EEPROM Default Values?
Arduino Uno R3.
Hi.
I bought two of these recently. What is the default setup for the eeprom in these boards, as sold by yourselves?
We're trying to figure out how to detect an 'unused' eeprom in order to load the relevant values into a program, either from sketch defaults or the eeprom, depending if the eeprom already has something usable in it or not.
DanB
openenergymonitor.org
I think you may have misunderstood something.
A factory-fresh AVR's EEPROM will have 0xFF in every location.
This is not an installation and troubleshooting question.
(deleted)
It would probably be faster to find the answer if you has written a small test sketch to read the eeprom cells and find the answer yourself :wink:
Anyway
I have used this example in the past to calculate the crc. Advantage is that it can also pick up eeprom corruption.
I used the last 4 locations of the eeprom to store the calculated CRC; the for-loop needs to end at EEPROM.length() -4.
Below a simple demo to demonstrate
#include <EEPROM.h>
  Serial.begin(57600);
  Serial.print("EEPROM length: ");
  Serial.println(EEPROM.length());
  // calculate CRC over eeprom (eeprom.length - 4 bytes)
  unsigned long calculatedCrc = eeprom_crc();
  Serial.print("calculated CRC32 of EEPROM data: 0x");
  Serial.println(calculatedCrc, HEX);
  // get stored crc
  unsigned long storedCrc;
  EEPROM.get(EEPROM.length() - 4, storedCrc);
  Serial.print("stored CRC32 of EEPROM data: 0x");
  Serial.println(storedCrc, HEX);
  // check for eeprom 'corruption'
  if (storedCrc != calculatedCrc)
    // save something
    float pi = 3.14;
    EEPROM.put(0, pi);
    Serial.println("Initial values stored in EEPROM");
    //calculate CRC over eeprom
    // save calculated CRC to eeprom
    EEPROM.put(EEPROM.length() - 4, calculatedCrc);
    Serial.println("CRC saved to EEPROM");
    Serial.println("EEPROM OK");
  Serial.print("\n\nDone!");
unsigned long eeprom_crc(void)
  const unsigned long crc_table[16] =
    0x00000000, 0x1db71064, 0x3b6e20c8, 0x26d930ac,
    0x76dc4190, 0x6b6b51f4, 0x4db26158, 0x5005713c,
    0xedb88320, 0xf00f9344, 0xd6d6a3e8, 0xcb61b38c,
    0x9b64c2b0, 0x86d3d2d4, 0xa00ae278, 0xbdbdf21c
  unsigned long crc = ~0L;
  for (int index = 0 ; index < EEPROM.length() - 4  ; ++index)
    crc = crc_table[(crc ^ EEPROM[index]) & 0x0f] ^ (crc >> 4);
    crc = crc_table[(crc ^ (EEPROM[index] >> 4)) & 0x0f] ^ (crc >> 4);
    crc = ~crc;
  return crc;
The first time that you run it, it will update the eeprom because the calculated CRC and the stored CRC don't match. The second time that you run it, the CRCs should match and you will see the message that the eeprom is OK.
Arduino Uno does not use EEPROM by default. You may use whole EEPROM without fear to rewrite any "important" data.
I thought the Arduino Uno started putting a serial number in the first few bytes of EEPROM?
Did they stop doing that?
In any case, if you have an application that you want to have check whether it has already put stuff in EEPROM, the thing to do is to put some "magic numbers" in there, and perhaps a "proprietary" checksum of your significant data fields.
struct my_eeprom_data EEMEM {
   uint32_t magicNumber;
   uint16_t checksum;
   uint8_t eedatat[100];
void initializeEEPROM() {
   if (eeprom_read_dword(&my_eeprom_data.magicnumber == 0xDEADBEEF) {
      if (eeprom_read_word(&my_eeprom_data.checksum) == do_checksum(&my_eeprom_data.checksum, 100))
         // EEPROM is already initialized and looks good.
        return;
   // EEPROM is not initialized, or bad.  Initialize it.
   for (int i=0; i<100;i++)
      eeprom_write_byte(&my_eeprom_data.data[i], 0);
   eeprom_write_word(&my_eeprom_data.checksum, do_checksum(&my_eeprom_data.checksum, 100));
   eeprom_write_dword(&my_eeprom_data.magicnumber, 0xDEADBEEF);
   // NOW eeprom is initialized!
AWOL:
That is also what you get when they die.
Paul
