Hello,
I am doing the motor bike project and i have a small problem with the encoder on the rear wheel driving motor. It looks like the Simulink support package Encoder block stops outputting the speed signal after i disconnect the USB cable and monitor the motorbike through Wifi connection. It still outputs the position signal.
I have added a screenshot where you can see the wheel speed signal working correctly at the start but after i had disconnected the USB cable it was zero all the way until the end. After that signal will remain zero until you turn the board off and on again.
Hi parol_m,
Did you find a resolution? please share if you can, thank you.
I reported the problem to mathworks and meanwhile i am using difference block to calculate the counts per second from position output.
