Hi All
I`m looking for some solution to the following problem.
I have 2 types of rotary encoders.
First have 100ppr (pulse per revolution)
Second 2500ppr
The code attached perfectly emulates the 100ppr and does exactly what i want ( simulates the actual encoder so i can test everything without the "real" encoder.
However i got nothing when i try to simulate the 2500ppr encode with the same code.
Can somebody recommend solution please?
Pinout and manufacturer is the same for both. Wiring also confirmed to be right
Thank you in advance
THE CODE HAS BEEN SPLIT IN 2 PARTS.
K Lawson 2014
Use a pot to control the cycle speed of an encoder simulator. An A and B channel drive in either direction at speeds from 1-10K Hz.
A bi-colour LED indiates speed and when we reach 1k and 10kHz.
When in the mid-position the unit is 'off'; this is taken from a dedband.
The encoder SM has 4 states and outputs at 4x lower f than it's called.
The analog sampling and LED control are done using ms timing.
1-1KHz output frequency
Green LED 0-10Hz
Red LED 10-.1KHz
Bi .1K - 1K
// Pin 13 has an LED connected on most Arduino boards.
// give it a name:
int led = 13;
// time delay constants (us). First 14 are for deadband. This is us delay times for a 5 cycle state machine.
// f = 250'000/t Hz
// so 250'000 = 1Hz and 250 = 1KHz
// note check the clock frequency is right; some chinese 3.3 models are clocked at 16Mhz; if so the set the model to the
// 5V arduino 16Mhz model in the IDE. Otherwise the timer functions are all out.
unsigned long scale[256] = {
//DEADBAND
1000,1000,1000,1000,1000,1000,1000,1000,1000,1000,1000,1000,1000,1000,
//.25 Hz (Responder testing - 100Hz
2500000, 2500000, 2500000, 2500000, 2500000, 2500000, 2500000, 900000, 600000, 250000,225225,204918,187969,173611,161290,150602,141242,
132978,125628,119047,113122,107758,102880,98425,94339,90579,87108,83892,80906,78125,75528,73099,68681,66666,64766,62972,61274,
59665,58139,56689,55309,53995,52742,51546,50403,49309,48262,47258,46296,45372,44483,43630,42808,42016,41254,40518,39808,39123,38461,
37821,37202,36603,36023,35460,34916,34387,33875,33377,32894,32425,31969,31525,31094,30674,30266,29481,29103,28735,28376,28026,
27685,27352,27027,26709,26399,26096,25799,25510,25000,22321,20161,18382,16891,15625,14534,13586,12755,12019,11363,10775,10245,
9765,9328,8928,8561,8223,7911,7621,7352,7102,6868,6648,6443,6250,6067,5896,5733,5580,5434,5296,5165,4921,4807,4699,4595,4496,
4401,4310,4222,4139,4058,3980,3906,3834,3765,3698,3633,3571,3511,3453,3396,3342,3289,3238,3188,3140,3094,3048,3004,2962,2880,2840,
2802,2765,2729,2693,2659,2626,2593,2561,2530,
//100-1kHz
2500,2500,2500,2500,2500,2500,2500,2500,2500,2500,2500,2500,1923,1562,1315,1136,1000,892,806,735,675,625,581,543,510,480,454,431,
409,390,373,357,342,328,304,284,274,265,257,
//1k-10kHz
250,250,250,250,250,250,250,250,250,250,192,156,131,113,100,89,80,73,67,62,58,54,51,48,45,43,40,39,37,35,34,32,31,30,29,28,27,26,
24,24,24,24
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
//A-B drive
pinMode(11,OUTPUT);
pinMode(12,OUTPUT);
//BI LED drive
pinMode(A2,OUTPUT);
pinMode(A4,OUTPUT);
//AI
// AI 0 = pot
//debug
}//END Setup
// the loop routine runs over and over again forever:
static unsigned long msDelay, usDelay, TrigTime, SampleTime, FlashTime, uTime;
static byte Pos,Speed,SeqEnd,Power, On, SimSpeed;
static int x;
uTime = micros();
// @@@@@@@@@@ 100Hz loop @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@
if(uTime > SampleTime)
SampleTime += 10000;
DecodePot(&msDelay, &usDelay, &Pos, &Speed, &Power, &On);
//Drive LEDs at rate and colour depending on freq; uses timer to flash led
//1-100 G
//100-1000 R
//1000=10000 Mix
DriveLED(Speed,Power,On);
}//End sample loop
// @@@@@@@@@@ 1-40KHz FAST Driver loop ( variable freq ) @@@@@@@@@@@@@
// if time to go to next sim state OR pot has changed val
if(abs(Speed-SimSpeed) > 2)
// if user has moved the pot a bit then trigger state change - for slow times
// otherwise its unresponsive around the null point
TrigTime = uTime;
//Time for a state change!
if((uTime >= TrigTime))
TrigTime += usDelay;
//drive IO; 5 cycle state machine Tell it dir and on/off status
SimulateEncoder(Pos,On);
SimSpeed=Speed;
}//DELAY
// Catch any rollover strangeness
if(uTime < 100)
SampleTime = 0;
TrigTime = 0;
}//END Loop
// read the freq pot. 0-3V equates to 0-1023
// The delays vary a lot so we output ms or us.
// Pos tells the drive module to go fwd / rev
// pow describes the output frequncy and is used to
// change the LED colour.
// *msDelay delay tme to be returned (not used)
// *usDelay delay tme to be returned in us
// *Pos output TRUE /FALSE simulate encoder going Fwd / back
// *Speed 0-255 represents speed of encoder sim (255) = fast used for LED display
// *Power 0,1,2 tells the LED diaply the band of simulationspeed for LED colour.
// *On The mid position has a dead band; when in this region turn the
// simulation off
void DecodePot(unsigned long *msDelay, unsigned long *usDelay, byte *Pos, byte *Speed, byte *Power, byte *On)
unsigned long val;
int index;
static int LastVal;
// 0-1023;
index = analogRead(6); //0-1023
// time saver; only do this stuff if there's a change
/*if(index == LastVal)
return;
LastVal = index;*/
index -= 512; //-512 <> 511
//go fwd / back
if(index<0)
*Pos = 0;
*Pos = 1;
//get the scaled time delay from the scale array/
//previously derived from excel
// / by 2 as thats the res of the lookup table
index = (abs(index) - 1) >> 1; //0-255
val = scale[index] ; //originlly did 10K; now just go to 1KHz
//Serial.print(val);
//Serial.print(",");
//Serial.println(index);
*Speed = index; //for LED drive delay 255 = fast 0 = slow
//on off indicator
if(*Speed < 15)
*On = 0;
*On = 1;
// use the fast or slow timer since us has a 65k max time delay
// after that val use ms timer
*usDelay = val;
// set power of indicator to change LED colour
// 0 200 2000 300000us
// 2 1 0
*Power=0; // 0-100 hz
if(val <= 250 ) // 1k-10k
*Power = 2;
else if(val <= 2500) // 100-1k
*Power=1;
}//End DecodePot
// Drive the LED this is done using a bi-colour LED. 2 DOs decide
// the colour red or green and a third colour is used also
// The log power is used to determine the LED flash colour and
// when the colour chnges the flash rate is divided down so it's
// visible.
// Colour Drive Hz Pow
// GREEN Gn 0-100 0
// YELLOW Red + Gn alternate 100-1000 1
// RED Red 1000-10000 2
// This routine is called at a non constant frequency therefore a timer
// is used to flash the LED.
void DriveLED(byte Speed, byte Pow, byte On)
static char toggle,subtoggle;
static int divisor;
char trigger=0,A,B;
static unsigned long TimeToggle;
// Speed = 0-255
// 0=1000ms 255=5ms
if(millis() > TimeToggle)
//set next time to toggle leds (ms)
TimeToggle = 260 - Speed;
TimeToggle += millis();
//toggle bit
toggle++;
toggle &= 1;
if(toggle && On)
//toggle LED
if(Pow == 0) //Gn
digitalWrite(A2,HIGH);
digitalWrite(A4,LOW);
else if (Pow == 2) //Yl
if(subtoggle==0)
digitalWrite(A2,LOW);
digitalWrite(A4,HIGH);
//toggle bit
subtoggle++;
subtoggle &= 1;
else //Rd
}//END toggle
}//END if time
}//END DriveLEDs
