Error compiling Esp32 Wrover Board
Hello, i recently bought a esp32 cam board and when i tried to upload camerawebserver code i got a error message. Any idea how can i solve it?
Arduino: 1.8.15 (Windows 8.1), Board: "ESP32 Wrover Module, Huge APP (3MB No OTA/1MB SPIFFS), QIO, 40MHz, 115200, None"
C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Users\USER\AppData\Local\Arduino15\packages -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Users\USER\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\USER\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32wrover:PartitionScheme=huge_app,FlashMode=qio,FlashFreq=40,UploadSpeed=115200,DebugLevel=none -vid-pid=0403_6001 -ide-version=10815 -build-path C:\Users\USER\AppData\Local\Temp\arduino_build_462968 -warnings=none -build-cache C:\Users\USER\AppData\Local\Temp\arduino_cache_171952 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\USER\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\USER\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\USER\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\USER\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\USER\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\USER\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -verbose C:\Users\USER\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.0\libraries\ESP32\examples\Camera\CameraWebServer\CameraWebServer.ino
C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Users\USER\AppData\Local\Arduino15\packages -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Users\USER\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\USER\Documents\Arduino\libraries -fqbn=esp32:esp32:esp32wrover:PartitionScheme=huge_app,FlashMode=qio,FlashFreq=40,UploadSpeed=115200,DebugLevel=none -vid-pid=0403_6001 -ide-version=10815 -build-path C:\Users\USER\AppData\Local\Temp\arduino_build_462968 -warnings=none -build-cache C:\Users\USER\AppData\Local\Temp\arduino_cache_171952 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-esp32-elf-gcc.path=C:\Users\USER\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.xtensa-esp32-elf-gcc-1.22.0-97-gc752ad5-5.2.0.path=C:\Users\USER\AppData\Local\Arduino15\packages\esp32\tools\xtensa-esp32-elf-gcc\1.22.0-97-gc752ad5-5.2.0 -prefs=runtime.tools.mkspiffs.path=C:\Users\USER\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.mkspiffs-0.2.3.path=C:\Users\USER\AppData\Local\Arduino15\packages\esp32\tools\mkspiffs\0.2.3 -prefs=runtime.tools.esptool_py.path=C:\Users\USER\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -prefs=runtime.tools.esptool_py-3.0.0.path=C:\Users\USER\AppData\Local\Arduino15\packages\esp32\tools\esptool_py\3.0.0 -verbose C:\Users\USER\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.0\libraries\ESP32\examples\Camera\CameraWebServer\CameraWebServer.ino
Using board 'esp32wrover' from platform in folder: C:\Users\USER\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5
Using core 'esp32' from platform in folder: C:\Users\USER\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.5
cmd /c if exist "C:\Users\USER\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.0\libraries\ESP32\examples\Camera\CameraWebServer\partitions.csv" copy /y "C:\Users\USER\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.0\libraries\ESP32\examples\Camera\CameraWebServer\partitions.csv" "C:\Users\USER\AppData\Local\Temp\arduino_build_462968\partitions.csv"
exec: "cmd": executable file not found in %PATH%
Error compiling for board ESP32 Wrover Module.
Hi, @aryanyadav2003
Welcome to the forum.
To add code please click this link;
We need to see your code please.
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
Yes indeed, lets see the code.
It has nothing to do with the code. This is a failure of the build system:
You will get this if the location containing the Windows command line interpreter cmd (usually C:\Windows\System32) is not in your system path.
That is an unusual circumstance that would probably result from a non-standard system configuration or security restrictions on the user account you are running the IDE from.
Thanku
The path in system variables is "ComSpec: C:\windows\system32\cmd.exe" where or what else would be required, or is there another path not known about? This is very baffling as it is in system variables, but still not found. The system is standard for win8.1 pro, and no restrictiions can be found.
