Boa noite Luis.
Essa montagem é para executar o código de exemplo da biblioteca do Greg Copeland:
Copyright (C) 2011 James Coliz, Jr. <maniacbug@ymail.com>
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
version 2 as published by the Free Software Foundation.
* Example LED Remote
* This is an example of how to use the RF24 class to control a remote
* bank of LED's using buttons on a remote control.
* On the 'remote', connect any number of buttons or switches from
* an arduino pin to ground. Update 'button_pins' to reflect the
* pins used.
* On the 'led' board, connect the same number of LED's from an
* arduino pin to a resistor to ground. Update 'led_pins' to reflect
* the pins used. Also connect a separate pin to ground and change
* the 'role_pin'. This tells the sketch it's running on the LED board.
* Every time the buttons change on the remote, the entire state of
* buttons is send to the led board, which displays the state.
#include <SPI.h>
#include "RF24.h"
#include "printf.h"
// Hardware configuration
// Set up nRF24L01 radio on SPI bus plus pins 8 & 9
RF24 radio(8,9);
// sets the role of this unit in hardware. Connect to GND to be the 'led' board receiver
// Leave open to be the 'remote' transmitter
const int role_pin = A4;
// Pins on the remote for buttons
const uint8_t button_pins[] = { 2,3,4,5,6,7 };
const uint8_t num_button_pins = sizeof(button_pins);
// Pins on the LED board for LED's
const uint8_t led_pins[] = { 2,3,4,5,6,7 };
const uint8_t num_led_pins = sizeof(led_pins);
// Topology
// Single radio pipe address for the 2 nodes to communicate.
const uint64_t pipe = 0xE8E8F0F0E1LL;
// Role management
// Set up role. This sketch uses the same software for all the nodes in this
// system. Doing so greatly simplifies testing. The hardware itself specifies
// which node it is.
// This is done through the role_pin
// The various roles supported by this sketch
typedef enum { role_remote = 1, role_led } role_e;
// The debug-friendly names of those roles
const char* role_friendly_name[] = { "invalid", "Remote", "LED Board"};
// The role of the current running sketch
role_e role;
// Payload
uint8_t button_states[num_button_pins];
uint8_t led_states[num_led_pins];
// Setup
void setup(void)
// Role
// set up the role pin
pinMode(role_pin, INPUT);
digitalWrite(role_pin,HIGH);
delay(20); // Just to get a solid reading on the role pin
// read the address pin, establish our role
if ( digitalRead(role_pin) )
role = role_remote;
role = role_led;
// Print preamble
Serial.begin(57600);
printf_begin();
printf("\n\rRF24/examples/led_remote/\n\r");
printf("ROLE: %s\n\r",role_friendly_name[role]);
// Setup and configure rf radio
radio.begin();
// Open pipes to other nodes for communication
// This simple sketch opens a single pipes for these two nodes to communicate
// back and forth. One listens on it, the other talks to it.
if ( role == role_remote )
radio.openWritingPipe(pipe);
radio.openReadingPipe(1,pipe);
// Start listening
if ( role == role_led )
radio.startListening();
// Dump the configuration of the rf unit for debugging
radio.printDetails();
// Set up buttons / LED's
// Set pull-up resistors for all buttons
int i = num_button_pins;
while(i--)
pinMode(button_pins[i],INPUT);
digitalWrite(button_pins[i],HIGH);
// Turn LED's ON until we start getting keys
int i = num_led_pins;
while(i--)
pinMode(button_pins[i],OUTPUT);
led_states[i] = HIGH;
digitalWrite(led_pins[i],led_states[i]);
// Loop
void loop(void)
// Remote role. If the state of any button has changed, send the whole state of
// all buttons.
// Get the current state of buttons, and
// Test if the current state is different from the last state we sent
bool different = false;
while(i--)
uint8_t state = ! digitalRead(button_pins[i]);
if ( state != button_states[i] )
different = true;
button_states[i] = state;
// Send the state of the buttons to the LED board
if ( different )
printf("Now sending...");
bool ok = radio.write( button_states, num_button_pins );
if (ok)
printf("ok\n\r");
printf("failed\n\r");
// Try again in a short while
delay(20);
// LED role. Receive the state of all buttons, and reflect that in the LEDs
// if there is data ready
if ( radio.available() )
// Dump the payloads until we've gotten everything
bool done = false;
while (!done)
// Fetch the payload, and see if this was the last one.
done = radio.read( button_states, num_button_pins );
// Spew it
printf("Got buttons\n\r");
// For each button, if the button now on, then toggle the LED
while(i--)
if ( button_states[i] )
led_states[i] ^= HIGH;
// vim:ai:cin:sts=2 sw=2 ft=cpp
No início, possui as instruções de montagem em inglês, que compreendi da seguinte forma:
"Conecte qualquer número de botões ou chaves dos pinos arduinos (2,3,4,5,6,7) ligados ao terra" (Fiz isso)
"Conecte o mesmo número de leds dos pinos arduinos (2,3,4,5,6,7) à um resistor, ao GND"
Isso é o que confere na foto, montando próximo para minimizar fios de ligação.
Porém, desisti no meio, pois acredito (ainda pesquisando), ter um exemplo já pronto, ou mais simples, para a minha aplicação:
- No master, pressionei um botão, que equivale ao envio de um sinal/variável
- O slave irá receber este sinal e acender um led
- Logo depois, o slave irá retornar o sinal
- O master recebe esse sinal e confirma que a ação foi executada
- Caso o sinal não seja retornado, um led vermelho do master acende e depois apaga.
Att,
Yago
