hi, im trying to figure out encoder pinnout. i made some conclussions. im i right?
Wire it up and try it. Put a voltmeter for A or B to ground and you should see a square wave (turn the encoder very slowly). If that doesn't work then put the voltmeter from A or B to +v. If that doesn't work, swap +v and ground, and repeat.
I would agree with @SteveMann.
However output A and output B may need each to have a 1K resistor form A to Vcc and B to Vcc.
The output is probably open collector photo transistor.
Tom.... ![]()
i wired it up, i can read 2V between gnd and a, same with b, is it ok? i used 4.2k pull up for each output
Francisco-Colli:
Sounds good for those resistors, what happens when you put an opaque object in the gap of the sensor?
That, is block the LED IR/light getting to the optotransistor?
Thanks.. Tom.. ![]()
