Elegoo Robot Car v4 modifying code
We finally got the Elegoo Robot Car v4 to work with some of the easy code examples supplied by Martin Hebel (thanks so much Martin!). The original code was to navigate to an object and turn but my son just wants to make the car stop. We tried modifying the code but the car stops and then jerks a bit - presumably getting back into the loop. What do we need to change? Thanks for your help with this very basic query!
/*Drive_until_object
    Uses Driving with Function
    Martin Hebel, March 2023
    Drives the car forward until the ultrasonic sensor detects an object, then stops
    Be sure to add the library for the sensor:
    Sketch--> Include Library --> Add Zip Library --> HC-SR04.zip
    Place on floor, press mode switch.
// Configure ultrasonic sensor
#include "SR04.h"
#define TRIG_PIN 13
#define ECHO_PIN 12
SR04 sr04 = SR04(ECHO_PIN,TRIG_PIN);    // create an instance of the ultrasonic class
// define Motor IO pin
#define PWMA  5    // Controls power to right motor
#define PWMB  6    // Controls power to left motor
#define AIN   7    // Controls direction of right motor, HIGH = FORWARD, LOW = REVERSE
#define BIN   8    // Controls direction of right motor, HIGH = FORWARD, LOW = REVERSE
#define STBY  3    // Place H-Bridge in standby if LOW, Run if HIGH
#define modeSwitch 2 // Mode Switch input
// Define variables
int speedLeft = 0;  // holds the speed of left wheels
int speedRight = 0; // holds the speed of right wheels
long distance;      // Holds distance from sensor
//init the car
  pinMode(PWMA, OUTPUT);     //set IO pin mode OUTPUT
  pinMode(PWMB, OUTPUT);
  pinMode(BIN, OUTPUT);
  pinMode(AIN, OUTPUT);
  pinMode(STBY, OUTPUT);
  analogWrite(PWMA, 0);       // Fully off for Right
  analogWrite(PWMB, 0);       // Fully off for Left
  digitalWrite(STBY, HIGH);   //Enable Motors to run
  waitForStart();             // wait until mode is pressed
  setSpeeds(100, 100);        // sets moderate speed
//main loop to drive forward until an object is detected
  forward();                  // drive forward
  distance=sr04.Distance();   // Get and store the distance from the device driver
  if (distance < 40) {        // if too close, stop, reverse and turn
    stop();     delay(500);
void waitForStart(){
    while (digitalRead(modeSwitch) == 1)  // wait for mode switch to be pressed (go to 0)
    ;  // Do nothing
  delay(2000);    // delay 2 seconds before starting
void setSpeeds(int leftSpeed, int rightSpeed){    // stores speeds in variables to be used when driving
  speedLeft = leftSpeed;
  speedRight = rightSpeed;
What if you get rid of that?
Please correct your post and add code tags around your code.
There is a small pencil image below your existing posts.
  • click on this pencil ➜ that will let you edit your post.
  • Select the part of the text that corresponds to the code
  • Click on the <code/> icon in the toolbar to indicate that it is code
  • click image Save Edit
(Also make sure to properly indent the code in the IDE before copying and pasting it here. This can be done by pressing ctrlT on a PC or cmdT on a Mac)
Hello, do yourself a favour and please read How to get the best out of this forum and post accordingly
Edited. Thanks for the pointers.
I can’t see where it does this
In your setup() function, you can see how to "stop motors and prepare to run"... you can put that into a stop() function, but make STBY, LOW to disable motors.
