Please advise regarding the following error message:
Arduino: 1.8.3 (Linux), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Archiving built core (caching) in: /tmp/arduino_cache_520958/core/core_arduino_avr_mega_cpu_atmega2560_12330cb3e710267cdccf791b88a3e42c.a
Sketch uses 1462 bytes (0%) of program storage space. Maximum is 253952 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 8183 bytes for local variables. Maximum is 8192 bytes.
/home/brianeo/Downloads/arduino-1.8.3/hardware/tools/avr/bin/avrdude -C/home/brianeo/Downloads/arduino-1.8.3/hardware/tools/avr/etc/avrdude.conf -v -patmega2560 -cwiring -P/dev/ttyACM0 -b115200 -D -Uflash:w:/tmp/arduino_build_227785/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 11:00:16
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/home/brianeo/Downloads/arduino-1.8.3/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/home/brianeo/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM0
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude: ser_open(): can't open device "/dev/ttyACM0": Permission denied
ioctl("TIOCMGET"): Inappropriate ioctl for device
avrdude: ser_send(): write error: Bad file descriptor
avrdude: stk500_send(): failed to send command to serial port
avrdude: stk500v2_ReceiveMessage(): timeout
(cut)
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
the selected serial port avrdude: stk500_send(): failed to send command to serial port
does not exist or your board is not connected
option enabled in File -> Preferences.
