Emergency soap bubble machine project
I need urgent help in my arduino project. We are supposed to make a soap bubble machine with the arduino uno and I’m completely lost and I have no idea what to do . Please if someone could help me , I would really appreciate it as my project is due in about 2 weeks and I really need help bc I don’t know what to do . Here is what it’s supposed to look like
What will happen if your homework is not submitted on time ?
Welcome to the forum
Why did you post your topic in the Covid response category of the forum ?
Your topic has been moved to a more relevant forum category
The very first step is to use the list of parts to find or order the parts!!!!! Without them you will never even begin the project. Then get whatever power is needed for the project.
Finally, why is an Arduino part of the project?
How to Get the Right Help from this forum Faster:
You can spend weeks spinning your wheels, or you might get lucky and solve your problem quickly. To avoid unnecessary delays, it’s crucial to provide an annotated schematic of your circuit as you have it wired, showing all connections, including power, ground, and supplies. This can be a preliminary one and we will help you through it.
Why Detailed Information Matters:
  • Annotated Schematics: These are essential because they show exactly how your circuit is set up. Without them, it's difficult for anyone to understand what you’ve done, which makes troubleshooting nearly impossible. Fritzing diagrams or unclear pictures are not enough.
  • Technical Information: Many modules look similar and may even have the same name, but they can function differently. This is why we always ask for links to detailed technical information—not just sales pages like those on Amazon, which often lack the specifics we need.
  • Show All Connections: It’s important to include every connection, especially power and ground, in your schematic. Missing these details makes it hard to determine if a setup issue might be causing your problem.
My Process:
When I see a question, I spend a moment assessing it. If it’s missing critical information, I might ask for it. However, if it's repeatedly lacking important details, I may assume the questioner is not serious and move on to another query.
What You Need to Consider:
We don’t know your skill level or what resources you have available. We realize you are new at this and will need more help. If you’re missing key technical details or seem unprepared, it may indicate that you need to spend more time learning the basics before starting your project. Get the Arduino Cookbook from your library and skim it but pause on parts that pertain to your project.
Providing the right information upfront will help you get the best possible assistance and avoid the frustration of running into dead ends. Let us help you by sharing what you have clearly and completely!
