So I got some code working and getting the expected ASCII code!!!!! My code needs some cleaning up due to it being a combination of several different examples and my inputs. So I need some help deciphering and converting the output. Hopefully I can get some response or should I start a new thread?
This would be my typical/expected response, but seems when I send the command my response starts anywhere in the string (ex if you look at the serial output below)
$8C82;01C5;0200000000;0300D2;040000;050000;060000;070000;088000;09FFF7;0A02EB;0B8000;0C02CA;0D8000;0E8000;0F8000;10016B;1113;1212;2E8000;7A
Where $8C82 is 0x00 answer 1 BYTE; 01C5 is 0x01 Status 1 1 Byte; 0200000000 is 0x03 Error status 4 long-word;
0300D2 is command 0x03 O2 in percent, 2 word; 03 first byte is the index of the data remaining is the actual data
040000 is command 0x04 CO in ppm, 2 word; 04 first byte is the index of the data remaining is the actual data
What is the best way to pull out the actual data values and convert it to decimal? Also what is the best way to do a check sum?
/*Protocol
The baud rate is not fixed and will be adjusted via a corresponding external program,
otherwise 8 bit, no parity, 1 start/stop bit. Data will be send and received in ASCII.
The maximum size of a record is 256 characters. The first character of a record is "$" (0x24),
the last one is carriage return CR (0x0D). In between these two characters is the actual information.
The first byte (2+3rd character, described with "GG") in HEX indicates the number of all
transmitted characters. The second byte (4+5th character) in HEX is the command. Any possible
following (use-)characters (described with "HH..XX") can contain different information.
The number of (use-)characters is equal to the number of the received/send characters minus 8.
The last byte in HEX is a checksum value, which will be calculated by simply adding theprevious
characters.A break of more than 4 seconds during data receiving resets the data receive.
Within the answer the commands are added with 0x80.
Command 1 (0x01) : Write EEProm of USB Interface (only for USB-interface)
Send : $1201HHHHIIJJKK,CHKS,CR
Answer: $1281HHHHIIJJKK,CHKS,CR
HHHH : Serial number
II : RF-channel
JJ : Setup 0x80 = Remote 0=No 1=yes 0x40 = Fahrenheit 0=°C 1=°F 0x20 = Data structure 0=DAS 1=new commands
KK : Baud rate 0x00 = 300 0x01 = 600 0x02 = 1200 0x03 = 2400 0x04 = 4800 0x05 = 9600 0x06 = 19200 0x07 = 38400 0x08 = 57600 0x09 =115200
Example send : $12013039054002E2,CR
Example answer : $12813039054002EA,CR
Serial number : 0x3039 = 12345
RF-channel: 0x05 = 5
Setup : 0x40 = Fahrenheit
Baud rate : 0x02 = 1200 Baud
Command 2 (0x02) : Read all values Send : $0802EE,CR Answer: $GG82;HHHH;...;,CHKS,CR
The following values are transmitted : (see point 3.) 0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15,16,17,18
Bits 0x0100 and 0x0200 in "Status USB interface" were cleared after sending the values.
#include <CP210x.h>
#include <usbhub.h>
#include "pgmstrings.h"
#include <SPI.h>
class CP210xAsync : public CP210xAsyncOper
public:
uint8_t OnInit(CP210x *pftdi);
uint8_t CP210xAsync::OnInit(CP210x *cp210x)
uint8_t rcode = 0;
rcode = cp210x->IFCEnable();
if (rcode)
return rcode;
rcode = cp210x->SetBaudRate(9600); //changed from 115200
if (rcode)
return rcode;
rcode = cp210x->SetDataBits(8);
if (rcode)
return rcode;
rcode = cp210x->SetStopBits(CP210X_STOP_BITS_1);
if (rcode)
return rcode;
rcode = cp210x->SetParity(CP210X_PARITY_NONE);
if (rcode)
return rcode;
rcode = cp210x->SetFlowControl(CP210X_FLOW_CONTROL_OFF);
if (rcode)
return rcode;
return rcode;
USB Usb;
//USBHub Hub(&Usb);
CP210xAsync cp210xAsync;
CP210x cp210x(&Usb, &cp210xAsync);
Serial.begin( 9600 );//115200
#if !defined(MIPSEL)
while (!Serial); // Wait for serial port to connect - used on Leonardo, Teensy and other boards with built-in USB CDC serial connection
#endif
Serial.println("Start");
if (Usb.Init() == -1)
Serial.println("OSC did not start.");
delay( 200 );
Usb.Task();
if ( Usb.getUsbTaskState() == USB_STATE_RUNNING )
//send to analyzer
uint8_t rcode;
char strbuf[] = "$0802EE\r"; //command 2 (0x02) read all sensors
rcode = cp210x.SndData(strlen(strbuf), (uint8_t*)strbuf); //send to analyzer
Serial.print("Sent: "); Serial.print(rcode);
if (rcode)
ErrorMessage<uint8_t>(PSTR("SndData"), rcode);
delay(100);
//read from analyzer
uint8_t buf[64];
uint16_t rcvd = 64;
rcode = cp210x.RcvData(&rcvd, buf);
if (rcode && rcode != hrNAK)
ErrorMessage<uint8_t>(PSTR("Ret"), rcode);
if ( rcvd ) { //more than zero bytes received
Serial.print(" RCVD: ");
for (uint16_t i = 0; i < rcvd; i++ ) {
// Serial.print("RCVD: "); Serial.println((char)buf[i]);
Serial.print((char)buf[i]);
delay(100);
Serial.println("");
Serial Output
configuredevice: 0
CP210x Init
init 1: 0
Addr:01
NC:01
Conf.Val: 01
Iface Num: 00
Alt.Set: 00
Conf.Val: 01
Iface Num: 00
Alt.Set: 00
NumEP:03
Conf:01
CP210x configured
configuredevice 2: 0
attempt config: 0
config rcode 1:0
Sent: 0 RCVD: C02CA;0D8000;0E8000;0F8000;10016B;1113;1212;2E8000;7A
$8C82;01CC
Sent: 0 RCVD: $8C82;01C5;0200000000;0300D2;040000;050000;060000;070000;088000;
Sent: 0 RCVD: 09FFF7;0A02EB;0B8000;0C02CA;0D8000;0E8000;0F8000;10016B;1113;121
Sent: 0 RCVD: 2;2E8000;7A
Sent: 0 RCVD: 0000;088000;09FFF7;0A02EB;0B8000;0C02CA;0D8000;0E8000;0F8000;100
Sent: 0 RCVD: 16B;1113;1212;2E8000;7A
Sent: 0 RCVD: 00;060000;070000;088000;09FFF7;0A02EB;0B8000;0C02CA;0D8000;0E800
Sent: 0 RCVD: 0;0F8000;10016B;1113;1212;2E8000;7A
Sent: 0 RCVD: ;040000;050000;060000;070000;088000;09FFF7;0A02EB;0B8000;0C02CA;
Data Structure (from attached PDF in first post)
3) Data structure
Data will be received or send in HEX. The different values are separated by semicolon.
The first byte of one value is the index of the data, the following bytes are the data in different length.
For example see command 5.
Index Description Bytes
0 0x00 Answer J2K 1 , Byte
1 0x01 Status 1 analyzer 1 , Byte , see description
2 0x02 Errorstatus 4 , Long-Word , see description
3 0x03 O2 in x.x% 2 , Word (0x8000=nc)
4 0x04 CO in ppm 2 , Word (0x8000=nc)
5 0x05 NO in ppm (X.X low NOx) 2 , Word (0x8000=nc)
6 0x06 NO2 in ppm (X.X low NOx) 2 , Word (0x8000=nc)
7 0x07 SO2 in ppm 2 , Word (0x8000=nc)
8 0x08 Mica (CxHy) in ppm 2 , Word (0x8000=nc)
9 0x09 draft x.xx (or Pa) 2 , Integer
10 0x0A Temp. air X.X °C/°F 2 , Integer (0x8000=nc)
11 0x0B Temp. gas X.X °C/°F 2 , Integer (0x8000=nc)
12 0x0C Temp. sensor X.X °C/°F 2 , Integer (0x8000=nc)
