Hi, I am trying to write library files for communication between I2C Master and Slave. In the Master library I get the following error:
i2c_master.cpp:71:42: error: cannot declare member function 'static void i2c_master::buttonPressed()' to have static linkage [-fpermissive]
static void i2c_master::buttonPressed ()
I have declared butonPressed as static void function, the member used is also of static int type, and the function is called in attachinterrupt(). I dont understand the error. Can anyone help me to figure it out. My .cpp file is as below:
#include "i2c_master.h" #include "Arduino.h"
CLASS * I 2 C M A S T E R
i2c_master::i2c_master(int SDA_PIN, int SCL_PIN, int INTR, int LED, int buttonPushCounter, int I2C_SLAVE_ADDR)
_pin_a = SDA_PIN;
_pin_b = SCL_PIN;
_pin_c = INTR;
_pin_d = LED;
_val_a = buttonPushCounter;
_addr = I2C_SLAVE_ADDR;
pinMode(_pin_a, OUTPUT);
pinMode(_pin_b, OUTPUT);
pinMode(_pin_c, OUTPUT);
pinMode(_pin_d, OUTPUT);
void i2c_master::PinSetup() {
Wire.begin(_pin_a, _pin_b); // join i2c bus
attachInterrupt (_pin_c , i2c_master::buttonPressed, CHANGE);
void i2c_master::sequence() {
static unsigned long lastReadMillis = 0;
if (millis() - lastReadMillis > 1000) {
if (_val_a > 0){
Serial.println(requestI2C());
if(requestI2C() == 'H')
digitalWrite(_pin_d, HIGH);
digitalWrite(_pin_d, LOW);
lastReadMillis = millis();
Serial.println("test response");
_val_a++;
char i2c_master::requestI2C()
WireSlaveRequest slaveReq(Wire, _addr, MAX_SLAVE_RESPONSE_LENGTH);
slaveReq.setRetryDelay(5);
bool success = slaveReq.request();
if (success) {
while (1 < slaveReq.available()) { // loop through all but the last byte
char c = slaveReq.read(); // receive byte as a character
Serial.print(c); // print the character
return c;
The class static function doesn't know which object you mean so it can't increment '_val_a'. One way to work around that is to have a class static pointer to the object: static i2c_master *Instance;
Then initialize it to "this" in the constructor: Instance = this;
And then the static buttonPressed() function can reference the variable with: Instance->_val_a++;
Thank you very much for the detailed solution. But however I'm a little confused as I am new to Arduino and C++, What does Instance = this; mean? and Do I need to initialize it within my class i2c_master or in PinSetup()?
It means "Set the class static pointer 'Instance' to the object instance being created by this constructor." The reserved word 'this' used inside an object method means 'the current instance'.
Like I said, in the constructor: i2c_master::i2c_master()
