Error cannot call member function without object
Hi every one
Hereafter the error message that I do not understand.
Someone could help me please ?
Thanks in advance for any comment and/or correction.
There is the error message and the relative code to this error :
The error during compilation :
Packet.cpp:140:45: error: cannot call member function 'void I2C_Command::I2C_SendData(int, int, int*) volatile' without object
I2C_Command::I2C_SendData(2, 1, *dataToI2C[]) volatile ;
The code : (there are 3 parts)
1st part - In I2C_Command .h file :
#include "Arduino.h"
#ifndef I2C_Command_h
#define I2C_Command_h
struct I2C_Command {
  static void I2C_Scan();
  void I2C_SendData(int, int, int[]) ;
  void I2C_Request(int, int, int[]);
}; // I2C_Command
#endif
2nd part - In I2C_Command.cpp file :
//  Library
//#include <Wire.h>
#include "I2C_Command.h"
 void I2C_Command::I2C_SendData(int I2Cadr, int I2Clenght, int I2Cdata[]) {
  Wire.beginTransmission(I2Cadr); // transmit to device #2
  for (int i = 0; i <= I2Clenght; ++i) {
    Wire.write(I2Cdata[i]);   // sends one byte
  Wire.endTransmission();    // stop transmitting
  Serial.println(I2Clenght + "I2C sent");
    Serial.print(I2Cdata[i]);   // sends one byte
void I2C_Command::I2C_Request(int I2Cadr, int I2Clenght, int I2Cdata[]) {
  Wire.requestFrom(I2Cadr, I2Clenght);    // request int from slave device #8
  for (int i = 0; i < I2Clenght; ++i) {
    while (Wire.available()) { // slave may send less than requested
      I2Cdata[i] = Wire.read();
3rd part - In Packet.cpp file :
#include "Packet.h"
void PacketList::set(char *s) volatile {
  byte b[5];                      // save space for checksum byte
  int nR;
  int tC;
  int tS;
  int tD;
  int dataToI2C[20];
  if (sscanf(s, "%d %d %d %d", &nR, &tC, &tS, &tD) != 4)
    return;
  dataToI2C[0] = '1';
  I2C_Command::I2C_SendData(2, 1, dataToI2C) ;
} // PacketList::set()
You've already identified the problem in the title of this thread. You can't call a struct/class member function without specifying an object of that struct/class. What is your question?
Thank's for your remark.
my question is : how can I modified my code to have a success during compilation ?
Since Packet.h was not provided, I guessed what it might contain. Then I made the following changes (see comments).
#pragma once
#include "I2C_Command.h"   // Moved from "Packet.cpp".
struct PacketList {
  I2C_Command i2cCommand;  // Added `I2C_Command` object.
  void set(char*) volatile;
Now, if we change the following line,
to:
i2cCommand.I2C_SendData(2, 1, dataToI2C);
The sketch compiles (but it may still be non functional).
[edit]
Alternatively, you could have declared I2C_SendData static. Then your original syntax should work (but this only works if you have no plans to add state to your structs).
I have in Packet.h only :
#ifndef Packet_h
#define Packet_h
struct PacketList{
  void set(char *) volatile;
Thanks a lot for your contribution.
but like we say "sleep on it" ...
so to resolve this problem, I changed the program structure ...
The old program structure was
Main
Call PacketList::set(char *s);
Packet.h
Struct PacketList {
Void set(char *) volatile;
Packet.cpp
#include "Packet.h"
I2C_Command.h
I2C_Command.cpp
The new program structure :
Main
Call I2C_Command::set(char *s);
Packet.h
Struct PacketList {
Packet.cpp
#include "Packet.h"
I2C_Command.h
  void I2C_Set(char *) volatile ;
  void I2C_SendData(int, int, int[]) volatile ;
I2C_Command.cpp
 void I2C_Command::I2C_Set(char *s) volatile {
  dataToI2C[0] = '1';
  I2C_Command::I2C_SendData(2, 1, dataToI2C) volatile ;
 void I2C_Command::I2C_SendData(int I2Cadr, int I2Clenght, int I2Cdata[]) volatile {
and now it's OK :smile: :smile: :smile:
