Outside of background color specification in the preference.txt file, is there any way to control the text color coding in the editor? Thanks
You mean the general text colour or the code colouring thing?
For instance the comment text is gray, keywords are orange, booleans are blue, other text black. Mainly I'd like to use a different color than gray for the comments and than orange for the keywords. I'm not trying to be picky, it's just that when I print out a sketch it is not easily readable even if I set the printer for "best". Thanks for any help you can give.
look in your arduino folder for a file called theme.txt
Hi Osgeld,
Thank you, thank you, thank you. You really helped, it is so cool now. The text is very readable even when I print at fast draft!!!
Thanks again
your most welcome
