ENC28J60 Ethernet shield, Artnet, Led strip
HI!
I have 3 projects
one of which is unfinished :slightly_frowning_face:
Project 1 - video sending with Artnet to ESP8266 what are connected with Wifi. And led strip WS2812 is added to this module.
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#include <ArtnetWifi.h>
//Wifi settings
const char *ssid = "TEST";
const char *password = "testtest";
// Neopixel settings
const int numLeds = 169; // change for your setup
const int numberOfChannels = numLeds * 3; // Total number of channels you want to receive (1 led = 3 channels)
const byte dataPin = D4;
Adafruit_NeoPixel leds = Adafruit_NeoPixel(numLeds, dataPin, NEO_RGB + NEO_KHZ800);
// Artnet settings
ArtnetWifi artnet;
const int startUniverse = 1; // CHANGE FOR YOUR SETUP most software this is 1, some software send out artnet first universe as 0.
// Check if we got all universes
const int maxUniverses = numberOfChannels / 512 + ((numberOfChannels % 512) ? 1 : 0);
bool universesReceived[maxUniverses];
bool sendFrame = 1;
int previousDataLength = 0;
// connect to wifi – returns true if successful or false if not
boolean ConnectWifi(void)
  boolean state = true;
  int i = 0;
  WiFi.begin(ssid, password);
  Serial.println("");
  Serial.println("Connecting to WiFi");
  // Wait for connection
  Serial.print("Connecting");
    Serial.print(".");
    if (i > 20) {
      state = false;
    i++;
  if (state) {
    Serial.println("");
    Serial.print("Connected to ");
    Serial.println(ssid);
    Serial.print("IP address: ");
    Serial.println("");
    Serial.println("Connection failed.");
  return state;
void initTest()
  for (int i = 0 ; i < numLeds ; i++)
    leds.setPixelColor(i, 127, 0, 0);
  leds.show();
    leds.setPixelColor(i, 0, 127, 0);
  leds.show();
    leds.setPixelColor(i, 0, 0, 127);
  leds.show();
    leds.setPixelColor(i, 0, 0, 0);
  leds.show();
void onDmxFrame(uint16_t universe, uint16_t length, uint8_t sequence, uint8_t* data)
  sendFrame = 1;
  // set brightness of the whole strip
  if (universe == 15)
    leds.setBrightness(data[0]);
    leds.show();
  // Store which universe has got in
  if ((universe - startUniverse) < maxUniverses)
    universesReceived[universe - startUniverse] = 1;
  for (int i = 0 ; i < maxUniverses ; i++)
    if (universesReceived[i] == 0)
      //Serial.println("Broke");
      sendFrame = 0;
  // read universe and put into the right part of the display buffer
  for (int i = 0; i < length / 3; i++)
    int led = i + (universe - startUniverse) * (previousDataLength / 3);
    if (led < numLeds)
      leds.setPixelColor(led, data[i * 3], data[i * 3 + 1], data[i * 3 + 2]);
  previousDataLength = length;
  if (sendFrame)
    leds.show();
    // Reset universeReceived to 0
    memset(universesReceived, 0, maxUniverses);
  ConnectWifi();
  artnet.begin();
  leds.begin();
  initTest();
  // this will be called for each packet received
  artnet.setArtDmxCallback(onDmxFrame);
  // we call the read function inside the loop
  artnet.read();
Project 2 - video sending with Artnet to Ethernet Shield W5100 what are connected on Arduino UNO. And led strip WS2812 is added to this module.
Code in attachment:
Project 3 - video sending with Artnet to Ethernet Shield ENC28J60 what are connected on Arduino NANO. And led strip WS2812 is added to this module.
Maybe someone can help combine these two codes to use this ENC28J60 ethernet Shield?
Code for ESP8266 and W5100 modules I found myself here in the forum!
Project 1 and Project 2 are working fine!
Thanks!
Shield W5100.ino (4.76 KB)
What do you expect us to do about this?
I have no intention of doing someone else's work!
If you are unable to do the work, hire someone and post the project in the Gigs forum elsewhere on this message board.
