EPSOLAR solar charge controller monitoring system
Hello people
I'm a novice and I'm trying to read data from an epever charge controller using MODBUS according to the following details:
Arduino: Mega
Used library: ModbusMaster
Circuit: rs-485 module connected as follows
1- MAX485_DE → Pin 2 of Arduino
2- MAX485_RE_NEG → Pin 2 of the Arduino
3- MAX485_RO → 19 Arduino RX Pin
4- MAX485_DI → 18 TX Pin of Arduino
#include <ModbusMaster.h>
#define MAX485_DE      2
#define MAX485_RE_NEG  2
ModbusMaster node;
void preTransmission()
  digitalWrite(MAX485_RE_NEG, 1);
  digitalWrite(MAX485_DE, 1);
void postTransmission()
  digitalWrite(MAX485_RE_NEG, 0);
  digitalWrite(MAX485_DE, 0);
  pinMode(MAX485_RE_NEG, OUTPUT);
  pinMode(MAX485_DE, OUTPUT);
  Serial1.begin(115200);
  node.begin(1, Serial1);
  node.preTransmission(preTransmission);
  node.postTransmission(postTransmission);
bool state = true;
  uint8_t result;
  uint16_t data[6];
  result = node.writeSingleCoil(0x0002, state);
  state = !state;
  result = node.readInputRegisters(0x3100, 5);
  if (result == node.ku8MBSuccess)
    Serial.print("Array Power(W)[L] : ");
    Serial.println(node.getResponseBuffer(0x02) / 100.0f);
    Serial.print("Array Power(W)[H] : ");
    Serial.println(node.getResponseBuffer(0x03) / 100.0f);
  result = node.readInputRegisters(0x3200, 5);
    Serial.print("Battery Status : ");
    Serial.println(node.getResponseBuffer(0x00));
    Serial.print("Charging Status : ");
    Serial.println(node.getResponseBuffer(0x01));
    Serial.print("Array Status : ");
    Serial.print("Device Status : ");
    Serial.print("Load Status : ");
    Serial.println(node.getResponseBuffer(0x02));
  Serial.println("===================================================");
The link below has the address of each epever charge controller data
https://drive.google.com/file/d/1MR_LYVdnBIO6cV4cjuRz217lro9rRGKE/view?usp=sharing
I tested the code to get variables like voltage and current and it works normally. My question is how can I get the Battery status, Array status, Charging status, Load status and Array Power(W) data correctly?
According to the epever manual, the power array data is divided into two addresses L and H (L: 0x3102 / H: 0x3103).
On the other hand, the status analysis data is distributed as follows:
Array status: address 3201 bits D15-D10
Charging status:address 3201 bits D3-D2
Battery status: address 3200 bits D7-D0
Load status: address 3201 bits D9-D7, address 3202 bits D13-D8,D6-D4
Device status: address 3200 bit D15 address 3201 bits D6 address 2000
The description of each address according to the epever manual is as follows:
Battery status (0x3200):
D15: 1-Wrong identification for rated voltage
D8: Battery inner resistance abnormal 1, normal 0
D7-D4: 0x00 Normal, 0x01 Over Temp.(Higher than the warning settings), 0x02 Low Temp.(Lower than the warning settings),
D3-D0: 0x00 Normal ,0x01 Over Voltage. , 0x02 Under Voltage, 0x03 Over discharge, 0x04 Fault
Charging equipment status (0x3201):
D15-D14: Input voltage status. 0x00 normal, 0x01 No input power connected, 0x02 Higher input voltage , 0x03 Input voltage error.
D13: Charging MOSFET is short circuit.
D12: Charging or Anti-reverse MOSFET is open circuit.
D11: Anti-reverse MOSFET is short circuit.
D10: Input is over current.
D9: The load is over current.
D8: The load is short circuit.
D7: Load MOSFET is short circuit.
D6:Disequilibrium in three circuits.
D4: PV input is short circuit.
D3-D2: Charging status. 0x00 No charging, 0x01 Float, 0x02 Boost, 0x03 Equalization.
D1: 0 Normal, 1 Fault.
D0: 1 Running, 0 Standby
Discharging equipment status (0x3202):
D15-D14: 0x00 Input voltage normal, 0x01 Input voltage low, 0x02 Input voltage high, 0x03 no access.
D13-D12: Output power. 0x00 Light load, 0x01 Moderate, 0x02 rated, 0x03 overload
D11: Short circuit
D10: Unable to discharge
D9: Unable to stop discharging
D8: Output voltage abnormal
D7: Input over voltage
D6: Short circuit in high voltage side
D5: Boost over voltage
D4: Output over voltage
D0: 1 Running, 0 Standby.
When you retrieve a value out of your node.getResponseBuffer(), you are getting a 16 bit unsigned value. For the battery status, you then have to look at those specific bits
  Serial.println(node.getResponseBuffer(0x00), BIN);
  uint16_t batStatus = node.getResponseBuffer(0x00);
  if ( batStatus & 0x8000 ) {
    Serial.print("Wrong identification for rated voltage");
  if ( batStatus & 0x0100 ) {
    Serial.print("Battery inner resistance abnormal");
  uint8_t temp = (batStatus & 0x00F0) >> 4;   // D7-D4 shifted down
  if ( temp == x000 ) {
    Serial.print("Normal");
  } else if ( temp == 0x01 ) {
    Serial.print("Over Temp.(Higher than the warning settings)");
  } else if ( temp == 0x02 ) {
    Serial.print("Low Temp.(Lower than the warning settings)");
  temp = (batStatus & 0x000F);   // D3-D0
    Serial.print("Over Voltage.");
    Serial.print("Under Voltage");
  } else if ( temp == 0x03 ) {
    Serial.print("Over discharge");
  } else if ( temp == 0x04 ) {
    Serial.print("Fault");
This is the code I used when I played with mine. Works very well I learnt from it and made my own spin off from that this code, I think I found that on here.
    This code is for reading live-, statistical and status-data from
    an EpEver LandStar B ( LS1024B ) via a Modbus connection.
    The data is then published via mqtt to be fed to gafana and pimatic.
    This code started as a small sketch to read the data via modbus and
    then got additions for mqtt, deep-sleep, debug a.t.l.. It got quite big
    an should get some restructuring...
    If you have another EpEver charge controller (like a Tracer),
    you may need to adjust the register/data locations according
    to the datasheet.
    I'm using a NodeMCU clone (Board: Lolin Wemos D1 R2 & mini) and a
    widespread MAX485 breakout module to connect to the RJ45 port of the
    solar charge controller.
    Both modules are powered using the (in my case) 7.5 Volt supply-voltage
    that is available at the RJ45 port. If you're using another esp module
    (e.g. Wemos D1 mini), make sure, the onboard voltage-regulator can
    handle the 7.5 volts from the EpEver.
    To avoid the need of a level-shifter, the max485 module is powered only
    with 3V3 from the NodeMCU, which works for me, but YMMV.
    Power-consumption is roughly 4mA during Deep-Sleep, mostly due to the
    onboard leds, I guess. When running, the power-demand gets up to about
    75mA for 3-4 seconds.
    Connections:
            MAX485         NodeMCU
            DI              TX
            DE              D2
            RE              D1
            RO              RX
            VCC             3V3 !!!
            GND             GND
         EpEver RJ45                        MAX485      NodeMCU
        pin1  +7.5 V       org-wht                       Vin
        pin8  GND          brn                           GND
        pin6  RS-485-A     grn               A
        pin4  RS-485-B     blu               B
    connect DE (Max485) with a pull-down resistor (e.g. 6k7) to GND,
    to hold that line down in Deep-Sleep to lower power consumption
    connect D0 (NodeMCU) with reset (NodeMCU) for DeepSleep wake-up to work
    connect D6 (NodeMCU)and D7 (NodeMCU) to enable debug-mode. this
    sets the sleep duration to only 10 seconds
    some datasheets list different pinouts for the RJ45 jack!  swap A<->B if
    connection fails. Check voltage-level and -polarity before connecting!
    I'm excessively using the union-struct trick to map buffer-data
    to structs here. Most of the defines for the data-locations
    are for reference only and not actually used in the code
    I got loads of info for this from:
        https://www.eevblog.com/forum/projects/nodemcu-esp8266-rs485-epever-solar-monitor-diy/
        http://4-20ma.io/ModbusMaster
    For taking the data to grafana, have a look here:
        https://github.com/glitterkitty/mqtt-mysql
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
// settings
const char* ssid =        "your_ssid";
const char* password =    "your_pass";
const char* mqtt_server = "you_broker";
uint16_t sleepSeconds =    120;         // 2 minutes default
// Pins
#define LED             D4  // for flashing the led - LOW active!
#define MAX485_DE       D2  // data or
#define MAX485_RE       D1  //      recv enable
// ModBus Register Locations
#define LIVE_DATA       0x3100     // start of live-data
#define LIVE_DATA_CNT   16         // 16 regs
// just for reference, not used in code
#define PANEL_VOLTS     0x00
#define PANEL_AMPS      0x01
#define PANEL_POWER_L   0x02
#define PANEL_POWER_H   0x03
#define BATT_VOLTS      0x04
#define BATT_AMPS       0x05
#define BATT_POWER_L    0x06
#define BATT_POWER_H    0x07
// dummy * 4
#define LOAD_VOLTS      0x0C
#define LOAD_AMPS       0x0D
#define LOAD_POWER_L    0x0E
#define LOAD_POWER_H    0x0F
#define RTC_CLOCK           0x9013  // D7-0 Sec, D15-8 Min  :   D7-0 Hour, D15-8 Day  :  D7-0 Month, D15-8 Year
#define RTC_CLOCK_CNT       3       // 3 regs
#define BATTERY_SOC         0x311A  // State of Charge in percent, 1 reg
#define BATTERY_CURRENT_L   0x331B  // Battery current L
#define BATTERY_CURRENT_H   0x331C  // Battery current H
#define STATISTICS      0x3300 // start of statistical data
#define STATISTICS_CNT  22     // 22 regs
#define PV_MAX     0x00 // Maximum input volt (PV) today
#define PV_MIN     0x01 // Minimum input volt (PV) today
#define BATT_MAX   0x02 // Maximum battery volt today
#define BATT_MIN   0x03 // Minimum battery volt today
#define CONS_ENERGY_DAY_L   0x04 // Consumed energy today L
#define CONS_ENGERY_DAY_H   0x05 // Consumed energy today H
#define CONS_ENGERY_MON_L   0x06 // Consumed energy this month L
#define CONS_ENGERY_MON_H   0x07 // Consumed energy this month H
#define CONS_ENGERY_YEAR_L  0x08 // Consumed energy this year L
#define CONS_ENGERY_YEAR_H  0x09 // Consumed energy this year H
#define CONS_ENGERY_TOT_L   0x0A // Total consumed energy L
#define CONS_ENGERY_TOT_H   0x0B // Total consumed energy  H
#define GEN_ENERGY_DAY_L   0x0C // Generated energy today L
#define GEN_ENERGY_DAY_H   0x0D // Generated energy today H
#define GEN_ENERGY_MON_L   0x0E // Generated energy this month L
#define GEN_ENERGY_MON_H   0x0F // Generated energy this month H
#define GEN_ENERGY_YEAR_L  0x10 // Generated energy this year L
#define GEN_ENERGY_YEAR_H  0x11 // Generated energy this year H
#define GEN_ENERGY_TOT_L   0x12 // Total generated energy L
#define GEN_ENERGY_TOT_H   0x13 // Total Generated energy  H
#define CO2_REDUCTION_L    0x14 // Carbon dioxide reduction L
#define CO2_REDUCTION_H    0x15 // Carbon dioxide reduction H
#define LOAD_STATE         0x02 // r/w load switch state
#define STATUS_FLAGS    0x3200
#define STATUS_BATTERY    0x00  // Battery status register
#define STATUS_CHARGER    0x01  // Charging equipment status register
ModbusMaster node;   // instantiate ModbusMaster object
WiFiClient wifi_client;
PubSubClient mqtt_client(wifi_client);
char mqtt_msg[64];
char buf[256];
int do_update = 0, switch_load = 0;
bool loadState = true;
int debug_mode = 0;             // no sleep and mmore updates
  // say hello
  while (!Serial) {
  Serial.println("Hello World! I'm an EpEver Solar Monitor!");
  // test for jumper on D6/D7 for enabling debug-mode
  pinMode(D7, OUTPUT);
  digitalWrite(D7, LOW);
  pinMode(D6, INPUT_PULLUP);
  for (int i = 0; i < 10; i++) {
    debug_mode += digitalRead(D6);
    delay(20);
  if (debug_mode < 5) {
    debug_mode = 1;
    sleepSeconds = 10;
    Serial.println( "debug-mode: on" );
    debug_mode = 0;
    Serial.println( "debug-mode: off" );
  // Connect D0 to RST to wake up
  pinMode(D0, WAKEUP_PULLUP);
  // init modbus in receive mode
  pinMode(MAX485_RE, OUTPUT);
  digitalWrite(MAX485_RE, 0);
  // EPEver Device ID 1
  node.begin(1, Serial);
  // modbus callbacks
  // Initialize the LED_BUILTIN pin as an output, low active
  pinMode(LED, OUTPUT);
  digitalWrite(LED, HIGH);
  // mqtt init
  mqtt_client.setServer(mqtt_server, 1883);
  mqtt_client.setCallback(mqtt_callback);
  // datastructures, also for buffer to values conversion
  uint8_t i, result;
  // clock
  union {
    struct {
      uint8_t  s;
      uint8_t  m;
      uint8_t  h;
      uint8_t  d;
      uint8_t  M;
      uint8_t  y;
    } r;
    uint16_t buf[3];
  } rtc ;
  // live data
  union {
    struct {
      int16_t  pV;
      int16_t  pI;
      int32_t  pP;
      int16_t  bV;
      int16_t  bI;
      int32_t  bP;
      uint16_t  dummy[4];
      int16_t  lV;
      int16_t  lI;
      int32_t  lP;
    } l;
    uint16_t  buf[16];
  } live;
  // statistics
  union {
    struct {
      // 4*1 = 4
      uint16_t  pVmax;
      uint16_t  pVmin;
      uint16_t  bVmax;
      uint16_t  bVmin;
      // 4*2 = 8
      uint32_t  consEnerDay;
      uint32_t  consEnerMon;
      uint32_t  consEnerYear;
      uint32_t  consEnerTotal;
      // 4*2 = 8
      uint32_t  genEnerDay;
      uint32_t  genEnerMon;
      uint32_t  genEnerYear;
      uint32_t  genEnerTotal;
      // 1*2 = 2
      uint32_t  c02Reduction;
    } s;
    uint16_t  buf[22];
  } stats;
  // these are too far away for the union conversion trick
  uint16_t batterySOC = 0;
  int32_t batteryCurrent = 0;
  // battery status
  struct {
    uint8_t volt;        // d3-d0  Voltage:     00H Normal, 01H Overvolt, 02H UnderVolt, 03H Low Volt Disconnect, 04H Fault
    uint8_t temp;        // d7-d4  Temperature: 00H Normal, 01H Over warning settings, 02H Lower than the warning settings
    uint8_t resistance;  // d8     abnormal 1, normal 0
    uint8_t rated_volt;  // d15    1-Wrong identification for rated voltage
  } status_batt ;
  char batt_volt_status[][20] = {
    "Normal",
    "Overvolt",
    "Low Volt Disconnect",
    "Fault"
  char batt_temp_status[][16] = {
    "Normal",
    "Over WarnTemp",
    "Below WarnTemp"
  // charging equipment status (not fully impl. yet)
  //uint8_t charger_operation = 0;
  //uint8_t charger_state = 0;
  //uint8_t charger_input = 0;
  uint8_t charger_mode  = 0;
  //char charger_input_status[][20] = {
  //  "Normal",
  //  "No power connected",
  //  "Higher volt input",
  //  "Input volt error"
  char charger_charging_status[][12] = {
    "Off",
    "Float",
    "Boost",
    "Equlization"
  // flash the led
  for (i = 0; i < 3; i++) {
    digitalWrite(LED, LOW);
    delay(200);
    delay(200);
  // clear old data
  memset(rtc.buf, 0, sizeof(rtc.buf));
  memset(live.buf, 0, sizeof(live.buf));
  memset(stats.buf, 0, sizeof(stats.buf));
  // Read registers for clock
  delay(200);
  node.clearResponseBuffer();
  result = node.readHoldingRegisters(RTC_CLOCK, RTC_CLOCK_CNT);
  if (result == node.ku8MBSuccess)  {
    rtc.buf[0]  = node.getResponseBuffer(0);
    rtc.buf[1]  = node.getResponseBuffer(1);
    rtc.buf[2]  = node.getResponseBuffer(2);
    Serial.print("Miss read rtc-data, ret val:");
    Serial.println(result, HEX);
  // read LIVE-Data
  delay(200);
  result = node.readInputRegisters(LIVE_DATA, LIVE_DATA_CNT);
    for (i = 0; i < LIVE_DATA_CNT ; i++) live.buf[i] = node.getResponseBuffer(i);
    Serial.print("Miss read liva-data, ret val:");
  // Statistical Data
  delay(200);
  result = node.readInputRegisters(STATISTICS, STATISTICS_CNT);
    for (i = 0; i < STATISTICS_CNT ; i++)  stats.buf[i] = node.getResponseBuffer(i);
  } else  {
    Serial.print("Miss read statistics, ret val:");
  // Battery SOC
  delay(200);
  result = node.readInputRegisters(BATTERY_SOC, 1);
    batterySOC = node.getResponseBuffer(0);
  } else  {
    Serial.print("Miss read batterySOC, ret val:");
  // Battery Net Current = Icharge - Iload
  delay(200);
  result = node.readInputRegisters(  BATTERY_CURRENT_L, 2);
    batteryCurrent = node.getResponseBuffer(0);
    batteryCurrent |= node.getResponseBuffer(1) << 16;
  } else  {
    Serial.print("Miss read batteryCurrent, ret val:");
  // State of the Load Switch
  delay(200);
  result = node.readCoils(  LOAD_STATE, 1 );
    loadState = node.getResponseBuffer(0);
  } else  {
    Serial.print("Miss read loadState, ret val:");
  // Read Status Flags
  delay(200);
  result = node.readInputRegisters(  0x3200, 2 );
    uint16_t temp = node.getResponseBuffer(0);
    Serial.print( "Batt Flags : "); Serial.println(temp);
    status_batt.volt = temp & 0b1111;
    status_batt.temp = (temp  >> 4 ) & 0b1111;
    status_batt.resistance = (temp  >>  8 ) & 0b1;
    status_batt.rated_volt = (temp  >> 15 ) & 0b1;
    temp = node.getResponseBuffer(1);
    Serial.print( "Chrg Flags : "); Serial.println(temp, HEX);
    //for(i=0; i<16; i++) Serial.print( (temp >> (15-i) ) & 1 );
    //Serial.println();
    //charger_input     = ( temp & 0b0000000000000000 ) >> 15 ;
    charger_mode        = ( temp & 0b0000000000001100 ) >> 2 ;
    //charger_input     = ( temp & 0b0000000000000000 ) >> 12 ;
    //charger_operation = ( temp & 0b0000000000000000 ) >> 0 ;
    //Serial.print( "charger_input : "); Serial.println( charger_input );
    Serial.print( "charger_mode  : "); Serial.println( charger_mode );
    //Serial.print( "charger_oper  : "); Serial.println( charger_operation );
    //Serial.print( "charger_state : "); Serial.println( charger_state );
  } else  {
    Serial.print("Miss read ChargeState, ret val:");
  // Print out to serial
  Serial.printf("\n\nTime:  20%02d-%02d-%02d   %02d:%02d:%02d   \n",  rtc.r.y , rtc.r.M , rtc.r.d , rtc.r.h , rtc.r.m , rtc.r.s  );
  Serial.print(  "\nLive-Data:           Volt        Amp       Watt  ");
  Serial.printf( "\n  Panel:            %7.3f    %7.3f    %7.3f ",  live.l.pV / 100.f ,  live.l.pI / 100.f ,  live.l.pP / 100.0f );
  Serial.printf( "\n  Batt:             %7.3f    %7.3f    %7.3f ",  live.l.bV / 100.f ,  live.l.bI / 100.f ,  live.l.bP / 100.0f );
  Serial.printf( "\n  Load:             %7.3f    %7.3f    %7.3f ",  live.l.lV / 100.f ,  live.l.lI / 100.f ,  live.l.lP / 100.0f );
  Serial.printf( "\n  Battery Current:  %7.3f  A ",      batteryCurrent / 100.f  );
  Serial.printf( "\n  Battery SOC:      %7.0f  %% ",     batterySOC / 1.0f  );
  Serial.printf( "\n  Load Switch:          %s   ",     (loadState == 1 ? " On" : "Off") );
  Serial.print(  "\n\nStatistics:  ");
  Serial.printf( "\n  Panel:       min: %7.3f   max: %7.3f   V", stats.s.pVmin / 100.f  , stats.s.pVmax / 100.f  );
  Serial.printf( "\n  Battery:     min: %7.3f   max: %7.3f   V", stats.s.bVmin / 100.f , stats.s.bVmax / 100.f);
  Serial.printf( "\n  Consumed:    day: %7.3f   mon: %7.3f   year: %7.3f  total: %7.3f   kWh",
                 stats.s.consEnerDay / 100.f  , stats.s.consEnerMon / 100.f  , stats.s.consEnerYear / 100.f  , stats.s.consEnerTotal / 100.f   );
  Serial.printf( "\n  Generated:   day: %7.3f   mon: %7.3f   year: %7.3f  total: %7.3f   kWh",
                 stats.s.genEnerDay / 100.f   , stats.s.genEnerMon / 100.f   , stats.s.genEnerYear / 100.f   , stats.s.genEnerTotal / 100.f  );
  Serial.printf( "\n  CO2-Reduction:    %7.3f  t ",      stats.s.c02Reduction / 100.f  );
  Serial.print(  "\nStatus:");
  Serial.printf( "\n    batt.volt:         %s   ",     batt_volt_status[status_batt.volt] );
  Serial.printf( "\n    batt.temp:         %s   ",     batt_temp_status[status_batt.temp] );
  Serial.printf( "\n    charger.charging:  %s   ",     charger_charging_status[ charger_mode] );
  // Go Online to publish via mqtt
  // get wifi going
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  // establish/keep mqtt connection
  if (!mqtt_client.connected()) {
    mqtt_reconnect();
  mqtt_client.loop();
  // publish via mqtt
  Serial.println("Publishing: ");
  // time
  sprintf(buf, "20%02d-%02d-%02d %02d:%02d:%02d" ,
  mqtt_publish_s( "solar/status/time", buf );
  // panel
  mqtt_publish_f( "solar/panel/V", live.l.pV / 100.f);
  mqtt_publish_f( "solar/panel/I", live.l.pI / 100.f);
  mqtt_publish_f( "solar/panel/P", live.l.pP / 100.f);
  mqtt_publish_f( "solar/battery/V", live.l.bV / 100.f);
  mqtt_publish_f( "solar/battery/I", live.l.bI / 100.f);
  mqtt_publish_f( "solar/battery/P", live.l.bP / 100.f);
  mqtt_publish_f( "solar/load/V", live.l.lV / 100.f);
  mqtt_publish_f( "solar/load/I", live.l.lI / 100.f);
  mqtt_publish_f( "solar/load/P", live.l.lP / 100.f);
  mqtt_publish_f( "solar/co2reduction/t", stats.s.c02Reduction / 100.f);
  mqtt_publish_f( "solar/battery/SOC",   batterySOC / 1.0f);
  mqtt_publish_f( "solar/battery/netI",  batteryCurrent / 100.0f);
  mqtt_publish_s( "solar/load/state",    (char*) (loadState == 1 ? "on" : "off") ); // pimatic state topic does not work with integers or floats ?!?
  mqtt_publish_f( "solar/battery/minV", stats.s.bVmin / 100.f);
  mqtt_publish_f( "solar/battery/maxV", stats.s.bVmax / 100.f);
  mqtt_publish_f( "solar/panel/minV", stats.s.pVmin / 100.f);
  mqtt_publish_f( "solar/panel/maxV", stats.s.pVmax / 100.f);
  mqtt_publish_f( "solar/energy/consumed_day", stats.s.consEnerDay / 100.f );
  mqtt_publish_f( "solar/energy/consumed_all", stats.s.consEnerTotal / 100.f );
  mqtt_publish_f( "solar/energy/generated_day", stats.s.genEnerDay / 100.f );
  mqtt_publish_f( "solar/energy/generated_all",  stats.s.genEnerTotal / 100.f );
  mqtt_publish_s( "solar/status/batt_volt", batt_volt_status[status_batt.volt] );
  mqtt_publish_s( "solar/status/batt_temp", batt_temp_status[status_batt.temp] );
  //mqtt_publish_s( "solar/status/charger_input", charger_input_status[ charger_input ]  );
  mqtt_publish_s( "solar/status/charger_mode",  charger_charging_status[ charger_mode ] );
  // delay work - but break nap on changes
  /*i = 20;
    do_update = 0;
    while(i--){
    mqtt_client.loop();
    if( do_update == 1 )
  // Do the Switching of the Load here - doesn't work in callback ?!?
  if ( switch_load == 1 ) {
    switch_load = 0;
    Serial.print("Switching Load ");
    Serial.println( (loadState ? "On" : "Off") );
    delay(200);
    result = node.writeSingleCoil(0x0002, loadState);
    if (result != node.ku8MBSuccess)  {
      Serial.print("Miss write loadState, ret val:");
  mqtt_publish_s("solar", "sleep");
  // power down MAX485_DE
  digitalWrite(MAX485_RE, 0); // low active
  // DeepSleep n microseconds
  Serial.print("\nDeepSleep for ");
  Serial.print(sleepSeconds);
  Serial.println(" Seconds");
  ESP.deepSleep(sleepSeconds * 1000000);
void mqtt_publish_s( char* topic , char* msg ) {
  Serial.print(topic);
  Serial.print(": ");
  Serial.println(msg);
  mqtt_client.publish(topic, msg);
void mqtt_publish_f( char* topic , float value  ) {
  Serial.print(": ");
  snprintf (mqtt_msg, 64, "%7.3f", value);
  Serial.println(mqtt_msg);
  mqtt_client.publish(topic, mqtt_msg);
void mqtt_publish_i( char* topic , int value  ) {
  Serial.print(": ");
  snprintf (mqtt_msg, 64, " %d", value);
  digitalWrite(MAX485_RE, 1);
void mqtt_reconnect() {
  // Loop until we're reconnected
  while (!mqtt_client.connected()) {
    Serial.print("Attempting MQTT connection...");
    // Create a client ID
    String clientId = "EpEver Solar Monitor";
    // Attempt to connect
    if (mqtt_client.connect(clientId.c_str())) {
      Serial.println("connected");
      // Once connected, publish an announcement...
      mqtt_client.publish("solar", "online");
      do_update = 1;
      // ... and resubscribe
      mqtt_client.subscribe("solar/load/control");
      mqtt_client.subscribe("solar/setting/sleep");
      Serial.print("failed, rc=");
      Serial.print(mqtt_client.state());
      Serial.println(" try again in 5 seconds");
      // Wait 5 seconds before retrying
      delay(5000);
// control load on / off here, setting sleep duration
void mqtt_callback(char* topic, byte* payload, unsigned int length) {
  Serial.print("Message arrived [");
  Serial.print("] ");
  for (int i = 0; i < length; i++) {
    Serial.print((char)payload[i]);
  payload[length] = '\0';
  // solar/load/control
  if ( strncmp( topic, "solar/load/control", strlen("solar/load/control") ) == 0 ) {
    // Switch - but i can't seem to switch a coil directly here ?!?
    if ( strncmp( (char *) payload , "1", 1) == 0 || strcmp( (char *) payload , "on") == 0  ) {
      loadState = true;
      do_update = 1;
      switch_load = 1;
    if ( strncmp( (char *) payload , "0", 1) == 0 || strcmp( (char *) payload , "off") == 0  ) {
      loadState = false;
      do_update = 1;
      switch_load = 1;
Sorry that's for the ESP2866 version,
This normal one
    to the datasheet.
    Connections:
        MAX485         NodeMCU
            DI              TX
            DE              D2
            RE              D1
            RO              RX
            VCC             3V3 !!!
            GND             GND
        pin8  GND          brn                           GND
        pin6  RS-485-A     grn               A
        pin4  RS-485-B     blu               B
#define LED             4  // for flashing the led - LOW active!
#define MAX485_DE       2  // data or
#define MAX485_RE       1  //      recv enable
char buf[256];
// dummy * 4
void setup(){
    // say hello
    while (!Serial) { ; }
    // modbus callbacks
void loop(){
  uint8_t i, result;
    // live data
  union {
    struct {
      int16_t  pV;
      int16_t  pI;
      int32_t  pP;
      int16_t  bV;
      int16_t  bI;
      int32_t  bP;
      uint16_t  dummy[4];
      int16_t  lV;
      int16_t  lI;
      int32_t  lP;
    } l;
    uint16_t  buf[16];
  } live;
  // statistics
  union {
    struct {
      // 4*1 = 4
      uint16_t  pVmax;
      uint16_t  pVmin;
      uint16_t  bVmax;
      uint16_t  bVmin;
      // 4*2 = 8
      // 4*2 = 8
      // 1*2 = 2
    } s;
    uint16_t  buf[22];
  } stats;
  // battery status
  struct {
  } status_batt ;
    "Normal",
    "Overvolt",
    "Fault"
    "Normal",
    "Over WarnTemp",
    "Below WarnTemp"
  //  "Normal",
    "Off",
    "Float",
    "Boost",
    "Equlization"
  delay(200);
 // read LIVE-Data
  delay(200);
    for(i=0; i< LIVE_DATA_CNT ;i++) live.buf[i] = node.getResponseBuffer(i);
  // Statistical Data
  delay(200);
    for(i=0; i< STATISTICS_CNT ;i++)  stats.buf[i] = node.getResponseBuffer(i);
  } else  {
  // Battery SOC
  delay(200);
  } else  {
  delay(200);
  } else  {
  delay(200);
  } else  {
  delay(200);
    //Serial.println();
  } else  {
//  Serial.print("\n\nTime:  20%02d-%02d-%02d   %02d:%02d:%02d   \n",  rtc.r.y , rtc.r.M , rtc.r.d , rtc.r.h , rtc.r.m , rtc.r.s  );
 // Serial.print(  "\nLive-Data:           Volt        Amp       Watt  ");
//  Serial.printf( "\n  Panel:            %7.3f    %7.3f    %7.3f ",  live.l.pV/100.f ,  live.l.pI/100.f ,  live.l.pP/100.0f );
//  Serial.printf( "\n  Batt:             %7.3f    %7.3f    %7.3f ",  live.l.bV/100.f ,  live.l.bI/100.f ,  live.l.bP/100.0f );
//  Serial.printf( "\n  Load:             %7.3f    %7.3f    %7.3f ",  live.l.lV/100.f ,  live.l.lI/100.f ,  live.l.lP/100.0f );
  Serial.print( "\n  Battery Current:  %7.3f  A ",      batteryCurrent/100.f  );
  Serial.print( "\n  Battery SOC:      %7.0f  %% ",     batterySOC/1.0f  );
  Serial.print "\n  Load Switch:          %s   ",     (loadState==1?" On":"Off") );
  Serial.print( "\n  Panel:       min: %7.3f   max: %7.3f   V", stats.s.pVmin/100.f  , stats.s.pVmax/100.f  );
  Serial.print( "\n  Battery:     min: %7.3f   max: %7.3f   V", stats.s.bVmin /100.f , stats.s.bVmax/100.f);
  Serial.print( "\n  Consumed:    day: %7.3f   mon: %7.3f   year: %7.3f  total: %7.3f   kWh",
      stats.s.consEnerDay/100.f  ,stats.s.consEnerMon/100.f  ,stats.s.consEnerYear/100.f  ,stats.s.consEnerTotal/100.f   );
  Serial.print( "\n  Generated:   day: %7.3f   mon: %7.3f   year: %7.3f  total: %7.3f   kWh",
      stats.s.genEnerDay/100.f   ,stats.s.genEnerMon/100.f   ,stats.s.genEnerYear/100.f   ,stats.s.genEnerTotal/100.f  );
  Serial.print( "\n  CO2-Reduction:    %7.3f  t ",      stats.s.c02Reduction/100.f  );
  Serial.print( "\n    batt.volt:         %s   ",     batt_volt_status[status_batt.volt] );
  Serial.print( "\n    batt.temp:         %s   ",     batt_temp_status[status_batt.temp] );
  Serial.print( "\n    charger.charging:  %s   ",     charger_charging_status[ charger_mode] );
  if( switch_load == 1 ){
    switch_load = 0;
    Serial.println( (loadState?"On":"Off") );
    delay(200);
  digitalWrite(LED,LOW);
  digitalWrite(LED,HIGH);
Thank you very much for your help @Steveiboy @blh64. I was able to extract the data from the charge controller
#define MAX485_DE      2
ModbusMaster node;
bool state = true;
  uint8_t result;
  uint16_t data[6];
  result = node.readDiscreteInputs(0x3100, 5);
    Serial.print("Array Power(W): ");
    Serial.println((node.getResponseBuffer(0x02 |
                   node.getResponseBuffer(0x03) << 16) / 100.0f);
  result = node.readInputRegisters(0x3200, 3);
    Serial.print(node.getResponseBuffer(0x00), HEX);
    Serial.print("\t");
    if ( temp == 0x00 ) {
      Serial.print("Normal (Temp)");
    Serial.print("\t");
      Serial.println("Normal (Voltage)");
      Serial.println("Over Voltage.");
      Serial.println("Under Voltage");
      Serial.println("Fault (Voltage)");
    Serial.print(node.getResponseBuffer(0x01), HEX);
    Serial.print("\t");
    uint16_t CharStatus = node.getResponseBuffer(0x01);
    uint8_t Charging = (CharStatus & 0x000C) >> 2; //D3-D2 shifted down
    // Serial.print(Charging,BIN);
    if ( Charging == 0x00 ) {
      Serial.println("No charging");
    } else if ( Charging == 0x01 ) {
      Serial.println("Float");
    } else if ( Charging == 0x02 ) {
      Serial.println("Boost");
    else if ( Charging == 0x03 ) {
      Serial.println("Equalization");
    Serial.print("\t");
    uint16_t ArrStatus = node.getResponseBuffer(0x01);
    uint8_t Arr = (ArrStatus & 0xC000) >> 14; //D15-D14 shifted down
    if ( Arr == 0x00 ) {
      Serial.println("Normal");
    } else if ( Arr == 0x01 ) {
      Serial.println("No input power connected");
    } else if ( Arr == 0x02 ) {
      Serial.println("Higher input voltage");
    else if ( Arr == 0x03 ) {
      Serial.println("Input voltage error");
    Serial.print(node.getResponseBuffer(0x02), HEX);
    Serial.print("\t");
    uint16_t LoadStatus = node.getResponseBuffer(0x02);
    uint8_t Load = (LoadStatus & 0x3000) >> 12; //D3-12 shifted down
    if ( Load == 0x00 ) {
      Serial.println("Light load");
    } else if ( Load == 0x01 ) {
      Serial.println("Moderate");
    } else if ( Load == 0x02 ) {
      Serial.println("Rated");
    else if ( Load == 0x03 ) {
      Serial.println("Overload");
    Serial.print("\n");
    uint16_t DeviceStatus = node.getResponseBuffer(0x00);
    if ( DeviceStatus & 0x8000 ) {
      Serial.println("Wrong identification for rated voltage");
  result = node.readDiscreteInputs(0x2000, 1);
    if ( DeviceStatus & 0x0040 ) {
      Serial.println("The temperature inside the controller is higher than the over-temperature protection point");
    else {
That can't be correct. Looks like your parenthesis are messed up. You need to fetch individual values from .getResponseBuffer() and then shift/combine them.
    Serial.println((node.getResponseBuffer(0x02) |
Thanks for the correction @blh64
