Electric Power Steering Sensor Data
Hello. I have a question about how to read data from torque sensor on a steering column of a car. This is steering system from Renault Twingo C06. I do not know what sensor is in there. It may be SX-4428 or something similar. There are 6 wires comming out of the box. In manual says it is:
ELECTRIC POWER STEERING TORQUE SENSOR FEED 1
ELECTRIC POWER STEERING TORQUE SENSOR FEED 2
ELECTRIC POWER STEERING TORQUE SENSOR SIGNAL 1
ELECTRIC POWER STEERING TORQUE SENSOR SIGNAL 2
ELECTRIC POWER STEERING TORQUE SENSOR EARTH 1
ELECTRIC POWER STEERING TORQUE SENSOR EARTH 2
There are 2 other topics with some more information and pictures:
In first one there is suggestion to build some circut with resistors and caps, but there is no answer, if it actually helps
Feed and Earth wires are connected together, so there are actually 4 wires. I tried applying voltage to feed and earth (5V and 12V), and then read from Signal wire. There is voltage, but it does not change when i turn or apply torque on steering column. I also tried applyting PWM (5V) to Feed, but there are no changes in voltage on signal wire (I used my Scope to see if there is something). I really do not know what to try next. Can somebody help me with some suggestions?
Some more resources:
Thank you all in advance!
