //CH6 Low Byte
TXBuf[2 * NUMCHANNELS + HEADERLEN] = 0x01; // Switches state
// Timer2
// Timer2 is used to setup the analag channels sampling frequency and packet update.
// Whenever interrupt occures, the current read packet is sent to the PC
// In addition the CAL_SIG is generated as well, so Timer1 is not required in this case!
FlexiTimer2::set(TIMER2VAL, Timer2_Overflow_ISR);
FlexiTimer2::start();
// Serial Port
Serial.begin(57600);
//Set speed to 57600 bps
// MCU sleep mode = idle.
//outb(MCUCR,(inp(MCUCR) | (1<<SE)) & (~(1<<SM0) | ~(1<<SM1) | ~(1<<SM2)));
interrupts(); // Enable all interrupts after initialization has been completed
/* Function name: Timer2_Overflow_ISR */
/* Parameters */
/* Input : No */
/* Output : No */
/* Action: Determines ADC sampling frequency. */
void Timer2_Overflow_ISR()
// Toggle LED1 with ADC sampling frequency /2
Toggle_LED1();
//Read the 6 ADC inputs and store current values in Packet
for(CurrentCh=0;CurrentCh<6;CurrentCh++){
ADC_Value = analogRead(CurrentCh);
TXBuf[((2*CurrentCh) + HEADERLEN)] = ((unsigned char)((ADC_Value & 0xFF00) >> 8)); // Write High Byte
TXBuf[((2*CurrentCh) + HEADERLEN + 1)] = ((unsigned char)(ADC_Value & 0x00FF)); // Write Low Byte
// Send Packet
for(TXIndex=0;TXIndex<17;TXIndex++){
Serial.write(TXBuf[TXIndex]);
// Increment the packet counter
TXBuf[3]++;
// Generate the CAL_SIGnal
counter++; // increment the devider counter
if(counter == 12){ // 250/12/2 = 10.4Hz ->Toggle frequency
counter = 0;
toggle_GAL_SIG(); // Generate CAL signal with frequ ~10Hz
/* Function name: loop */
/* Parameters */
/* Input : No */
/* Output : No */
/* Action: Puts MCU into sleep mode. */
__asm__ __volatile__ ("sleep");
