I am testing the code:
#include <ESPAsyncWebServer.h>
#include "esp_camera.h"
#include "camera_index.h"
#include "Arduino.h"
#include "fd_forward.h"
#include <SPI.h>
#include <TFT_eSPI.h>
TFT_eSPI tft = TFT_eSPI();
#include <TFT_eFEX.h>
TFT_eFEX fex = TFT_eFEX(&tft);
AsyncWebServer webserver(80);
AsyncWebSocket ws("/ws");
const char* ssid = "NSA";
const char* password = "orange";
String filelist;
camera_fb_t * fb = NULL;
String incoming;
long current_millis;
long last_capture_millis = 0;
static esp_err_t cam_err;
static esp_err_t card_err;
char strftime_buf[64];
long file_number = 0;
// CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
static inline mtmn_config_t app_mtmn_config()
mtmn_config_t mtmn_config = {0};
mtmn_config.type = FAST;
mtmn_config.min_face = 60; // 80 default
mtmn_config.pyramid = 0.707;
mtmn_config.pyramid_times = 4;
mtmn_config.p_threshold.score = 0.6;
mtmn_config.p_threshold.nms = 0.7;
mtmn_config.p_threshold.candidate_number = 20;
mtmn_config.r_threshold.score = 0.7;
mtmn_config.r_threshold.nms = 0.7;
mtmn_config.r_threshold.candidate_number = 10;
mtmn_config.o_threshold.score = 0.7;
mtmn_config.o_threshold.nms = 0.7;
mtmn_config.o_threshold.candidate_number = 1;
return mtmn_config;
mtmn_config_t mtmn_config = app_mtmn_config();
pinMode(4, OUTPUT);// initialize io4 as an output for LED flash.
digitalWrite(4, LOW); // flash off/
init_wifi();
tft.begin();
tft.setRotation(3); // 0 & 2 Portrait. 1 & 3 landscape
tft.fillScreen(TFT_BLACK);
tft.setCursor(35,55);
tft.setTextColor(TFT_WHITE);
tft.setTextSize(1);
tft.println(WiFi.localIP());
delay(5000);
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
//init with high specs to pre-allocate larger buffers
if (psramFound()) {
config.frame_size = FRAMESIZE_UXGA;
config.jpeg_quality = 10;
config.fb_count = 2;
config.frame_size = FRAMESIZE_SVGA;
config.jpeg_quality = 12;
config.fb_count = 1;
// camera init
cam_err = esp_camera_init(&config);
if (cam_err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", cam_err);
return;
sensor_t * s = esp_camera_sensor_get();
s->set_framesize(s, FRAMESIZE_QQVGA);
s->set_vflip(s, 1);
ws.onEvent(onEvent);
webserver.addHandler(&ws);
webserver.on("/", HTTP_GET, [](AsyncWebServerRequest * request) {
Serial.print("Sending interface...");
AsyncWebServerResponse *response = request->beginResponse_P(200, "text/html", index_ov2640_html_gz, sizeof(index_ov2640_html_gz));
response->addHeader("Content-Encoding", "gzip");
request->send(response);
webserver.on("/image", HTTP_GET, [](AsyncWebServerRequest * request) {
Serial.println("requesting image from SPIFFS");
if (request->hasParam("id")) {
AsyncWebParameter* p = request->getParam("id");
Serial.printf("GET[%s]: %s\n", p->name().c_str(), p->value().c_str());
String imagefile = p->value();
imagefile = imagefile.substring(4); // remove img_
request->send(SPIFFS, "/" + imagefile);
webserver.begin();
if (!SPIFFS.begin()) {
Serial.println("SPIFFS initialisation failed!");
SPIFFS.begin(true);// Formats SPIFFS - could lose data https://github.com/espressif/arduino-esp32/issues/638
Serial.println("\r\nInitialisation done.");
fex.listSPIFFS(); // Lists the files so you can see what is in the SPIFFS
bool init_wifi()
WiFi.begin(ssid, password);
Serial.print(".");
Serial.print("Ready! Use 'http://");
Serial.print(WiFi.localIP());
Serial.println("' to connect");
return true;
void onEvent(AsyncWebSocket * server, AsyncWebSocketClient * client, AwsEventType type, void * arg, uint8_t *data, size_t len)
// String incoming = String((char *)data); No idea why.. gave extra characters in data for short names.
// so ....
for (size_t i = 0; i < len; i++) {
incoming += (char)(data[i]);
Serial.println(incoming);
if (incoming.substring(0, 7) == "delete:") {
String deletefile = incoming.substring(7);
incoming = "";
int fromUnderscore = deletefile.lastIndexOf('_') + 1;
int untilDot = deletefile.lastIndexOf('.');
String fileId = deletefile.substring(fromUnderscore, untilDot);
Serial.println(fileId);
Serial.println("image delete");
SPIFFS.remove("/selfie_t_" + fileId + ".jpg");
SPIFFS.remove("/selfie_f_" + fileId + ".jpg");
client->text("removed:" + deletefile); // file deleted. request browser update
Serial.println("sending list");
client->text(filelist_spiffs());
String filelist_spiffs()
filelist = "";
fs::File root = SPIFFS.open("/");
fs::File file = root.openNextFile();
while (file) {
String fileName = file.name();
// Serial.println(fileName);
filelist = filelist + fileName;
Serial.println(filelist);
return filelist;
void latestFileSPIFFS()
while (file) {
int fromUnderscore = fileName.lastIndexOf('_') + 1;
int untilDot = fileName.lastIndexOf('.');
String fileId = fileName.substring(fromUnderscore, untilDot);
file_number = max(file_number, fileId.toInt()); // replace filenumber if fileId is higher
bool face_detected()
fb = esp_camera_fb_get();
dl_matrix3du_t *image_matrix = NULL;
image_matrix = dl_matrix3du_alloc(1, fb->width, fb->height, 3);
fmt2rgb888(fb->buf, fb->len, fb->format, image_matrix->item);
box_array_t *net_boxes = NULL;
net_boxes = face_detect(image_matrix, &mtmn_config);
if (net_boxes) {
free(net_boxes->score);
free(net_boxes->box);
free(net_boxes->landmark);
free(net_boxes);
dl_matrix3du_free(image_matrix);
Serial.println("face detected");
esp_camera_fb_return(fb);
fb = NULL;
return true;
fb = NULL;
return false;
void smile_for_the_camera()
long timer_millis = millis();
while (millis() - timer_millis < 500) {
if (!face_detected()) { // if face disappears stop
Serial.println("face not detected");
return;
digitalWrite(4, HIGH); // flash on
fex.drawJpgFile(SPIFFS, "/_count3.jpg", 0, 0);
delay(400);
fex.drawJpgFile(SPIFFS, "/_count2.jpg", 0, 0);
delay(400);
fex.drawJpgFile(SPIFFS, "/_count1.jpg", 0, 0);
delay(400);
take_photo();
static esp_err_t take_photo()
latestFileSPIFFS(); // next file number
file_number++;
Serial.println(file_number);
Serial.println("Starting thumb capture: ");
fex.drawJpg((const uint8_t*)fb->buf, fb->len, 0, 6);
//save thumb
char *thumb_filename = (char*)malloc(23 + sizeof(file_number));
sprintf(thumb_filename, "/spiffs/selfie_t_%d.jpg", file_number);
Serial.println("Opening file: ");
FILE *thumbnail = fopen(thumb_filename, "w");
if (thumbnail != NULL) {
size_t err = fwrite(fb->buf, 1, fb->len, thumbnail);
Serial.printf("File saved: %s\n", thumb_filename);
Serial.println("Could not open file");
fclose(thumbnail);
fb = NULL;
free(thumb_filename);
Serial.println("Starting main capture: ");
s->set_framesize(s, FRAMESIZE_SVGA);
char *full_filename = (char*)malloc(23 + sizeof(file_number));
sprintf(full_filename, "/spiffs/selfie_f_%d.jpg", file_number);
FILE *fullres = fopen(full_filename, "w");
if (fullres != NULL) {
size_t err = fwrite(fb->buf, 1, fb->len, fullres);
Serial.printf("File saved: %s\n", full_filename);
fclose(fullres);
fb = NULL;
free(full_filename);
char *addtobrowser = (char*)malloc(24 + sizeof(file_number));
sprintf(addtobrowser, "added:selfie_t_%d.jpg", file_number);
ws.textAll((char*)addtobrowser);// file added. request browser update
if (face_detected()) {
smile_for_the_camera();
fb = NULL;
and got the error:
Arduino: 1.8.13 (Windows 10), Board: "AI Thinker ESP32-CAM, 240MHz (WiFi/BT), QIO, 80MHz"
Multiple libraries were found for "WiFi.h"
In file included from C:\HUA\DIY\ESP32-CAM + TFT Screen + 3D Print - SelfieCam\esp32cam-selfiecam-master\esp32cam-selfiecam-master\SelfieCam\SelfieCam.ino:7:0:
Used: C:\Users\Xinzhou\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.6\libraries\WiFi
C:\Users\Xinzhou\Documents\Arduino\libraries\ESPAsyncWebServer-master\src/ESPAsyncWebServer.h:33:22: fatal error: AsyncTCP.h: No such file or directory
compilation terminated.
Not used: C:\Users\Xinzhou\Documents\Arduino\libraries\WiFiNINA-master
Not used: C:\Program Files (x86)\Arduino\libraries\WiFi
exit status 1
Error compiling for board AI Thinker ESP32-CAM.
option enabled in File -> Preferences.
Need help please.
Thanks
Adam
