I keep getting "error compiling for board Arduino/Genuino Uno" when I try to do the initial task for communicating with Arduino Uno on setup.
I found one other topic that said I should go into Boards Manager and change Arduino AVR Boards from it's current installation to version 1.6.11, which I have done, but this has not made a difference.
The error that is coming up is:
Arduino: 1.8.10 (Mac OS X), Board: "Arduino/Genuino Uno"
dyld: Symbol not found: _unlinkat
Referenced from: /Applications/Arduino.app/Contents/Java/arduino-builder
Expected in: flat namespace
/Applications/Arduino.app/Contents/Java/arduino-builder returned 133
Error compiling for board Arduino/Genuino Uno.
option enabled in File -> Preferences.
Well how about helping us to help you.
Post your code and we might just stand a chance to find out where you have gone wrong.
Please use the </> icon on the top row far left and paste your code between the tage that pop up.
Blink
Turns an LED on for one second, then off for one second, repeatedly.
Most Arduinos have an on-board LED you can control. On the UNO, MEGA and ZERO
it is attached to digital pin 13, on MKR1000 on pin 6. LED_BUILTIN is set to
the correct LED pin independent of which board is used.
If you want to know what pin the on-board LED is connected to on your Arduino
model, check the Technical Specs of your board at:
https://www.arduino.cc/en/Main/Products
modified 8 May 2014
by Scott Fitzgerald
modified 2 Sep 2016
by Arturo Guadalupi
modified 8 Sep 2016
by Colby Newman
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/Blink
// the setup function runs once when you press reset or power the board
// initialize digital pin LED_BUILTIN as an output.
pinMode(LED_BUILTIN, OUTPUT);
// the loop function runs over and over again forever
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
