Hi everyone !
I have a Power analyzer module
that can analyze the power statistics such as
• Real Power
• Apparent Power
• Reactive Power
• Fundamental & Harmonic Power
• Power Factor
• Volt rms
• Amp rms
• Watt-hr
It uses UART Communication so that I can connect it directly to a PC and read its values to my VB Program below:
Public Class frmEMII
Dim serialdelay As Integer
Private Sub tmrRx_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles tmrRx.Tick
Dim rxstring As String
Dim RX() As String
Dim temp() As String
'Timer2.Enabled = False
If SerialPort1.BytesToRead > 1 Then
serialdelay = serialdelay + 1
If serialdelay > 3 Then
rxstring = SerialPort1.ReadExisting
rxstring = rxstring.Replace(Chr(13), Chr(13) + Chr(10))
serialdelay = 0
RX = rxstring.Split(",")
'OK must be the first in splitted string
If RX(0) <> Chr(2) + "OK" Then
lblAlarm.BackColor = Color.Red
Exit Sub
End If
lblAlarm.BackColor = Color.Black
lblVer.Text = RX(1)
temp = RX(2).Split(".")
lblVRMS.Text = temp(0)
lblVrms1.Text = temp(1)
temp = RX(3).Split(".")
lblIrms.Text = temp(0)
lblIrms1.Text = temp(1)
temp = RX(4).Split(".")
lblRP.Text = temp(0)
lblRP1.Text = temp(1)
temp = RX(8).Split(".")
lblPF.Text = temp(0)
lblPF1.Text = temp(1)
lblS.Text = RX(5)
lblQ.Text = RX(6)
lblF.Text = RX(11)
lblH.Text = RX(10)
lblFQ.Text = RX(12)
lblWHr.Text = RX(13)
lblIT.Text = Sec2Time(Val(RX(14)))
lblTemp.Text = RX(9)
End If
Else
serialdelay = 0
End If
End Sub
Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
SerialPort1.Open()
End Sub
Private Sub InitMeterToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles InitMeterToolStripMenuItem.Click
SerialPort1.Write(Chr(2) + "M2" + Chr(3))
End Sub
Private Function Sec2Time(ByVal Time As Integer)
Dim sec, min, hr As Integer
Dim s, m, h As String
hr = Int(Time / 3600)
min = Int((Time - Int(hr * 3600)) / 60)
sec = Time - Int(hr * 3600) - Int(min * 60)
s = sec.ToString
m = min.ToString
h = hr.ToString
If s.Length < 2 Then s = "0" + s
If m.Length < 2 Then m = "0" + m
If h.Length < 2 Then h = "0" + h
Return (h + ":" + m + ":" + s)
End Function
Private Sub btnClear_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnClear.Click
SerialPort1.Write(Chr(2) + "R" + Chr(3))
End Sub
Private Sub ExitToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ExitToolStripMenuItem.Click
SerialPort1.Close()
End
End Sub
Private Sub OFFSETCalToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles OFFSETCalToolStripMenuItem.Click
If MsgBox("Calibrate Offset. Are you sure?", MsgBoxStyle.YesNo) = MsgBoxResult.No Then Exit Sub
If MsgBox("Remove ACV jumper and press OK..", MsgBoxStyle.OkCancel) = MsgBoxResult.Cancel Then Exit Sub
tmrRx.Enabled = False
SerialPort1.ReadExisting() 'clear buffer
SerialPort1.Write(Chr(2) + "O" + Chr(3))
Do
Application.DoEvents()
Loop Until SerialPort1.BytesToRead > 1
MsgBox(SerialPort1.ReadExisting, MsgBoxStyle.OkOnly)
tmrRx.Enabled = True
End Sub
Private Sub MenuStrip1_ItemClicked(ByVal sender As System.Object, ByVal e As System.Windows.Forms.ToolStripItemClickedEventArgs) Handles MenuStrip1.ItemClicked
End Sub
Private Sub lblVRMS_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles lblVRMS.Click
End Sub
Private Sub lblRP_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles lblRP.Click
End Sub
End Class
By Default, the Module outputs the data in ASCII CSV Format Stream, like this;
Example CSV output stream:
[STX]OK,1000,231 .49,0.21 6,34.56,49.65, -37.1 1 , -22.93,0.6961 ,40.07,0.03,34.53, -37.1 1 ,1 .475,987[ETX]
This is the equvalent values for:
[STX]STAT,VERSION,VRMS,IRMS,PREAL,VA,QAVERAGE,QINSTANT,PF,TEMPERATURE,PHARMONIC,PFUNDAMENTAL,PQFUNDAMENTAL,WATTHR,INT[ETX]
The VB Program Works. However, I want to connect the Power Analyzer Module to my Arduino UNO RX/TX Ports, but I do not know how to do the following though I am still a newbie to arduino:
Program the arduino to read the values coming from the power module up to the Arduino RX/TX Ports
Convert these ASCII CSV values into INT values so that I can store them to different arduino program variables.
I attached below the VB Program I am using, and the Manual for the Power Analyzer Module is given also in the above link
Thanks Guys !
