i have already uploaded this code to my arduino 2560 pro before 1year.
#include <RH_ASK.h>
#include <MIDI.h>
#include <Keypad.h>
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include<EEPROM.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
#define OLED_RESET -1 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
#define NUMFLAKES 10 // Number of snowflakes in the animation example -96,-97,-98,-99
#define KEY_UP -115
#define KEY_DOWN -113
#define KEY_ZERO -114
#define KEY_FIND_SCN -110
#define A -106
#define B -107
#define C -109
#define D -108
#define AA -96
#define BB -97
#define CC -98
#define DD -99
#define PATCH_UP -126
#define PATCH_DOWN -127
#define MONO -125
#define POLY -124
#define DRUM -116
#define KEY_128 -128
#define ORANGE_A -123
#define ORANGE_B -122
#define BLUE_A -121
#define BLUE_B -120
#define Bank_WriteA -119
#define Bank_WriteB -118
#define Key_Mode_Sw -117
char *data; // RF
const byte ROWS = 16;
const byte COLS = 10;
char keys[ROWS][COLS] = {
{1,2,3,4,5,6,7,8,9,10},
{11,12,13,14,15,16,17,18,19,20},
{21,22,23,24,25,26,27,28,29,30},
{31,32,33,34,35,36,37,38,39,40},
{41,42,43,44,45,46,47,48,49,50},
{51,52,53,54,55,56,57,58,59,60},
{61,62,63,64,65,66,67,68,69,70},
{71,72,73,74,75,76,77,78,79,80},
{81,82,83,84,85,86,87,88,89,90},
{91,92,93,94,95,96,97,98,99,100},
{101,102,103,104,105,106,107,108,109,110},
{111,112,113,114,115,116,117,118,119,120},
{121,122,123,124,125,126,127,128,129,130},
{131,132,133,134,135,136,137,138,139,140},
{141,142,143,144,145,146,147,148,149,150},
{151,152,153,154,155,156,157,158,159,160}
byte rowPins[ROWS] = {4,5,6,7,8,9,10,11,12,14,15,16,17,22,23,24};
byte colPins[COLS] = {32,33,34,35,36,37,38,39,40,41};
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
String msg;
MIDI_CREATE_DEFAULT_INSTANCE();
byte sysexArray[8] = {0xF0,0x7F,0x7F,0x04,0x04,0x00,50,0xF7}; // 0x28 // byte sysexArray[8] = {0xF0, 0x7F, 0x7F, 0x04, 0x04, 0x0, 0x50, 0xF7}; // MIDI.sendSysEx(8, sysexArray, true);
byte User[8] = {0xB0,0x00,0x55,0x90,0x20,0x00,0xC0,0x00};
RH_ASK driver(2000, 2, A1, 5); // ESP8266 or ESP32: do not use pin 11 rx_2 ,tx_A1
int UP = 0;
int DOWN = 0;
int Bank = 61;
String Key_Mode;
int PATCH = 0;
int SHIFT1 = 0;
long COUNT = 0;
int TRANS_KEY = 0;
int TRANS_KEY_Old = 0;
int KEY_SHIFT_MODE = 0;
int NOTE_NUMBER = 0;
int RAG_NOTE[15] = {49,51,52,54,56,57,59,61,63,64,66,68,69,71,73 };
int Bells_DRBR[22] = {61,63,64,66,68,69,71,73,75,76,78,80,81,83,85,87,88,90,92,93,95,97 }; // 22 notes
int SLIDE1 = 0;
int SLIDE1_OLD = 0;
int Last_Note = 0;
int Pitch_Value = 0;
byte C_Status = 0;
byte D_Status = 0;
byte Last_Gear = 0;
int A001=0,A002=0,A003=0,A004=0,A005=0,A006=0,A007=0,A008=0,A009=0,A010=0;
int A011=0,A012=0,A013=0,A014=0,A015=0,A016=0,A017=0,A018=0,A019=0,A020=0;
int A21=0,A22=0,A23=0,A24=0,A25=0,A26=0,A27=0,A28=0,A29=0,A30=0;
int A31=0,A32=0,A33=0,A34=0,A35=0,A36=0,A37=0,A38=0,A39=0,A40=0;
int A41=0,A42=0,A43=0,A44=0,A45=0,A46=0,A47=0,A48=0,A49=0,A50=0;
int A51=0,A52=0,A53=0,A54=0,A55=0,A56=0,A57=0,A58=0,A59=0,A60=0;
int A61=0,A62=0,A63=0,A64=0,A65=0,A66=0,A67=0,A68=0,A69=0,A70=0;
int A71=0,A72=0,A73=0,A74=0,A75=0,A76=0,A77=0,A78=0,A79=0,A80=0;
int A81=0,A82=0,A83=0,A84=0,A85=0,A86=0,A87=0,A88=0,A89=0,A90=0;
int A91=0,A92=0,A93=0,A94=0,A95=0,A96=0,A97=0,A98=0,A99=0,A100=0;
int A101=0,A102=0,A103=0,A104=0,A105=0,A106=0,A107=0,A108=0,A109=0,A110=0;
int A111=0,A112=0,A113=0,A114=0,A115=0,A116=0,A117=0,A118=0,A119=0,A120=0;
int A121=0,A122=0,A123=0,A124=0,A125=0,A126=0,A127=0,A128=0;
int data = 1;
if (!driver.init()) // RF
Serial.println("init failed"); // RF
Serial.begin(9600); // Debugging only
pinMode(LED_BUILTIN, OUTPUT);
kpd.setHoldTime(1000);
MIDI.begin(4);
MIDI.turnThruOff();
digitalWrite(13,LOW);
if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
display.display();
display.clearDisplay();
msg = "";
Key_Mode="Bank";
WEL_COME_SCN ();
A001 = EEPROM.read(1); A002 = EEPROM.read(2); A003 = EEPROM.read(3); A004 = EEPROM.read(4); A005 = EEPROM.read(5);
A006 = EEPROM.read(6); A007 = EEPROM.read(7); A008 = EEPROM.read(8); A009 = EEPROM.read(9); A010 = EEPROM.read(10); //-------------
A011 = EEPROM.read(11); A012 = EEPROM.read(12); A013 = EEPROM.read(13); A014 = EEPROM.read(14); A015 = EEPROM.read(15);
A016 = EEPROM.read(16); A017 = EEPROM.read(17); A018 = EEPROM.read(18); A019 = EEPROM.read(19); A020 = EEPROM.read(20); //-------------
A21 = EEPROM.read(21); A22 = EEPROM.read(22); A23 = EEPROM.read(23); A24 = EEPROM.read(24); A25 = EEPROM.read(25);
A26 = EEPROM.read(26); A27 = EEPROM.read(27); A28 = EEPROM.read(28); A29 = EEPROM.read(29); A30 = EEPROM.read(30); //-------------
A31 = EEPROM.read(31); A32 = EEPROM.read(32); A33 = EEPROM.read(33); A34 = EEPROM.read(34); A35 = EEPROM.read(35);
A36 = EEPROM.read(36); A37 = EEPROM.read(37); A38 = EEPROM.read(38); A39 = EEPROM.read(39); A40 = EEPROM.read(40); //-------------
A41 = EEPROM.read(41); A42 = EEPROM.read(42); A43 = EEPROM.read(43); A44 = EEPROM.read(44); A45 = EEPROM.read(45);
A46 = EEPROM.read(46); A47 = EEPROM.read(47); A48 = EEPROM.read(48); A49 = EEPROM.read(49); A50 = EEPROM.read(50); //-------------
A51 = EEPROM.read(51); A52 = EEPROM.read(52); A53 = EEPROM.read(53); A54 = EEPROM.read(54); A55 = EEPROM.read(55);
A56 = EEPROM.read(56); A57 = EEPROM.read(57); A58 = EEPROM.read(58); A59 = EEPROM.read(59); A60 = EEPROM.read(60); //-------------
A61 = EEPROM.read(61); A62 = EEPROM.read(62); A63 = EEPROM.read(63); A64 = EEPROM.read(64); A65 = EEPROM.read(65);
A66 = EEPROM.read(66); A67 = EEPROM.read(67); A68 = EEPROM.read(68); A69 = EEPROM.read(69); A70 = EEPROM.read(70); //-------------
A71 = EEPROM.read(71); A72 = EEPROM.read(72); A73 = EEPROM.read(73); A74 = EEPROM.read(74); A75 = EEPROM.read(75);
A76 = EEPROM.read(76); A77 = EEPROM.read(77); A78 = EEPROM.read(78); A79 = EEPROM.read(79); A80 = EEPROM.read(80); //-------------
A81 = EEPROM.read(81); A82 = EEPROM.read(82); A83 = EEPROM.read(83); A84 = EEPROM.read(84); A85 = EEPROM.read(85);
A86 = EEPROM.read(86); A87 = EEPROM.read(87); A88 = EEPROM.read(88); A89 = EEPROM.read(89); A90 = EEPROM.read(90); //-------------
A91 = EEPROM.read(91); A92 = EEPROM.read(92); A93 = EEPROM.read(93); A94 = EEPROM.read(94); A95 = EEPROM.read(95);
A96 = EEPROM.read(96); A97 = EEPROM.read(97); A98 = EEPROM.read(98); A99 = EEPROM.read(99); A100 = EEPROM.read(100); //-------------
A101 = EEPROM.read(101); A102 = EEPROM.read(102); A103 = EEPROM.read(103); A104 = EEPROM.read(104); A105 = EEPROM.read(105);
A106 = EEPROM.read(106); A107 = EEPROM.read(107); A108 = EEPROM.read(108); A109 = EEPROM.read(109); A110 = EEPROM.read(110); //-------------
A111 = EEPROM.read(111); A112 = EEPROM.read(112); A113 = EEPROM.read(113); A114 = EEPROM.read(114); A115 = EEPROM.read(115);
A116 = EEPROM.read(116); A117 = EEPROM.read(117); A118 = EEPROM.read(118); A119 = EEPROM.read(119); A120 = EEPROM.read(120); //-------------
A121 = EEPROM.read(121); A122 = EEPROM.read(122); A123 = EEPROM.read(123); A124 = EEPROM.read(124); A125 = EEPROM.read(125);
A126 = EEPROM.read(126); A127 = EEPROM.read(127); A128 = EEPROM.read(128);
void SCN (int gg) {
display.setTextSize(1); // Normal 1:1 pixel scale
display.setTextColor(SSD1306_WHITE); // Draw white text
display.setCursor(0,0); // Start at top-left corner
display.println(gg);
display.setCursor(50,0); // Start at top-left corner
display.println(msg);
display.setCursor(0,16); // Start at top-left corner
display.println(analogRead(A0));
display.display();
SLIDE1 = map(analogRead(0),10,1013,1,14);
if (analogRead(0)<10) { SLIDE1=0; }
if (analogRead(0)>1013) { SLIDE1=15; }
if (SLIDE1 !=SLIDE1_OLD) {
if ((SLIDE1>0) && (SLIDE1<15)) {
// Serial.println(SLIDE1);
// else if (SLIDE1 < 1) { Serial.println("All Note OFF after --00"); }
// else if (SLIDE1 > 14) { Serial.println("All Note OFF after --15"); }
// MAIN_SCN ();
// for (int c=1; c<11; c++) { MIDI.sendControlChange(94,(SLIDE1),c);} // (cc#,value,channel) TRANS_KEY , Last_Note ,
SLIDE1_OLD = SLIDE1;
if (kpd.getKeys())
for (int i=0; i<LIST_MAX; i++)
{ int mykey = kpd.key[i].kchar;
if (( kpd.key[i].stateChanged ) && (mykey < 128 ) && (mykey > 0 ) && (mykey != 13))
switch (kpd.key[i].kstate) {
case PRESSED:
if (Key_Mode == "Perform") { Perform_Mode (mykey); MAIN_SCN (); }
else if (Key_Mode == "Bank") { Bank_Mode (mykey); } MAIN_SCN ();
case RELEASED:
// if (Key_Mode == "Bank") { Bank_Mode_Released (mykey); } MAIN_SCN ();
if (( kpd.key[i].stateChanged ) && (mykey == KEY_128)) // --------------------------------------
{ switch (kpd.key[i].kstate) {
case PRESSED:
if (Key_Mode == "Perform") { PATCH = 127; MIDI.sendProgramChange(PATCH, 1); MAIN_SCN (); }
if (( kpd.key[i].stateChanged ) && (mykey == PATCH_UP)) // --------------------------------------
case PRESSED:
PATCH++; MIDI.sendProgramChange(PATCH, 1); MAIN_SCN ();
if (DOWN==1) {PATCH = PATCH+10; MIDI.sendProgramChange(PATCH, 1); MAIN_SCN (); } UP = 1;
case HOLD: break;
case RELEASED: UP = 0; break;
if (( kpd.key[i].stateChanged ) && (mykey == PATCH_DOWN)) // --------------------------------------
case PRESSED:
PATCH--; MIDI.sendProgramChange(PATCH, 1); MAIN_SCN ();
if (UP==1) {PATCH = PATCH-10; MIDI.sendProgramChange(PATCH, 1); MAIN_SCN (); } DOWN = 1;
case HOLD: break;
case RELEASED: DOWN = 0; break;
if (( kpd.key[i].stateChanged ) && (mykey == KEY_FIND_SCN)) // --------------------------------------
case PRESSED:
MIDI.sendProgramChange(10, 1);
FIND_SCN ();
KEY_SHIFT_MODE = 1;
case RELEASED:
KEY_SHIFT_MODE = 0;
All_Note_Off (); MIDI.sendProgramChange(PATCH, 1); MAIN_SCN ();
if (( kpd.key[i].stateChanged ) && (mykey == KEY_UP)) // --------------------------------------
case PRESSED:
TRANS_KEY++; MAIN_SCN ();
if (( kpd.key[i].stateChanged ) && (mykey == KEY_DOWN)) // --------------------------------------
case PRESSED:
TRANS_KEY--; MAIN_SCN (); data = 31;
if (( kpd.key[i].stateChanged ) && ((mykey == KEY_ZERO) || (mykey == -112) || (mykey == -111))) // --------------------------------------
case PRESSED:
TRANS_KEY = 0;
MAIN_SCN ();
if (( kpd.key[i].stateChanged ) && (mykey == A)) // --------------------------------------
case PRESSED:
data = 11; driver.send((uint8_t *)&data, sizeof(data)); driver.waitPacketSent();
case HOLD:
data = 13; driver.send((uint8_t *)&data, sizeof(data)); driver.waitPacketSent();
case RELEASED:
data = 12; driver.send((uint8_t *)&data, sizeof(data)); driver.waitPacketSent();
if (( kpd.key[i].stateChanged ) && (mykey == B)) // --------------------------------------
case PRESSED:
data = 21; driver.send((uint8_t *)&data, sizeof(data)); driver.waitPacketSent();
case HOLD:
data = 23; driver.send((uint8_t *)&data, sizeof(data)); driver.waitPacketSent();
case RELEASED:
data = 22; driver.send((uint8_t *)&data, sizeof(data)); driver.waitPacketSent();
if (( kpd.key[i].stateChanged ) && (mykey == C)) // --------------------------------------
case PRESSED:
if (D_Status==0) { data = 31; driver.send((uint8_t *)&data, sizeof(data)); driver.waitPacketSent(); Last_Gear = 31;}
if (D_Status==1) { data = 10; driver.send((uint8_t *)&data, sizeof(data)); driver.waitPacketSent(); } // Speeed full
C_Status = 1;
case HOLD:
// data = 33; driver.send((uint8_t *)&data, sizeof(data)); driver.waitPacketSent();
case RELEASED:
if (D_Status==0) { data = 32; driver.send((uint8_t *)&data, sizeof(data)); driver.waitPacketSent(); }
if (D_Status==1) { data = 5; driver.send((uint8_t *)&data, sizeof(data)); driver.waitPacketSent(); } // Speed LOW
C_Status = 0;
if (( kpd.key[i].stateChanged ) && (mykey == D)) // --------------------------------------
case PRESSED: //41
if (C_Status==0) { data = 41; driver.send((uint8_t *)&data, sizeof(data)); driver.waitPacketSent(); Last_Gear = 41;}
if (C_Status==1) { data = 10; driver.send((uint8_t *)&data, sizeof(data)); driver.waitPacketSent(); } // Speeed full
D_Status = 1;
case HOLD:
// data = 43; driver.send((uint8_t *)&data, sizeof(data)); driver.waitPacketSent();
case RELEASED: // 42
if (C_Status==0) { data = 42; driver.send((uint8_t *)&data, sizeof(data)); driver.waitPacketSent(); }
if (C_Status==1) { data = 5; driver.send((uint8_t *)&data, sizeof(data)); driver.waitPacketSent(); } // Speed LOW
D_Status = 0;
if (( kpd.key[i].stateChanged ) && (mykey == AA)) // -------------------------------------- P
case PRESSED:
case HOLD:
case RELEASED:
if (( kpd.key[i].stateChanged ) && (mykey == BB)) // --------------------------------------
case PRESSED:
case HOLD:
case RELEASED:
if (( kpd.key[i].stateChanged ) && (mykey == CC)) // --------------------------------------
case PRESSED:
case HOLD:
case RELEASED:
if (( kpd.key[i].stateChanged ) && (mykey == DD)) // --------------------------------------
case PRESSED:
case HOLD:
case RELEASED:
if (( kpd.key[i].stateChanged ) && (mykey == Key_Mode_Sw)) // --------------------------------------
case PRESSED:
if ( Key_Mode=="Perform") { Key_Mode="Bank"; }
else if ( Key_Mode=="Bank") { Key_Mode="Perform"; }
MAIN_SCN ();
if (( kpd.key[i].stateChanged ) && (mykey == DRUM)) // --------------------------------------
case PRESSED:
MAIN_SCN ();
if (( kpd.key[i].stateChanged ) && (mykey == Bank_WriteA)) // --------------------------------------
case PRESSED: Write_Bank (); Key_Mode="Bank"; MAIN_SCN (); break;
if (( kpd.key[i].stateChanged ) && (mykey == Bank_WriteB)) // --------------------------------------
if (( kpd.key[i].stateChanged ) && (mykey == MONO)) // --------------------------------------
case PRESSED: for (int i=1; i<11; i++) { MIDI.sendControlChange(126,0,i); } // (cc#,value,channel)
break; // CC# 126
if (( kpd.key[i].stateChanged ) && (mykey == POLY)) // --------------------------------------
case PRESSED: for (int i=1; i<11; i++) { MIDI.sendControlChange(127,0,i); } // (cc#,value,channel)
break; // CC#127
if (( kpd.key[i].stateChanged ) && (mykey == ORANGE_A )) // --------------------------------------
case PRESSED:
MIDI.sendProgramChange(111, 1);
for (int i=21; i>(-1); i--) {
MIDI.sendNoteOn((Bells_DRBR[i]+TRANS_KEY),127,1);
delay(100);
MIDI.sendNoteOff((Bells_DRBR[i]+TRANS_KEY),0,1); } // (note,velocity,channel)
MAIN_SCN ();
if (MIDI.read()) // Is there a MIDI message incoming ?
{ COUNT++;
// digitalWrite(13,HIGH);
byte A_TYPE = MIDI.getType();
byte A_CHANNEL = MIDI.getChannel(); // channel
byte A_NOTE = MIDI.getData1(); // note number
byte A_VOL = MIDI.getData2(); // velocity
if ((A_TYPE==144) && (A_CHANNEL == 4)&& (KEY_SHIFT_MODE==1) ) { // A_TYPE=144 noteOn 128 NoteOff ///
TRANS_KEY = (A_NOTE-73) + TRANS_KEY_Old; // ......52 = -12........64 = 0........76 = +12.......COARSE TUNE
display.setCursor(0,0); display.println(A_TYPE); display.setCursor(50,0); display.println(A_CHANNEL); display.setCursor(90,0); display.println( A_NOTE);
display.setCursor(0,16); display.println(A_VOL); display.setCursor(50,16); display.print( "Turn-"); display.print( COUNT);
display.display();
if (A_TYPE==240)
{ display.clearDisplay();
display.setCursor(0,0); display.print(A_TYPE); display.print( " -" ); display.print(A_CHANNEL); display.print( " -" ); display.print( A_NOTE);
display.setCursor(0,16); display.print( "Turn-"); display.print( COUNT);
display.display(); }
if ( TRANS_KEY != TRANS_KEY_Old ) {
byte sysexArray[8] = {0xF0,0x7F,0x7F,0x04,0x04,0x00,(TRANS_KEY+64),0xF7};
MIDI.sendSysEx(8,sysexArray,true);
MAIN_SCN ();
TRANS_KEY_Old = TRANS_KEY;
//// if (UP == 1) {PATCH =PATCH+10; MIDI.sendProgramChange(PATCH, 1); delay }
// if (DOWN == 1) {PATCH--; MIDI.sendProgramChange(PATCH, 1); }
if (PATCH < 0) { PATCH = 127; }
if (PATCH > 127) { PATCH = 0; }
} // End loop ####################################################################################################################################################
void All_Note_Off ()
MIDI.sendControlChange(0,123,0);
MIDI.sendControlChange(1,123,0);
MIDI.sendControlChange(2,123,0);
MIDI.sendControlChange(3,123,0);
MIDI.sendControlChange(4,123,0);
MIDI.sendControlChange(5,123,0);
MIDI.sendControlChange(6,123,0);
MIDI.sendControlChange(7,123,0);
MIDI.sendControlChange(8,123,0);
MIDI.sendControlChange(9,123,0);
MIDI.sendControlChange(10,123,0);
MIDI.sendControlChange(11,123,0);
MIDI.sendControlChange(12,123,0);
MIDI.sendControlChange(13,123,0);
MIDI.sendControlChange(14,123,0);
MIDI.sendControlChange(15,123,0);
void FIND_SCN ()
display.setTextSize(3); // Normal 1:1 pixel scale
display.println("Key ??");
display.display();
void SCN_SLIDE () {
display.println(SLIDE1);
display.display();
void MAIN_SCN () {
if (TRANS_KEY > 0) { display.print("+"); }
display.print(TRANS_KEY);
display.setCursor(60,0);
display.print(Key_Mode);
display.print("__");
display.print(Bank);
display.setCursor(70,16);
display.print("P- ");
display.print(PATCH+1);
display.display();
void function () {
MIDI.sendControlChange(94,127,1); // (cc#,value,channel)
void WEL_COME_SCN () {
display.setTextSize(2); // Normal 1:1 pixel scale
display.println("Roland CH2");
void Bank_Mode (int Bank_Key) {
if (Bank_Key==1) { MIDI.sendProgramChange(A001, 1); Bank = 1; PATCH = A001; }
if (Bank_Key==2) { MIDI.sendProgramChange(A002, 1); Bank = 2; PATCH = A002;}
if (Bank_Key==3) { MIDI.sendProgramChange(A003, 1); Bank = 3; PATCH = A003;}
if (Bank_Key==4) { MIDI.sendProgramChange(A004, 1); Bank = 4; PATCH = A004;}
if (Bank_Key==5) { MIDI.sendProgramChange(A005, 1); Bank = 5; PATCH = A005;}
if (Bank_Key==6) { MIDI.sendProgramChange(A006, 1); Bank = 6; PATCH = A006;}
if (Bank_Key==7) { MIDI.sendProgramChange(A007, 1); Bank = 7; PATCH = A007;}
if (Bank_Key==8) { MIDI.sendProgramChange(A008, 1); Bank = 8; PATCH = A008;}
if (Bank_Key==9) { MIDI.sendProgramChange(A009, 1); Bank = 9; PATCH = A009;}
if (Bank_Key==10) { MIDI.sendProgramChange(A010, 1); Bank = 10; PATCH = A010;}
if (Bank_Key==11) { MIDI.sendProgramChange(A011, 1); Bank = 11; PATCH = A011;}
if (Bank_Key==12) { MIDI.sendProgramChange(A012, 1); Bank = 12; PATCH = A012;}
if (Bank_Key==13) { MIDI.sendProgramChange(A013, 1); Bank = 13; PATCH = A013;}
if (Bank_Key==14) { MIDI.sendProgramChange(A014, 1); Bank = 14; PATCH = A014;}
if (Bank_Key==15) { MIDI.sendProgramChange(A015, 1); Bank = 15; PATCH = A015;}
if (Bank_Key==16) { MIDI.sendProgramChange(A016, 1); Bank = 16; PATCH = A016;}
if (Bank_Key==17) { MIDI.sendProgramChange(A017, 1); Bank = 17; PATCH = A017;}
if (Bank_Key==18) { MIDI.sendProgramChange(A018, 1); Bank = 18; PATCH = A018;}
if (Bank_Key==19) { MIDI.sendProgramChange(A019, 1); Bank = 19; PATCH = A019;}
if (Bank_Key==20) { MIDI.sendProgramChange(A020, 1); Bank = 20; PATCH = A020;}
if (Bank_Key==21) { MIDI.sendProgramChange(A21, 1); Bank = 21; PATCH = A21;}
if (Bank_Key==22) { MIDI.sendProgramChange(A22, 1); Bank = 22; PATCH = A22;}
if (Bank_Key==23) { MIDI.sendProgramChange(A23, 1); Bank = 23; PATCH = A23;}
if (Bank_Key==24) { MIDI.sendProgramChange(A24, 1); Bank = 24; PATCH = A24;}
if (Bank_Key==25) { MIDI.sendProgramChange(A25, 1); Bank = 25; PATCH = A25;}
if (Bank_Key==26) { MIDI.sendProgramChange(A26, 1); Bank = 26; PATCH = A26;}
if (Bank_Key==27) { MIDI.sendProgramChange(A27, 1); Bank = 27; PATCH = A27;}
if (Bank_Key==28) { MIDI.sendProgramChange(A28, 1); Bank = 28; PATCH = A28;}
if (Bank_Key==29) { MIDI.sendProgramChange(A29, 1); Bank = 29; PATCH = A29;}
if (Bank_Key==30) { MIDI.sendProgramChange(A30, 1); Bank = 30; PATCH = A30;}
if (Bank_Key==31) { MIDI.sendProgramChange(A31, 1); Bank = 31; PATCH = A31;}
if (Bank_Key==32) { MIDI.sendProgramChange(A32, 1); Bank = 32; PATCH = A32;}
if (Bank_Key==33) { MIDI.sendProgramChange(A33, 1); Bank = 33; PATCH = A33;}
if (Bank_Key==34) { MIDI.sendProgramChange(A34, 1); Bank = 34; PATCH = A34;}
if (Bank_Key==35) { MIDI.sendProgramChange(A35, 1); Bank = 35; PATCH = A35;}
if (Bank_Key==36) { MIDI.sendProgramChange(A36, 1); Bank = 36; PATCH = A36;}
if (Bank_Key==37) { MIDI.sendProgramChange(A37, 1); Bank = 37; PATCH = A37;}
if (Bank_Key==38) { MIDI.sendProgramChange(A38, 1); Bank = 38; PATCH = A38;}
if (Bank_Key==39) { MIDI.sendProgramChange(A39, 1); Bank = 39; PATCH = A39;}
if (Bank_Key==40) { MIDI.sendProgramChange(A40, 1); Bank = 40; PATCH = A40;}
if (Bank_Key==41) { MIDI.sendProgramChange(A41, 1); Bank = 41; PATCH = A41;}
if (Bank_Key==42) { MIDI.sendProgramChange(A42, 1); Bank = 42; PATCH = A42 ;}
if (Bank_Key==43) { MIDI.sendProgramChange(A43, 1); Bank = 43; PATCH = A43 ;}
if (Bank_Key==44) { MIDI.sendProgramChange(A44, 1); Bank = 44; PATCH = A44 ;}
if (Bank_Key==45) { MIDI.sendProgramChange(A45, 1); Bank = 45; PATCH = A45 ;}
if (Bank_Key==46) { MIDI.sendProgramChange(A46, 1); Bank = 46; PATCH = A46 ;}
if (Bank_Key==47) { MIDI.sendProgramChange(A47, 1); Bank = 47; PATCH = A47 ;}
if (Bank_Key==48) { MIDI.sendProgramChange(A48, 1); Bank = 48; PATCH = A48 ;}
if (Bank_Key==49) { MIDI.sendProgramChange(A49, 1); Bank = 49; PATCH = A49 ;}
if (Bank_Key==50) { MIDI.sendProgramChange(A50, 1); Bank = 50; PATCH = A50 ;}
if (Bank_Key==51) { MIDI.sendProgramChange(A51, 1); Bank = 51; PATCH = A51 ;}
if (Bank_Key==52) { MIDI.sendProgramChange(A52, 1); Bank = 52; PATCH = A51 ;}
if (Bank_Key==53) { MIDI.sendProgramChange(A53, 1); Bank = 53; PATCH = A53 ;}
if (Bank_Key==54) { MIDI.sendProgramChange(A54, 1); Bank = 54; PATCH = A54 ;}
if (Bank_Key==55) { MIDI.sendProgramChange(A55, 1); Bank = 55; PATCH = A55 ;}
if (Bank_Key==56) { MIDI.sendProgramChange(A56, 1); Bank = 56; PATCH = A56 ;}
if (Bank_Key==57) { MIDI.sendProgramChange(A57, 1); Bank = 57; PATCH = A57 ;}
if (Bank_Key==58) { MIDI.sendProgramChange(A58, 1); Bank = 58; PATCH = A58 ;}
if (Bank_Key==59) { MIDI.sendProgramChange(A59, 1); Bank = 59; PATCH = A59 ;}
if (Bank_Key==60) { MIDI.sendProgramChange(A60, 1); Bank = 60; PATCH = A60 ;}
if (Bank_Key==61) { MIDI.sendProgramChange(A61, 1); Bank = 61; PATCH = A61;}
if (Bank_Key==62) { MIDI.sendProgramChange(A62, 1); Bank = 62; PATCH = A62;}
if (Bank_Key==63) { MIDI.sendProgramChange(A63, 1); Bank = 63; PATCH = A63;}
if (Bank_Key==64) { MIDI.sendProgramChange(A64, 1); Bank = 64; PATCH = A64;}
if (Bank_Key==65) { MIDI.sendProgramChange(A65, 1); Bank = 65; PATCH = A65;}
if (Bank_Key==66) { MIDI.sendProgramChange(A66, 1); Bank = 66; PATCH = A66; }
if (Bank_Key==67) { MIDI.sendProgramChange(A67, 1); Bank = 67; PATCH = A67;}
if (Bank_Key==68) { MIDI.sendProgramChange(A68, 1); Bank = 68; PATCH = A68;}
if (Bank_Key==69) { MIDI.sendProgramChange(A69, 1); Bank = 69; PATCH = A69;}
if (Bank_Key==70) { MIDI.sendProgramChange(A70, 1); Bank = 70; PATCH = A70;}
if (Bank_Key==71) { MIDI.sendProgramChange(A71, 1); Bank = 71; PATCH = A71;}
if (Bank_Key==72) { MIDI.sendProgramChange(A72, 1); Bank = 72; PATCH = A72;}
if (Bank_Key==73) { MIDI.sendProgramChange(A73, 1); Bank = 73; PATCH = A73;}
if (Bank_Key==74) { MIDI.sendProgramChange(A74, 1); Bank = 74; PATCH = A74;}
if (Bank_Key==75) { MIDI.sendProgramChange(A75, 1); Bank = 75; PATCH = A75;}
if (Bank_Key==76) { MIDI.sendProgramChange(A76, 1); Bank = 76; PATCH = A76;}
if (Bank_Key==77) { MIDI.sendProgramChange(A77, 1); Bank = 77; PATCH = A77;}
if (Bank_Key==78) { MIDI.sendProgramChange(A78, 1); Bank = 78; PATCH = A78;}
if (Bank_Key==79) { MIDI.sendProgramChange(A79, 1); Bank = 79; PATCH = A79;}
if (Bank_Key==80) { MIDI.sendProgramChange(A80, 1); Bank = 80; PATCH = A80;}
if (Bank_Key==81) { MIDI.sendProgramChange(A81, 1); Bank = 81; PATCH = A81;}
if (Bank_Key==82) { MIDI.sendProgramChange(A82, 1); Bank = 82; PATCH = A82;}
if (Bank_Key==83) { MIDI.sendProgramChange(A83, 1); Bank = 83; PATCH = A83;} //////////////
if (Bank_Key==84) { MIDI.sendProgramChange(A84, 1); Bank = 84; PATCH = A84;}
if (Bank_Key==85) { MIDI.sendProgramChange(A85, 1); Bank = 85; PATCH = A85;}
if (Bank_Key==86) { MIDI.sendProgramChange(A86, 1); Bank = 86; PATCH = A86;}
if (Bank_Key==87) { MIDI.sendProgramChange(A87, 1); Bank = 87; PATCH = A87;}
if (Bank_Key==88) { MIDI.sendProgramChange(A88, 1); Bank = 88; PATCH = A88;}
if (Bank_Key==89) { MIDI.sendProgramChange(A89, 1); Bank = 89; PATCH = A89;}
if (Bank_Key==90) { MIDI.sendProgramChange(A90, 1); Bank = 90; PATCH = A90;}
if (Bank_Key==91) { MIDI.sendProgramChange(A91, 1); Bank = 91; PATCH = A91;}
if (Bank_Key==92) { MIDI.sendProgramChange(A92, 1); Bank = 92; PATCH = A92;}
if (Bank_Key==93) { MIDI.sendProgramChange(A93, 1); Bank = 93; PATCH = A93;}
if (Bank_Key==94) { MIDI.sendProgramChange(A94, 1); Bank = 94; PATCH = A94;}
if (Bank_Key==95) { MIDI.sendProgramChange(A95, 1); Bank = 95; PATCH = A95;}
if (Bank_Key==96) { MIDI.sendProgramChange(A96, 1); Bank = 96; PATCH = A96;}
if (Bank_Key==97) { MIDI.sendProgramChange(A97, 1); Bank = 97; PATCH = A97;}
if (Bank_Key==98) { MIDI.sendProgramChange(A98, 1); Bank = 98; PATCH = A98;}
if (Bank_Key==99) { MIDI.sendProgramChange(A99, 1); Bank = 99; PATCH = A99;}
if (Bank_Key==100) { MIDI.sendProgramChange(A100, 1); Bank = 100; PATCH = A100;}
if (Bank_Key==101) { MIDI.sendProgramChange(A101, 1); Bank = 101; PATCH = A101;}
if (Bank_Key==102) { MIDI.sendProgramChange(A102, 1); Bank = 102; PATCH = A102;}
if (Bank_Key==103) { MIDI.sendProgramChange(A103, 1); Bank = 103; PATCH = A103;}
if (Bank_Key==104) { MIDI.sendProgramChange(A104, 1); Bank = 104; PATCH = A104;}
if (Bank_Key==105) { MIDI.sendProgramChange(A105, 1); Bank = 105; PATCH = A105; }
if (Bank_Key==106) { MIDI.sendProgramChange(A106, 1); Bank = 106; PATCH = A106; }
if (Bank_Key==107) { MIDI.sendProgramChange(A107, 1); Bank = 107; PATCH = A107; }
if (Bank_Key==108) { MIDI.sendProgramChange(A108, 1); Bank = 108; PATCH = A108;}
if (Bank_Key==109) { MIDI.sendProgramChange(A109, 1); Bank = 109; PATCH = A109;}
if (Bank_Key==110) { MIDI.sendProgramChange(A110, 1); Bank = 110; PATCH = A110;}
if (Bank_Key==111) { MIDI.sendProgramChange(A111, 1); Bank = 111; PATCH = A111;}
if (Bank_Key==112) { MIDI.sendProgramChange(A112, 1); Bank = 112; PATCH = A112;}
if (Bank_Key==113) { MIDI.sendProgramChange(A113, 1); Bank = 113; PATCH = A113;}
if (Bank_Key==114) { MIDI.sendProgramChange(A114, 1); Bank = 114; PATCH = A114;}
if (Bank_Key==115) { MIDI.sendProgramChange(A115, 1); Bank = 115; PATCH = A115;}
if (Bank_Key==116) { MIDI.sendProgramChange(A116, 1); Bank = 116; PATCH = A116;}
if (Bank_Key==117) { MIDI.sendProgramChange(A117, 1); Bank = 117; PATCH = A117;}
if (Bank_Key==118) { MIDI.sendProgramChange(A118, 1); Bank = 118; PATCH = A118;}
if (Bank_Key==119) { MIDI.sendProgramChange(A119, 1); Bank = 119; PATCH = A119;}
if (Bank_Key ==120) { MIDI.sendProgramChange(A120, 1); Bank = 120; PATCH = A120;}
if (Bank_Key ==121) { MIDI.sendProgramChange(A121, 1); Bank = 121; PATCH = A121;}
if (Bank_Key ==122) { MIDI.sendProgramChange(A122, 1); Bank = 122; PATCH = A122;}
if (Bank_Key ==123) { MIDI.sendProgramChange(A123, 1); Bank = 123; PATCH = A123;}
if (Bank_Key ==124) { MIDI.sendProgramChange(A124, 1); Bank = 124; PATCH = A124;}
if (Bank_Key ==125) { MIDI.sendProgramChange(A125, 1); Bank = 125; PATCH = A125;}
if (Bank_Key ==126) { MIDI.sendProgramChange(A126, 1); Bank = 126; PATCH = A126;}
if (Bank_Key ==127) { MIDI.sendProgramChange(A127, 1); Bank = 127; PATCH = A127;}
if (Bank_Key ==128) { MIDI.sendProgramChange(A128, 1); Bank = 128; PATCH = A128;}
void Perform_Mode (int mykey)
{PATCH = mykey-1; MIDI.sendProgramChange(PATCH, 1);}
void Write_Bank () {
if (Bank==1) { EEPROM.write(1, PATCH); A001 = PATCH; }
if (Bank==2) { EEPROM.write(2, PATCH); A002 = PATCH; }
if (Bank==3) { EEPROM.write(3, PATCH); A003 = PATCH; }
if (Bank==4) { EEPROM.write(4, PATCH); A004 = PATCH; }
if (Bank==5) { EEPROM.write(5, PATCH); A005 = PATCH; }
if (Bank==6) { EEPROM.write(6, PATCH); A006 = PATCH; }
if (Bank==7) { EEPROM.write(7, PATCH); A007 = PATCH; }
if (Bank==8) { EEPROM.write(8, PATCH); A008 = PATCH; }
if (Bank==9) { EEPROM.write(9, PATCH); A009 = PATCH; }
if (Bank==10) { EEPROM.write(10, PATCH); A010 = PATCH; } // -----
if (Bank==11) { EEPROM.write(11, PATCH); A011 = PATCH; }
if (Bank==12) { EEPROM.write(12, PATCH); A012 = PATCH; }
if (Bank==13) { EEPROM.write(13, PATCH); A013 = PATCH; }
if (Bank==14) { EEPROM.write(14, PATCH); A014 = PATCH; }
if (Bank==15) { EEPROM.write(15, PATCH); A015 = PATCH; }
if (Bank==16) { EEPROM.write(16, PATCH); A016 = PATCH; }
if (Bank==17) { EEPROM.write(17, PATCH); A017 = PATCH; }
if (Bank==18) { EEPROM.write(18, PATCH); A018 = PATCH; }
if (Bank==19) { EEPROM.write(19, PATCH); A019 = PATCH; }
if (Bank==20) { EEPROM.write(20, PATCH); A020 = PATCH; }
if (Bank==21) { EEPROM.write(21, PATCH); A21 = PATCH; }
if (Bank==22) { EEPROM.write(22, PATCH); A22 = PATCH; }
if (Bank==23) { EEPROM.write(23, PATCH); A23 = PATCH; }
if (Bank==24) { EEPROM.write(24, PATCH); A24 = PATCH; }
if (Bank==25) { EEPROM.write(25, PATCH); A25 = PATCH; }
if (Bank==26) { EEPROM.write(26, PATCH); A26 = PATCH; }
if (Bank==27) { EEPROM.write(27, PATCH); A27 = PATCH; }
if (Bank==28) { EEPROM.write(28, PATCH); A28 = PATCH; }
if (Bank==29) { EEPROM.write(29, PATCH); A29 = PATCH; }
if (Bank==30) { EEPROM.write(30, PATCH); A30 = PATCH; }
if (Bank==31) { EEPROM.write(31, PATCH); A31 = PATCH; }
if (Bank==32) { EEPROM.write(32, PATCH); A32 = PATCH; }
if (Bank==33) { EEPROM.write(33, PATCH); A33 = PATCH; }
if (Bank==34) { EEPROM.write(34, PATCH); A34 = PATCH; }
if (Bank==35) { EEPROM.write(35, PATCH); A35 = PATCH; }
if (Bank==36) { EEPROM.write(36, PATCH); A36 = PATCH; }
if (Bank==37) { EEPROM.write(37, PATCH); A37 = PATCH; }
if (Bank==38) { EEPROM.write(38, PATCH); A38 = PATCH; }
if (Bank==39) { EEPROM.write(39, PATCH); A39 = PATCH; }
if (Bank==40) { EEPROM.write(40, PATCH); A40 = PATCH; }
if (Bank==41) { EEPROM.write(41, PATCH); A41 = PATCH; }
if (Bank==42) { EEPROM.write(42, PATCH); A42 = PATCH; }
if (Bank==43) { EEPROM.write(43, PATCH); A43 = PATCH; }
if (Bank==44) { EEPROM.write(44, PATCH); A44 = PATCH; }
if (Bank==45) { EEPROM.write(45, PATCH); A45 = PATCH; }
if (Bank==46) { EEPROM.write(46, PATCH); A46 = PATCH; }
if (Bank==47) { EEPROM.write(47, PATCH); A47 = PATCH; }
if (Bank==48) { EEPROM.write(48, PATCH); A48 = PATCH; }
if (Bank==49) { EEPROM.write(49, PATCH); A49 = PATCH; }
if (Bank==50) { EEPROM.write(50, PATCH); A50 = PATCH; }
if (Bank==51) { EEPROM.write(51, PATCH); A51 = PATCH; }
if (Bank==52) { EEPROM.write(52, PATCH); A52 = PATCH; }
if (Bank==53) { EEPROM.write(53, PATCH); A53 = PATCH; }
if (Bank==54) { EEPROM.write(54, PATCH); A54 = PATCH; }
if (Bank==55) { EEPROM.write(55, PATCH); A55 = PATCH; }
if (Bank==56) { EEPROM.write(56, PATCH); A56 = PATCH; }
if (Bank==57) { EEPROM.write(57, PATCH); A57 = PATCH; }
if (Bank==58) { EEPROM.write(58, PATCH); A58 = PATCH; }
if (Bank==59) { EEPROM.write(59, PATCH); A59 = PATCH; }
if (Bank==60) { EEPROM.write(60, PATCH); A60 = PATCH; }
if (Bank==61) { EEPROM.write(61, PATCH); A61 = PATCH; } //write A61 address PATCH_Number
if (Bank==62) { EEPROM.write(62, PATCH); A62 = PATCH; }
if (Bank==63) { EEPROM.write(63, PATCH); A63 = PATCH; }
if (Bank==64) { EEPROM.write(64, PATCH); A64 = PATCH; }
if (Bank==65) { EEPROM.write(65, PATCH); A65 = PATCH ; }
if (Bank==66) { EEPROM.write(66, PATCH); A66 = PATCH; }
if (Bank==67) { EEPROM.write(67, PATCH); A67 = PATCH; }
if (Bank==68) { EEPROM.write(68, PATCH); A68 = PATCH; }
if (Bank==69) { EEPROM.write(69, PATCH); A69 = PATCH; }
if (Bank==70) { EEPROM.write(70, PATCH); A70 = PATCH; }
if (Bank==71) { EEPROM.write(71, PATCH); A71 = PATCH; }
if (Bank==72) { EEPROM.write(72, PATCH); A72 = PATCH; }
if (Bank==73) { EEPROM.write(73, PATCH); A73 = PATCH; }
if (Bank==74) { EEPROM.write(74, PATCH); A74 = PATCH; }
if (Bank==75) { EEPROM.write(75, PATCH); A75 = PATCH; }
if (Bank==76) { EEPROM.write(76, PATCH); A76 = PATCH; }
if (Bank==77) { EEPROM.write(77, PATCH); A77 = PATCH; }
if (Bank==78) { EEPROM.write(78, PATCH); A78 = PATCH; }
if (Bank==79) { EEPROM.write(79, PATCH); A79 = PATCH; }
if (Bank==80) { EEPROM.write(80, PATCH); A80 = PATCH; }
if (Bank==81) { EEPROM.write(81, PATCH); A81 = PATCH; }
if (Bank==82) { EEPROM.write(82, PATCH); A82 = PATCH; }
if (Bank==83) { EEPROM.write(83, PATCH); A83 = PATCH; }
if (Bank==84) { EEPROM.write(84, PATCH); A84 = PATCH; }
if (Bank==85) { EEPROM.write(85, PATCH); A85 = PATCH; }
if (Bank==86) { EEPROM.write(86, PATCH); A86 = PATCH; }
if (Bank==87) { EEPROM.write(87, PATCH); A87 = PATCH; }
if (Bank==88) { EEPROM.write(88, PATCH); A88 = PATCH; }
if (Bank==89) { EEPROM.write(89, PATCH); A89 = PATCH; }
if (Bank==90) { EEPROM.write(90, PATCH); A90 = PATCH; }
if (Bank==91) { EEPROM.write(91, PATCH); A91 = PATCH; }
if (Bank==92) { EEPROM.write(92, PATCH); A92 = PATCH; }
if (Bank==93) { EEPROM.write(93, PATCH); A93 = PATCH; }
if (Bank==94) { EEPROM.write(94, PATCH); A94 = PATCH; }
if (Bank==95) { EEPROM.write(95, PATCH); A95 = PATCH; }
if (Bank==96) { EEPROM.write(96, PATCH); A96 = PATCH; }
if (Bank==97) { EEPROM.write(97, PATCH); A97 = PATCH; }
if (Bank==98) { EEPROM.write(98, PATCH); A98 = PATCH; }
if (Bank==99) { EEPROM.write(99, PATCH); A99 = PATCH; }
if (Bank==100) { EEPROM.write(100, PATCH); A100 = PATCH; }
if (Bank==101) { EEPROM.write(101, PATCH); A101 = PATCH; }
if (Bank==102) { EEPROM.write(102, PATCH); A102 = PATCH; }
if (Bank==103) { EEPROM.write(103, PATCH); A103 = PATCH; }
if (Bank==104) { EEPROM.write(104, PATCH); A104 = PATCH; }
if (Bank==105) { EEPROM.write(105, PATCH); A105 = PATCH; }
if (Bank==106) { EEPROM.write(106, PATCH); A106 = PATCH; }
if (Bank==107) { EEPROM.write(107, PATCH); A107 = PATCH; }
if (Bank==108) { EEPROM.write(108, PATCH); A108 = PATCH; }
if (Bank==109) { EEPROM.write(109, PATCH); A109 = PATCH; }
if (Bank==110) { EEPROM.write(110, PATCH); A110 = PATCH; }
if (Bank==111) { EEPROM.write(111, PATCH); A111 = PATCH; }
if (Bank==112) { EEPROM.write(112, PATCH); A112 = PATCH; }
if (Bank==113) { EEPROM.write(113, PATCH); A113 = PATCH; }
if (Bank==114) { EEPROM.write(114, PATCH); A114 = PATCH; }
if (Bank==115) { EEPROM.write(115, PATCH); A115 = PATCH; }
if (Bank==116) { EEPROM.write(116, PATCH); A116 = PATCH; }
if (Bank==117) { EEPROM.write(117, PATCH); A117 = PATCH; }
if (Bank==118) { EEPROM.write(118, PATCH); A118 = PATCH; }
if (Bank==119) { EEPROM.write(119, PATCH); A119 = PATCH; }
if (Bank==120) { EEPROM.write(120, PATCH); A120 = PATCH; }
Write_Bank_SCN ();
delay(1000); MAIN_SCN ();
void Bank_Mode_Released (int Bank_key) {
void Write_Bank_SCN () {
display.print("Write Done");
display.display();
and i have this board with running above sketch
Arduino 2560
i tried it again after 1 year .i did nothing to it ,
select board "Arduino Mega or Mega 2560" and hit compile and i got error
Arduino: 1.8.19 (Windows 7), TD: 1.59, Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Users\acer\AppData\Local\Arduino15\packages -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Users\acer\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\acer\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\acer\AppData\Local\Temp\arduino_build_125782 -warnings=none -build-cache C:\Users\acer\AppData\Local\Temp\arduino_cache_709087 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\acer\Documents\Arduino\2560_Midi_RadioHead\2560_Midi_RadioHead.ino
C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Users\acer\AppData\Local\Arduino15\packages -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Users\acer\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\acer\Documents\Arduino\libraries -fqbn=arduino:avr:mega:cpu=atmega2560 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\acer\AppData\Local\Temp\arduino_build_125782 -warnings=none -build-cache C:\Users\acer\AppData\Local\Temp\arduino_cache_709087 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avr-gcc.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\7.3.0-atmel3.6.1-arduino7 -prefs=runtime.tools.avrdude.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -verbose C:\Users\acer\Documents\Arduino\2560_Midi_RadioHead\2560_Midi_RadioHead.ino
Using board 'mega' from platform in folder: C:\Users\acer\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Using core 'arduino' from platform in folder: C:\Users\acer\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6
Detecting libraries used...
"C:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\sketch\\2560_Midi_RadioHead.ino.cpp" -o nul
Alternatives for RH_ASK.h: [RadioHead]
ResolveLibrary(RH_ASK.h)
-> candidates: [RadioHead]
"C:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\RadioHead" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\sketch\\2560_Midi_RadioHead.ino.cpp" -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
-> candidates: [SPI@1.0]
"C:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\sketch\\2560_Midi_RadioHead.ino.cpp" -o nul
Alternatives for MIDI.h: [MIDI_Library-5.0.2@5.0.2]
ResolveLibrary(MIDI.h)
-> candidates: [MIDI_Library-5.0.2@5.0.2]
"C:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\MIDI_Library-5.0.2\\src" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\sketch\\2560_Midi_RadioHead.ino.cpp" -o nul
Alternatives for Keypad.h: [Keypad-3.1.1@3.1.1]
ResolveLibrary(Keypad.h)
-> candidates: [Keypad-3.1.1@3.1.1]
"C:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\MIDI_Library-5.0.2\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Keypad-3.1.1\\src" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\sketch\\2560_Midi_RadioHead.ino.cpp" -o nul
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
-> candidates: [Wire@1.0]
"C:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\MIDI_Library-5.0.2\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Keypad-3.1.1\\src" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\sketch\\2560_Midi_RadioHead.ino.cpp" -o nul
Alternatives for Adafruit_GFX.h: [Adafruit_GFX_Library@1.7.5]
ResolveLibrary(Adafruit_GFX.h)
-> candidates: [Adafruit_GFX_Library@1.7.5]
"C:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\MIDI_Library-5.0.2\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Keypad-3.1.1\\src" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\sketch\\2560_Midi_RadioHead.ino.cpp" -o nul
Alternatives for Adafruit_SSD1306.h: [Adafruit_SSD1306@2.5.7]
ResolveLibrary(Adafruit_SSD1306.h)
-> candidates: [Adafruit_SSD1306@2.5.7]
"C:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\MIDI_Library-5.0.2\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Keypad-3.1.1\\src" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\sketch\\2560_Midi_RadioHead.ino.cpp" -o nul
Alternatives for EEPROM.h: [EEPROM@2.0]
ResolveLibrary(EEPROM.h)
-> candidates: [EEPROM@2.0]
"C:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\MIDI_Library-5.0.2\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Keypad-3.1.1\\src" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\sketch\\2560_Midi_RadioHead.ino.cpp" -o nul
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RHCRC.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RHDatagram.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RHEncryptedDriver.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RHGenericDriver.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RHGenericSPI.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RHHardwareSPI.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RHMesh.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RHNRFSPIDriver.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RHReliableDatagram.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RHRouter.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RHSPIDriver.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RHSoftwareSPI.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RH_ASK.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RH_CC110.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RH_E32.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RH_MRF89.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RH_NRF24.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RH_NRF51.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RH_NRF905.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RH_RF22.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RH_RF24.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RH_RF69.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RH_RF95.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RH_Serial.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\RadioHead\RH_TCP.cpp
Using cached library dependencies for file: C:\Users\acer\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI\src\SPI.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\MIDI_Library-5.0.2\src\MIDI.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\Keypad-3.1.1\src\Key.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\Keypad-3.1.1\src\Keypad.cpp
Using cached library dependencies for file: C:\Users\acer\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src\Wire.cpp
Using cached library dependencies for file: C:\Users\acer\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire\src\utility\twi.c
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\Adafruit_GFX_Library\glcdfont.c
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp
Generating function prototypes...
"C:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\MIDI_Library-5.0.2\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Keypad-3.1.1\\src" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\sketch\\2560_Midi_RadioHead.ino.cpp" -o "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega2560 -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_MEGA2560 -DARDUINO_ARCH_AVR "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\cores\\arduino" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\variants\\mega" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\RadioHead" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\SPI\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\MIDI_Library-5.0.2\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Keypad-3.1.1\\src" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\Wire\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.6\\libraries\\EEPROM\\src" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\sketch\\2560_Midi_RadioHead.ino.cpp" -o "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\sketch\\2560_Midi_RadioHead.ino.cpp.o"
Compiling libraries...
Compiling library "RadioHead"
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RHCRC.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RHGenericDriver.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RHEncryptedDriver.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RHHardwareSPI.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RHGenericSPI.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RHNRFSPIDriver.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RHMesh.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RHDatagram.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RHRouter.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RHSPIDriver.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RHReliableDatagram.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RHSoftwareSPI.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RH_E32.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RH_ASK.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RH_CC110.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RH_MRF89.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RH_NRF24.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RH_RF22.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RH_RF24.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RH_NRF51.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RH_RF69.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RH_NRF905.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RH_RF95.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RH_TCP.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RH_Serial.cpp.o
Compiling library "SPI"
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\SPI\SPI.cpp.o
Compiling library "MIDI_Library-5.0.2"
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\MIDI_Library-5.0.2\MIDI.cpp.o
Compiling library "Keypad-3.1.1"
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\Keypad-3.1.1\Key.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\Keypad-3.1.1\Keypad.cpp.o
Compiling library "Wire"
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\Wire\Wire.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\Wire\utility\twi.c.o
Compiling library "Adafruit_GFX_Library"
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\Adafruit_GFX_Library\glcdfont.c.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp.o
Compiling library "Adafruit_SSD1306"
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp.o
Compiling library "EEPROM"
Compiling core...
Using precompiled core: C:\Users\acer\AppData\Local\Temp\arduino_cache_709087\core\core_arduino_avr_mega_cpu_atmega2560_e096d7f2de0ee363dcb84f01ce7a5463.a
Linking everything together...
"C:\\Users\\acer\\AppData\\Local\\Arduino15\\packages\\arduino\\tools\\avr-gcc\\7.3.0-atmel3.6.1-arduino7/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega2560 -o "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782/2560_Midi_RadioHead.ino.elf" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\sketch\\2560_Midi_RadioHead.ino.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RHCRC.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RHDatagram.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RHEncryptedDriver.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RHGenericDriver.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RHGenericSPI.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RHHardwareSPI.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RHMesh.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RHNRFSPIDriver.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RHReliableDatagram.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RHRouter.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RHSPIDriver.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RHSoftwareSPI.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RH_ASK.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RH_CC110.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RH_E32.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RH_MRF89.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RH_NRF24.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RH_NRF51.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RH_NRF905.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RH_RF22.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RH_RF24.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RH_RF69.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RH_RF95.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RH_Serial.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\RadioHead\\RH_TCP.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\MIDI_Library-5.0.2\\MIDI.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\Keypad-3.1.1\\Key.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\Keypad-3.1.1\\Keypad.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\Adafruit_GFX_Library\\glcdfont.c.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782\\libraries\\Adafruit_SSD1306\\Adafruit_SSD1306.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782/..\\arduino_cache_709087\\core\\core_arduino_avr_mega_cpu_atmega2560_e096d7f2de0ee363dcb84f01ce7a5463.a" "-LC:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_125782" -lm
`__vector_1' referenced in section `.vectors' of c:/users/acer/appdata/local/arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/../lib/gcc/avr/7.3.0/../../../../avr/lib/avr6/crtatmega2560.o: defined in discarded section `.text' of WInterrupts.c.o (symbol from plugin)
`__vector_2' referenced in section `.vectors' of c:/users/acer/appdata/local/arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/../lib/gcc/avr/7.3.0/../../../../avr/lib/avr6/crtatmega2560.o: defined in discarded section `.text' of WInterrupts.c.o (symbol from plugin)
`__vector_3' referenced in section `.vectors' of c:/users/acer/appdata/local/arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/../lib/gcc/avr/7.3.0/../../../../avr/lib/avr6/crtatmega2560.o: defined in discarded section `.text' of WInterrupts.c.o (symbol from plugin)
`__vector_4' referenced in section `.vectors' of c:/users/acer/appdata/local/arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/../lib/gcc/avr/7.3.0/../../../../avr/lib/avr6/crtatmega2560.o: defined in discarded section `.text' of WInterrupts.c.o (symbol from plugin)
`__vector_5' referenced in section `.vectors' of c:/users/acer/appdata/local/arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/../lib/gcc/avr/7.3.0/../../../../avr/lib/avr6/crtatmega2560.o: defined in discarded section `.text' of WInterrupts.c.o (symbol from plugin)
`__vector_6' referenced in section `.vectors' of c:/users/acer/appdata/local/arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/../lib/gcc/avr/7.3.0/../../../../avr/lib/avr6/crtatmega2560.o: defined in discarded section `.text' of WInterrupts.c.o (symbol from plugin)
`__vector_7' referenced in section `.vectors' of c:/users/acer/appdata/local/arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/../lib/gcc/avr/7.3.0/../../../../avr/lib/avr6/crtatmega2560.o: defined in discarded section `.text' of WInterrupts.c.o (symbol from plugin)
`__vector_8' referenced in section `.vectors' of c:/users/acer/appdata/local/arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/../lib/gcc/avr/7.3.0/../../../../avr/lib/avr6/crtatmega2560.o: defined in discarded section `.text' of WInterrupts.c.o (symbol from plugin)
`__vector_17' referenced in section `.vectors' of c:/users/acer/appdata/local/arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/../lib/gcc/avr/7.3.0/../../../../avr/lib/avr6/crtatmega2560.o: defined in discarded section `.text' of C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\RadioHead\RH_ASK.cpp.o (symbol from plugin)
`__vector_23' referenced in section `.vectors' of c:/users/acer/appdata/local/arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/../lib/gcc/avr/7.3.0/../../../../avr/lib/avr6/crtatmega2560.o: defined in discarded section `.text' of wiring.c.o (symbol from plugin)
`__vector_25' referenced in section `.vectors' of c:/users/acer/appdata/local/arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/../lib/gcc/avr/7.3.0/../../../../avr/lib/avr6/crtatmega2560.o: defined in discarded section `.text' of HardwareSerial0.cpp.o (symbol from plugin)
`__vector_26' referenced in section `.vectors' of c:/users/acer/appdata/local/arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/../lib/gcc/avr/7.3.0/../../../../avr/lib/avr6/crtatmega2560.o: defined in discarded section `.text' of HardwareSerial0.cpp.o (symbol from plugin)
`__vector_39' referenced in section `.vectors' of c:/users/acer/appdata/local/arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/../lib/gcc/avr/7.3.0/../../../../avr/lib/avr6/crtatmega2560.o: defined in discarded section `.text' of C:\Users\acer\AppData\Local\Temp\arduino_build_125782\libraries\Wire\utility\twi.c.o (symbol from plugin)
c:/users/acer/appdata/local/arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino7/bin/../lib/gcc/avr/7.3.0/../../../../avr/lib/avr6/crtatmega2560.o:(.init9+0x0): undefined reference to `main'
collect2.exe: error: ld returned 1 exit status
Using library RadioHead in folder: C:\Users\acer\Documents\Arduino\libraries\RadioHead (legacy)
Using library SPI at version 1.0 in folder: C:\Users\acer\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\SPI
Using library MIDI_Library-5.0.2 at version 5.0.2 in folder: C:\Users\acer\Documents\Arduino\libraries\MIDI_Library-5.0.2
Using library Keypad-3.1.1 at version 3.1.1 in folder: C:\Users\acer\Documents\Arduino\libraries\Keypad-3.1.1
Using library Wire at version 1.0 in folder: C:\Users\acer\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\Wire
Using library Adafruit_GFX_Library at version 1.7.5 in folder: C:\Users\acer\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library Adafruit_SSD1306 at version 2.5.7 in folder: C:\Users\acer\Documents\Arduino\libraries\Adafruit_SSD1306
Using library EEPROM at version 2.0 in folder: C:\Users\acer\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.6\libraries\EEPROM
exit status 1
Error compiling for board Arduino Mega or Mega 2560.
could you please tell me , what i am missing ??????
