I have written a code to store number of steps taken by a motor when in set mode & save the value to EEPROM . And when in drive mode , the motor should run clock wise and ccw to the same number of steps by recalling the value stored . The code works fine with arduino and uno . But , on ESP32 . The stored value is returning 0
When using the EEPROM functions on the ESP32 you need a couple of extra commands.
The ESP32 does not have an EEPROM. The EEPROM library emulates the standard functionality... but data is actually stored in flash memory.
You need to use...
#define EEPROM_SIZE 5 // Define how many bytes you want to use.
Then in setup()...
EEPROM.begin(EEPROM_SIZE);
Then after any updates...
EEPROM.commit();
This is my code i have done all the three thing .
#include <Stepper.h>
#include<EEPROM.h>
const int stepsPerRevolution = 200; // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution,27,26);
float stepCount = 0 ;
// the setup function runs once when you press reset or power the board
//int swi = 4;
int rotationCW = 0;
int rotationCCW = 0;
int location = 1;
//int button1 = 13;
float val;
//const int En = 25;
// initialize digital pin LED_BUILTIN as an output.
EEPROM.begin(4);
//pinMode(swi,INPUT);
// pinMode(button1,INPUT);
pinMode(2, OUTPUT);
//pinMode(En,OUTPUT);
//digitalWrite(swi,LOW);
//digitalWrite(button1,LOW);
// the loop function runs over and over again forever
EEPROM.get(2,val);
if (touchRead(T4)<=25)
stepCount=0;
digitalWrite(2, HIGH); // turn the LED on (HIGH is the voltage level)
while (touchRead(T4)<=25)
// step one step:
//digitalWrite(En,HIGH);
myStepper.step(200);
myStepper.setSpeed(1000);
Serial.print("steps:");
Serial.println(stepCount);
stepCount=stepCount+1;
//digitalWrite(En,LOW);
digitalWrite(2,LOW);
EEPROM.write(2,stepCount);
EEPROM.commit();
if(touchRead(T0)<=25 && location ==1)
while(touchRead(T0)<=25)
Serial.println(val);
myStepper.step((180*val));
location=2;
// digitalWrite(En,LOW);
else if(touchRead(T0)<=25 && location ==2)
myStepper.step(-(180*val));
location=1;
EEPROM.write() stores a single byte... did you mean EEPROM.put() ?
