Hi there,
I am struggling with the Webserver on this board. I used from the docs page the item “ Host a Web Server on the Arduino MKR Wifi 1010”. I used the code also from this item. In the serial monitor I see that the board is connected to my wifi network and got a ip address. So far so good. But when i go to the server ip address i get the message “ ERR_ADDRESS_UNREACHABLE”. Als a ping to this address gives nothing back. I tried several browers, shut down the firewall closed antivirus etc. No results.
Anyone a suggestion what is going on here. Thanks for helping this old man.
Here is the code from the docs site.
#include <WiFiNINA.h>
char ssid[] = ""; // your network SSID (name) between the " "
char pass[] = ""; // your network password between the " "
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS; //connection status
WiFiServer server(80); //server socket
WiFiClient client = server.available();
int ledPin = 2;
pinMode(ledPin, OUTPUT);
while (!Serial);
enable_WiFi();
connect_WiFi();
server.begin();
printWifiStatus();
if (client) {
printWEB();
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your board's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
Serial.print("To see this page in action, open a browser to http://");
Serial.println(ip);
void enable_WiFi() {
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < "1.0.0") {
Serial.println("Please upgrade the firmware");
void connect_WiFi() {
// attempt to connect to Wifi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
void printWEB() {
if (client) { // if you get a client,
Serial.println("new client"); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
Serial.write(c); // print it out the serial monitor
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println();
//create the buttons
client.print("Click <a href=\"/H\">here</a> turn the LED on<br>");
client.print("Click <a href=\"/L\">here</a> turn the LED off<br><br>");
int randomReading = analogRead(A1);
client.print("Random reading from analog pin: ");
client.print(randomReading);
// The HTTP response ends with another blank line:
client.println();
// break out of the while loop:
else { // if you got a newline, then clear currentLine:
currentLine = "";
else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
if (currentLine.endsWith("GET /H")) {
digitalWrite(ledPin, HIGH);
if (currentLine.endsWith("GET /L")) {
digitalWrite(ledPin, LOW);
// close the connection:
client.stop();
Serial.println("client disconnected");
