Endurance
I am going to run code in arduino board continuously for 3 months. Do you think it can stand it without affecting intended functionality?
Without seeing the code?
No comment.
I have an Atmega 328 on stripboard running 24/7 for nearly a year now.
...R
Yes.
As far a the micro goes you can run for as many years as you like, I know of 100,000 of micros which have been running that long.
Mark
jismagic:
Atmega_datasheet:
– Data retention: 20 years at 85°C/100 years at 25°C(1)
Reliability Qualification results show that the projected data retention failure rate is much less
than 1 PPM over 20 years at 85°C or 100 years at 25°C.
As long as it's not in space... If it is, make sure to wrap it around with a lot of aluminium foil. My biggest concern would be the on-board regulator.
I've had an AVR chip run continuously for about 4 years; it's not a problem. Humidity, temperature, vibrations-this will all affect the reliability of the device. Make sure your input voltage isn't too high; 9 volts is about it, excess energy gets converted into heat when it's not powered from USB. Even if you put it high, it will still be okay. 3 months is not an issue.
I built a car alarm with a different-older microcontroller and it's been running continuously in my 1994 van for almost 20 years with no problems! It runs a 24/7 and and is enabled/disabled depending on the state of an input pin, so it never gets turned-off or reset. It only gets turned-off & rebooted when the battery in the van has to be replaced every 3 or 4 years.
Now... I wouldn't send it into space or use it for medical life support, because it's just not built that well (it's built on a "breadboard") and there is no redundancy, back-up, fault detection, or fault-tolerance. But, it's been doggone reliable.
jismagic:
Unless you are foolishly using EEPROM for continueous writes that would exceed the recommended maximum in the 90 day period.
Ray
