i work arduino library <> #include <OneWireSlave.h>
I want to do -programs how to make substitute for DS18b20
Which sened to teltonika Degrees;
mycode not work ![]()
#include "Arduino.h"
#include "LowLevel.h"
#include "OneWireSlave.h"
// Defines to access to Low and High bytes
#define Lo(x)Â ((x) & 0xFF)
#define Hi(x)Â (((x)>>8) & 0xFF)
// This is the pin that will be used for one-wire data (depending on your arduino model, you are limited to a few choices, because some pins don't have complete interrupt support)
// On Arduino Uno, you can use pin 2 or pin 3
Pin oneWireData(2);
// This is the ROM the arduino will respond to, make sure it doesn't conflict with another device, 0x28 - DS18B20 identificator
const byte owROM[] = {0x28, 0xF2, 0x27, 0xD6, 0x04, 0x00, 0x00, 0x3D};
// 0 - Low Byte Temperature
// 1 - High Byte Temperature
// 2-7 - reserved
// 8 - CRC8
byte SCRATCHPAD[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0x00, 0x10, 0x00};
// This function will be called each time the OneWire library has an event to notify (reset, error, byte received)
void owReceive(OneWireSlave::ReceiveEvent evt, byte data);
// Setup the OneWire library
//OneWire.setReceiveCallback(&owReceive);
//OneWire.begin(owROM, oneWireData.getPinNumber());
delay(100);Â
 int temperature = 25;
Â
 // Add temperature to the SCRATCHPAD
 if (temperature > 99) temperature = 99;
 if (temperature < -55) temperature = -55;
 if (temperature >= 0) {
  SCRATCHPAD[0] = Lo(temperature*16);
  SCRATCHPAD[1] = Hi(temperature*16);
 else {
  SCRATCHPAD[1] = Hi(temperature*16) | 0xF8;
 // Add CRC8 to the SCRATCHPAD
// SCRATCHPAD[8] = OneWire.crc8(SCRATCHPAD,8);
Â
cli();//disable interrupts
sei();//enable interrupts
void owReceive(OneWireSlave::ReceiveEvent evt, byte data) {
switch (evt) {
  case OneWireSlave::RE_Reset:
  case OneWireSlave::RE_Byte:
   // Read Scratchpad [BEh] command
   if (data == 0xBE) {
    // Send SCRATCHPAD 9 byte with temperature and CRC
    for (byte i = 8, j = 1; j<=9; i--, j++) {
    // OneWire.write(&SCRATCHPAD[i],j, NULL);
     //Serial.print(5);
  case OneWireSlave::RE_Error:
 default:
