I would greatly appreciate help resolving the error messages below created when verifying the Wire Master Reader code included in this posting.
IDE: Energia 1.8.11E23 running on Windows 7 64 bit
Master device: Launch Pad MSP-EXP30g2ET with a MCU part type MSP-EXP430G2553
Error messages:
Energia: 1.8.11E23 (Windows 10), Board: "MSP-EXP430G2 w/ MSP430G2553"
C:\energia-1.8.10E23-windows\energia-1.8.10E23\hardware\energia\msp430\libraries\Wire\utility\twi.c: In function 'twi_disable':
C:\energia-1.8.10E23-windows\energia-1.8.10E23\hardware\energia\msp430\libraries\Wire\utility\twi.c:443:5: error: 'UCBzCTLW0' undeclared (first use in this function)
C:\energia-1.8.10E23-windows\energia-1.8.10E23\hardware\energia\msp430\libraries\Wire\utility\twi.c:443:5: note: each undeclared identifier is reported only once for each function it appears in
Multiple libraries were found for "Wire.h"
Used: C:\energia-1.8.10E23-windows\energia-1.8.10E23\hardware\energia\msp430\libraries\Wire
exit status 1
Error compiling for board MSP-EXP430G2 w/ MSP430G2553.
Note: I have deleted all but one instance of wire.h
// Wire Master Reader
// by Nicholas Zambetti http://www.zambetti.com
// Demonstrates use of the Wire library
// Reads data from an I2C/TWI slave device
// Refer to the "Wire Slave Sender" example for use with this
// Created 29 March 2006
// This example code is in the public domain.
#include <Wire.h>
Wire.begin(0x5A); // slave address (Address not required if master)
Serial.begin(9600); // start serial for output
Wire.requestFrom(2, 6); // request 6 bytes from slave device #2
while(Wire.available()) // slave may send less than requested
char c = Wire.read(); // receive a byte as character
Serial.print(c); // print the character
