Error compiling to board ai thinker
hello i am new to the forum so i dont know much, i have been working on a project in which i use a esp32 cam modudle but when i try to upload the code it says error compiling to board esp32. Here is my code:
#include <WiFi.h>
#include <WiFiAP.h>
#include <WiFiClient.h>
#include <WiFiGeneric.h>
#include <WiFiMulti.h>
#include <WiFiScan.h>
#include <WiFiServer.h>
#include <WiFiSTA.h>
#include <WiFiType.h>
#include <WiFiUdp.h>
#include "Arduino.h"
#include "esp_camera.h"
#include <base64.h>
#include "camera_pins.h"
// Select camera model
//#define CAMERA_MODEL_WROVER_KIT // Has PSRAM
//#define CAMERA_MODEL_ESP_EYE // Has PSRAM
//#define CAMERA_MODEL_M5STACK_PSRAM // Has PSRAM
//#define CAMERA_MODEL_M5STACK_WIDE  // Has PSRAM
#define CAMERA_MODEL_AI_THINKER // Has PSRAM
//#define CAMERA_MODEL_TTGO_T_JOURNAL // No PSRAM
const char* ssid = "Hope Cottage";
const char* password = "pereira07";
  Serial1.begin(19200);
  ESP_BT.begin; //Name of your Bluetooth Signal
  Serial1.println("Bluetooth Device is Ready to Pair");
  if (ESP_BT.available()) //Check if we receive anything from Bluetooth
  {Serial1.println("connected");
  Serial.setDebugOutput(true);
  camera_config_t config;
  config.ledc_channel = LEDC_CHANNEL_0;
  config.ledc_timer = LEDC_TIMER_0;
  config.pin_d0 = Y2_GPIO_NUM;
  config.pin_d1 = Y3_GPIO_NUM;
  config.pin_d2 = Y4_GPIO_NUM;
  config.pin_d3 = Y5_GPIO_NUM;
  config.pin_d4 = Y6_GPIO_NUM;
  config.pin_d5 = Y7_GPIO_NUM;
  config.pin_d6 = Y8_GPIO_NUM;
  config.pin_d7 = Y9_GPIO_NUM;
  config.pin_xclk = XCLK_GPIO_NUM;
  config.pin_pclk = PCLK_GPIO_NUM;
  config.pin_vsync = VSYNC_GPIO_NUM;
  config.pin_href = HREF_GPIO_NUM;
  config.pin_sscb_sda = SIOD_GPIO_NUM;
  config.pin_sscb_scl = SIOC_GPIO_NUM;
  config.pin_pwdn = PWDN_GPIO_NUM;
  config.pin_reset = RESET_GPIO_NUM;
  config.xclk_freq_hz = 20000000;
  config.pixel_format = PIXFORMAT_JPEG;
  // if PSRAM IC present, init with UXGA resolution and higher JPEG quality
  //                      for larger pre-allocated frame buffer.
  if(psramFound()){
    config.frame_size = FRAMESIZE_QVGA;
    config.jpeg_quality = 10;
    config.fb_count = 2;
    config.jpeg_quality = 12;
    config.fb_count = 1;
#if defined(CAMERA_MODEL_ESP_EYE)
  pinMode(13, INPUT_PULLUP);
  pinMode(14, INPUT_PULLUP);
#endif
  // camera init
  esp_err_t err = esp_camera_init(&config);
  if (err != ESP_OK) {
    Serial.printf("Camera init failed with error 0x%x", err);
    return;
#if defined(CAMERA_MODEL_M5STACK_WIDE)
  s->set_vflip(s, 1);
  s->set_hmirror(s, 1);
#endif
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  classifyImage();
void classifyImage() {
  // Capture picture
   camera_fb_t * fb = NULL;
   fb = esp_camera_fb_get();
   if(!fb) {
    Serial.println("Camera capture failed");
    return;
  size_t size = fb->len;
  String buffer = base64::encode((uint8_t *) fb->buf, fb->len);
String payload = "{\"inputs\": [{ \"data\": {\"image\": {\"base64\": \"" + buffer + "\"}}}]}";
buffer = "";
  // Uncomment this if you want to show the payload
  // Serial.println(payload);
  esp_camera_fb_return(fb);
  // Generic model
  String model_id = "aaa03c23b3724a16a56b629203edc62c";
  HTTPClient http;
  http.begin("https://api.clarifai.com/v2/models/" + model_id + "/outputs");
  http.addHeader("Content-Type", "application/json");
  http.addHeader("Authorization", "Key your_key");
  int response_code = http.POST(payload);
  // Parse the json response: Arduino assistant
const int jsonSize = JSON_ARRAY_SIZE(1) + JSON_ARRAY_SIZE(20) + 3*JSON_OBJECT_SIZE(1) + 6*JSON_OBJECT_SIZE(2) + JSON_OBJECT_SIZE(3) + 20*JSON_OBJECT_SIZE(4) + 2*JSON_OBJECT_SIZE(6);
DynamicJsonDocument doc(jsonSize);
for (int i=0; i < 10; i++) {
  const int name = doc["outputs"][0]["data"]["concepts"][i]["name"];
  const float p = doc["outputs"][0]["data"]["concepts"][i]["value"];
  Serial.println("=====================");
  Serial.print("Name:");
  Serial.println(name);
  Serial.print("Prob:");
  Serial.println(p);
and this is the error that i get:
Arduino: 1.8.19 (Windows 10), Board: "ESP32 Wrover Module, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), QIO, 40MHz, 921600, None"
In file included from C:\Users\USER\OneDrive\Documents\Arduino\sketch_jan22a\sketch_jan22a.ino:14:
C:\Users\USER\OneDrive\Documents\Arduino\libraries\esp32-cam-mjpeg-master/camera_pins.h:98:2: error: #error "Camera model not selected"
Multiple libraries were found for "WiFi.h"
Used: C:\Users\USER\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.2\libraries\WiFi
Not used: H:\Arduino\libraries\WiFi
exit status 1
Error compiling for board ESP32 Wrover Module.
option enabled in File -> Preferences.
Pls help me to solve this issue and thanks in advance
cheers
sumithPreformatted text
this error happens because this line of your sketch:
must be located above this line in the sketch:
i will try this thank you
i made the changes as you said but now it is showing this error:
C:\Users\USER\OneDrive\Documents\Arduino\sketch_jan22a\sketch_jan22a.ino: In function 'void classifyImage()':
sketch_jan22a:127:22: error: 'JSON_ARRAY_SIZE' was not declared in this scope
const int jsonSize = JSON_ARRAY_SIZE(1) + JSON_ARRAY_SIZE(20) + 3JSON_OBJECT_SIZE(1) + 6JSON_OBJECT_SIZE(2) + JSON_OBJECT_SIZE(3) + 20JSON_OBJECT_SIZE(4) + 2JSON_OBJECT_SIZE(6);
C:\Users\USER\OneDrive\Documents\Arduino\sketch_jan22a\sketch_jan22a.ino:127:22: note: suggested alternative: 'LWIP_ARRAYSIZE'
                  LWIP_ARRAYSIZE
sketch_jan22a:127:67: error: 'JSON_OBJECT_SIZE' was not declared in this scope
sketch_jan22a:128:1: error: 'DynamicJsonDocument' was not declared in this scope
sketch_jan22a:132:20: error: 'doc' was not declared in this scope
Multiple libraries were found for "WiFiClient.h"
exit status 1
pls help
I guess the compiler is correct as usual. It looks like you have some code for use with the ArduinoJson library, yet you don't appear to have an #include directive for that library.
I'm having trouble understanding how you got to this point.
Did you find this code somewhere on the Internet? If so, please post a link to it. That might provide the helpers here with valuable information that will allow them to more effectively provide you with assistance.
i took the code from this website: ESP32-CAM Image Classification using Machine Learning
and i have made some changes to the code:
#include <HTTPClient.h>
#include <WiFi.h>
#include <base64.h>
#include <ArduinoJson.h>
  if(psramFound()){
#endif
  // camera init
    return;
  s->set_vflip(s, 1);
#endif
    Serial.print(".");
  Serial.println("");
  classifyImage();
  // Capture picture
   if(!fb) {
    return;
buffer = "";
  // Generic model
  HTTPClient http;
 // const int jsonSize = JSON_ARRAY_SIZE(1) + JSON_ARRAY_SIZE(20) + 3*JSON_OBJECT_SIZE(1) + 6*JSON_OBJECT_SIZE(2) + JSON_OBJECT_SIZE(3) + 20*JSON_OBJECT_SIZE(4) + 2*JSON_OBJECT_SIZE(6);
 // DynamicJsonDocument doc(jsonSize);
  const int name = ["outputs"][0]["data"]["concepts"][i]["name"];
  const float p = ["outputs"][0]["data"]["concepts"][i]["value"];
  Serial.println(p);
My suggestion is to start by following the tutorial exactly and make sure it works correctly in an unmodified state. Even though it is not what you want for your own project, this will provide you with a known working baseline to build from.
After that, I recommend trying the ArduinoJson library out on its own in a simple sketch that uses the functionality of that library, but without yet adding in the complexity of the whole camera, image classification, etc. After installing that library, you will find some example sketches under the File > Examples > ArduinoJson menu in the Arduino IDE. These will demonstrate how to use the library, and there is additional documentation at the link in my previous reply you can use if there are things in the examples you don't understand. Make sure your simple standalone ArduinoJson sketch is working as expected and that you understand how it works.
Once you have done that, you will be well prepared to integrate the ArduinoJson code into your image classification sketch.
ok i will try that thank you
hello I got the solution to my problem thank you very much for helping me out all this time here is my new code:
#include <WiFi.h>
#include <base64.h>
//CAMERA_MODEL_AI_THINKER
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
if(psramFound()){
#endif
// camera init
return;
s->set_vflip(s, 1);
#endif
Serial.print(".");
Serial.println("");
Serial.print("WiFi connected to: ");
Serial.println(ssid);
classifyImage();
Serial.println("\nSleep….");
esp_deep_sleep_start();
void loop(){
String response;
// Capture picture
if(!fb) {
return;
Serial.println("Camera capture OK");
String payloadData = "{\"inputs\": [{ \"data\": {\"image\": {\"base64\": \"" + buffer + "\"}}}]}";
buffer = "";
Serial.println(payloadData);
// Generic model
HTTPClient http;
http.addHeader("Content-Type: ", "application/json");
http.addHeader("Authorization: ", "Key c7cde234537462388e256785c071231");
int httpResponseCode = http.POST(payloadData);
if(httpResponseCode>0){
Serial.print(httpResponseCode);
Serial.print(" Returned String: ");
response = http.getString();
Serial.println(response);
Serial.print("POST Error: ");
return;
const int jsonSize = 2*JSON_ARRAY_SIZE(0) + JSON_ARRAY_SIZE(1) + JSON_ARRAY_SIZE(20) + 4*JSON_OBJECT_SIZE(0) + 7*JSON_OBJECT_SIZE(1) + 5*JSON_OBJECT_SIZE(2) + JSON_OBJECT_SIZE(3) + 21*JSON_OBJECT_SIZE(4) + JSON_OBJECT_SIZE(5) + JSON_OBJECT_SIZE(6) + JSON_OBJECT_SIZE(7) + JSON_OBJECT_SIZE(18)+ 3251;
deserializeJson(doc, response);
//StaticJsonDocument (doc);
// Deserialize the JSON document
DeserializationError error = deserializeJson(doc, response);
// Test if parsing succeeds.
if (error) {
Serial.print(F("deserializeJson() failed: "));
Serial.println(error.f_str());
return;
String name = doc["outputs"][0]["data"]["concepts"][i]["name"];
String p = doc["outputs"][0]["data"]["concepts"][i]["value"];
Serial.println(p);
You are welcome. I'm glad you found the solution. Thanks for taking the time to post an update!
hey, I am trying out your code, but I am unable to understand how to do the classification of images on the Clarifai platform after I upload the code on the ESP 32 cam
