ELMduino - Couldn't get into ELM327 using Arduino Uno and HC05
Hey I connected Arduino Uno with HC05 Bluetooth module with pins (HC05 - RX, TX, VCC, GND to Uno - 10, 11, 5v, GND) and I've successfully connected ELM327 bluetooth obd2 tool to arduino. I have this code to read engine rpm but it is not getting connected to the obd2 scanner. please help me out with this. I'm doing this on a Skoda Octavia mk2 (Laura).
elm327-obd2-v21-bluetooth-interface-auto-car-diagnostic-scanner-1-400x400
Code:
#include "ELMduino.h"
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
ELM327 myELM327;
uint32_t rpm = 0;
#if LED_BUILTIN
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, LOW);
#endif
mySerial.begin(115200);
Serial.println("Attempting to connect to ELM327...");
if (!myELM327.begin(mySerial, true, 2000))
Serial.println("Couldn't connect to OBD scanner");
while (1);
Serial.println("Connected to ELM327");
float tempRPM = myELM327.rpm();
if (myELM327.nb_rx_state == ELM_SUCCESS)
rpm = (uint32_t)tempRPM;
Serial.print("RPM: ");
Serial.println(rpm);
else if (myELM327.nb_rx_state != ELM_GETTING_MSG)
myELM327.printError();
O/P:
Does it work from PC when you use e.g. GitHub - cedricp/ddt4all: OBD tool ?
It looks like You've connected Rx to Rx and Tx to Tx. That's wrong.
Yeah I switched the connection RX - TX and TX - RX as well... I get the same result. I used the baudrate 38400
@Power_Broker
Okey. More digging needed.
Please post schematics. Pen and paper works fine. Remeber the pin designations.
As said above: check if your ODB module is working at all.
@crest6
Your other topic on the same subject deleted.
Please do not duplicate your questions as doing so wastes the time and effort of the volunteers trying to help you as they are then answering the same thing in different places.
Please create one topic only for your question and choose the forum category carefully. If you have multiple questions about the same project then please ask your questions in the one topic as the answers to one question provide useful context for the others, and also you won’t have to keep explaining your project repeatedly.
Repeated duplicate posting could result in a temporary or permanent ban from the forum.
Could you take a few moments to Learn How To Use The Forum
Thank you.
Will check it and let u know
I switched to esp32 with wifi and bluetooth module and still I couldn't connect into the elm327
You added more difficolties to the pot.
Why no responce to reply #7?
Sorry about that
this the connection I used for arduino and hc05. Later seeing other forums most of them used esp32 with builtin bluetooth so I decided to switch to it but still no progress but feel free to help me out on this as well
Does the HC05 LED indicate that it has paired?
Can your smartphone pair with the ELM?
(Trying to determine if the ELM is M or S.)
I saw this forum topic. didn't read it all.
The HC05 has to be config'd as M evidently.
Yea i made it as master by using AT mode and yes it is paired with the elm327 but im getting couldn't connect with elm327
I paired the hc05 with elm using AT command mode
... and you definitly checked if ddt4all worked?
Yes I tried to connect elm327 with DDT4 application but sadly I don't have access to the database files which needs to be purchased
But I did connect it using mobile application and it was working fine
Well guys now I'm able to connect the esp32 with the ELM327 and I'm able to get the rpm data in the serial monitor using this code:
#include <BluetoothSerial.h>
BluetoothSerial SerialBT;
uint8_t address[6] = {0x00, 0x00, 0x00, 0x33, 0x33, 0x33}; // ELM327 MAC address
void setup(){
  SerialBT.begin("ArduHUD", true);
  SerialBT.setPin("1234");
  SerialBT.connect(address);
float rpm =0;
void loop(){
  ELM327 myELM327;
  #define ELM_PORT SerialBT
  if(myELM327.begin(ELM_PORT, true)){
  myELM327.rpm();
  Serial.print("rpm: ");
but the thing is I want to see the list of DTCs present in the car... I know 01 01(Service 1 01 ) gives the Monitor dtcs status response but I want to request the ECU for Service 3 which shows the stored DTCs:
I want to see what are the trouble code present in my car... as I mentioned earlier I'm doing this in Skoda laura 2011 model (India) which communicates with ISO 15765-4 CAN (11 bit ID, 500 kbit/s).
