EEPROM in RTC DS3231 problem
Hi there,
I use eeprom in RTC DS3231,
I need to save number of button press,
every HIGH state on button need to increment counter and save number on eeprom,
I need counter value max 9999,
in my case after 255 counter start from 0 again,
can somebody help with advice?
thanks
my code
#include <DS3231.h>
DS3231  rtc(SDA, SCL);
#include "Wire.h"
#define EEPROM_I2C_ADDRESS 0x57
const int buttonPin1 = 7;    // pin7 button in
int buttonState1 = 0;        // start value for button
int Val = 0;                 // counter for the number of button presses
int readVal = 0;             // read value from address 0
int sum = 0;                 // sum readVal + new
int freshVal = 0;            // print last sum
   Wire.begin();
   Serial.begin(19200);
   rtc.begin();
   //The following lines can be uncommented to set the date and time
   //rtc.setTime(16, 31, 0);               // Set the time to 15:36:00 (24hr format)
   //rtc.setDate(06, 06, 2020);            // Set the date to 19 Noemvri 2019
   pinMode(buttonPin1, INPUT);
   readVal = readEEPROM(0, EEPROM_I2C_ADDRESS);  //if you need to reset value on addres 0 comment this line
   //writeEEPROM(0, 0, EEPROM_I2C_ADDRESS);      //uncomment this line to write 0 on addres 0
   buttonState1 = digitalRead(buttonPin1);
   delay(100);
    if (buttonState1 == HIGH) {                            // if button is High
    dothis();
    delay(50);
void dothis() {
  Val++;
  sum = readVal + Val;
  writeEEPROM(0, sum, EEPROM_I2C_ADDRESS);
  freshVal = readEEPROM(0, EEPROM_I2C_ADDRESS);
  delay(100);
  Serial.println(freshVal);     //print freshVal
void writeEEPROM(int address, byte sum, int i2c_address){
  // Begin transmission to I2C EEPROM
  Wire.beginTransmission(i2c_address);
  // Send memory address as two 8-bit bytes
  Wire.write((int)(address >> 8));   // MSB
  Wire.write((int)(address & 0xFF)); // LSB
  // Send data to be stored
  Wire.write(suma);
  // End the transmission
  Wire.endTransmission();
  // Add 5ms delay for EEPROM
  delay(5);
byte readEEPROM(int address, int i2c_address){
  // Define byte for received data
  byte rcvData = 0x00;
  // Request one byte of data at current memory address
  Wire.requestFrom(i2c_address, 1);
  // Read the data and assign to variable
  rcvData =  Wire.read();
  // Return the data as function output
  return rcvData;
You are saving and retrieving 8 bit byte values which are limited to 255. Each eeprom register can only hold one byte.
You need to be reading and writing the two bytes of an integer value to two registers. Take a look at the highByte() and lowByte() functions to break the integer into two bytes for storage.
You can recombine them when read with either bit shifting or multipication.
myRecombinedInteger = (highByteValue*256) + lowByteValue;
