Error during uploading" avrdude: stk500_recv(): programmer is not responding"
getting following error msg during Uploading And "L" led continue flashing.
Arduino: 1.8.13 (Windows 7), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Users\acer\AppData\Local\Arduino15\packages -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Users\acer\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\acer\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\acer\AppData\Local\Temp\arduino_build_564364 -warnings=none -build-cache C:\Users\acer\AppData\Local\Temp\arduino_cache_608920 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Program Files\Arduino\examples\01.Basics\Blink\Blink.ino
C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Users\acer\AppData\Local\Arduino15\packages -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Users\acer\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\acer\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\acer\AppData\Local\Temp\arduino_build_564364 -warnings=none -build-cache C:\Users\acer\AppData\Local\Temp\arduino_cache_608920 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Program Files\Arduino\examples\01.Basics\Blink\Blink.ino
Using board 'nano' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_564364\\sketch\\Blink.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Generating function prototypes...
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_564364\\sketch\\Blink.ino.cpp" -o "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_564364\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_564364\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_564364\\sketch\\Blink.ino.cpp" -o "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_564364\\sketch\\Blink.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\acer\AppData\Local\Temp\arduino_cache_608920\core\core_arduino_avr_nano_cpu_atmega328old_5638c217b04eda8279099c4937887265.a
Linking everything together...
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_564364/Blink.ino.elf" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_564364\\sketch\\Blink.ino.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_564364/..\\arduino_cache_608920\\core\\core_arduino_avr_nano_cpu_atmega328old_5638c217b04eda8279099c4937887265.a" "-LC:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_564364" -lm
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_564364/Blink.ino.elf" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_564364/Blink.ino.eep"
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_564364/Blink.ino.elf" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_564364/Blink.ino.hex"
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_564364/Blink.ino.elf"
Sketch uses 924 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b57600 -D -Uflash:w:C:\Users\acer\AppData\Local\Temp\arduino_build_564364/Blink.ino.hex:i
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
         Using Port                    : COM6
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd1
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xd1
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xd1
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xd1
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xd1
i also have tried Re-install Arduino IDE setup.
i don't know about programmer error messege. please guide me in simple steps
thank you..
Your problem is very common and answered in the forum thousand times... Please use forum search.
In general - you PC doesn't connect to the board. The most likely causes are wrong port and cable without data lines(charging cable).
  • ensure your board is really a Nano
  • ensure you selected the right port
  • try the other boot loader for the Nano
Cable has been checked.it is working on my camera to pc ..
Board is Nano. Port is right being show in ide. Also have tried other boot loader....
is it an official nano or one with a ch340 chip for the Serial communication? if so, do you have the right driver?
have you tried a different USB cable? different USB port?
There are no simple steps :wink:
Could you upload in the past?
What is the project that you're working on when it started failing?
Anything connected to pins 0 and/or 1?
If that is one second on / one off, it's the blink sketch that comes preloaded from the factory.
It is ch340.
LED flashing faster.
I tried another Nano board( for blink example) . That is also giving same error.
No issue of data cable. Also tried another port.
I tried Teensy LC board (for blink example) on same Port. It successfully uploaded code. And running fine.
"If about drivers " --- I upload many built-in examples codes before one week. There was no problem.
The problem appeared perhaps when I tried code in this Post
so do you have that driver installed?
so you double posted on that issue. that's bad... You were told the code is not the problem, the problem is with the upload.
May be you damaged something. Do you have another board to try out?
Do you try to upload the code without anything connected to 0 & 1 pins, as suggested in that thread?
Code is not being upload toa Arduino nano. Giving following error
Arduino: 1.8.13 (Windows 7), TD: 1.53, Board: "Arduino Nano, ATmega328P (Old Bootloader)"
Sketch uses 18990 bytes (61%) of program storage space. Maximum is 30720 bytes.
Global variables use 939 bytes (45%) of dynamic memory, leaving 1109 bytes for local variables. Maximum is 2048 bytes.
An error occurred while uploading the sketch
option enabled in File -> Preferences.
From following code
#include <Adafruit_SSD1306.h>    //   ok sketch    PIN 6 7 8 ARE FREE NOW
#include <TimerOne.h>
#include <EEPROM.h>
#include <Encoder.h>
#include <MIDI.h>
#include <Keypad.h>
const byte ROWS = 6; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
{1,2,3,4},
{5,6,7,8},
{9,10,11,12},
{13,14,15,16},
{17,18,19,20},
{21,22,23,24}
byte rowPins[ROWS] = {8,9,10,11,12,A0}; //connect to the row pinouts of the kpd
byte colPins[COLS] = {4,5,6,7}; //connect to the column pinouts of the kpd
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
String msg;
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
//  #define LED_PIN1 7 // Tempo LED
//  #define SYNC_OUTPUT_PIN 6 // Audio Sync Digital Pin
//  #define SYNC_OUTPUT_PIN2 8 // 2nd Audio Sync Pin
#define CLOCKS_PER_BEAT 24 // MIDI Clock Ticks
#define AUDIO_SYNC 12 // Audio Sync Ticks
#define AUDIO_SYNC2 12 // 2nd Audio Sync Ticks
#define MINIMUM_BPM 20
#define MAXIMUM_BPM 300
#define BLINK_TIME 4 // LED blink time
unsigned long Mark_A = 0;
unsigned long Mark_B = 0;
unsigned long Gap = 0;
byte Patch = 50;
byte STOP_CUT = 0;
byte SHIFT_UP = 0;
byte SHIFT_DOWN = 0;
volatile int  blinkCount = 0,
              blinkCount2 = 0,
              AudioSyncCount = 0,
              AudioSyncCount2 = 0;
long intervalMicroSeconds,
      bpm,
      audio_sync2;
boolean playing = false,
      sync_editing = false,
      display_update = false;
Encoder myEnc(2, 3); // Rotary Encoder Pin 2,3
MIDI_CREATE_DEFAULT_INSTANCE();
void sendClockPulse() {    //  -----------------------SEND CLOCK PULSE
  MIDI.sendRealTime(midi::Clock); // sending midi clock
  if (playing) {
  blinkCount = (blinkCount + 1) % CLOCKS_PER_BEAT;
  blinkCount2 = (blinkCount2 + 1) % (CLOCKS_PER_BEAT / 2);
  AudioSyncCount = (AudioSyncCount + 1) % AUDIO_SYNC;
  AudioSyncCount2 = (AudioSyncCount2 + 1) % audio_sync2;
  if (AudioSyncCount == 0) {    /*  digitalWrite(SYNC_OUTPUT_PIN, HIGH);  */  }
  else {          if (AudioSyncCount == 1) {     /*  digitalWrite(SYNC_OUTPUT_PIN, LOW); */  } }
  if (AudioSyncCount2 == 0) {  /* digitalWrite(SYNC_OUTPUT_PIN2, HIGH);  */ }
  else {          if (AudioSyncCount2 == 1) {  /* digitalWrite(SYNC_OUTPUT_PIN2, LOW); */  }  }
  if (blinkCount == 0) {  /*  digitalWrite(LED_PIN1, HIGH);  */  }
  else {    if (blinkCount == BLINK_TIME) {  /* digitalWrite(LED_PIN1, LOW); */  }  }  } // if playing
}      //   ------------------------------SEND CLOCK PULSE
void updateBpm() { // update BPM function (on the fly)
  long interval = 60L * 1000 * 1000 / bpm / CLOCKS_PER_BEAT;
  Timer1.setPeriod(interval);  }
void setup(void) {
  MIDI.begin(); // MIDI init
  MIDI.turnThruOff();
  bpm = EEPROMReadInt(0);
  if (bpm > MAXIMUM_BPM || bpm < MINIMUM_BPM) {
    bpm = 120;
  audio_sync2 = EEPROMReadInt(3);
  if (audio_sync2 > 64 || audio_sync2 < 2) {
    audio_sync2 = 12;
  Timer1.initialize(intervalMicroSeconds);
  Timer1.setPeriod(60L * 1000 * 1000 / bpm / CLOCKS_PER_BEAT);
  Timer1.attachInterrupt(sendClockPulse);
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  display.clearDisplay();
  display.setTextColor(WHITE);
  display.setTextSize(4);
  display.setCursor(0,0);
  display.print(bpm);
  display.display();
void EEPROMWriteInt(int p_address, int p_value)
     byte lowByte = ((p_value >> 0) & 0xFF);
     byte highByte = ((p_value >> 8) & 0xFF);
     EEPROM.write(p_address, lowByte);
     EEPROM.write(p_address + 1, highByte);
unsigned int EEPROMReadInt(int p_address)
     byte lowByte = EEPROM.read(p_address);
     byte highByte = EEPROM.read(p_address + 1);
     return ((lowByte << 0) & 0xFF) + ((highByte << 8) & 0xFF00);
void bpm_display() {
  updateBpm();
  EEPROMWriteInt(0,bpm);
  display.setTextColor(WHITE, BLACK);
  display.print("     ");
  display.print(bpm);
  display.display();
void sync_display() {
  EEPROMWriteInt(3,audio_sync2);
  int sync_current;
  sync_current = audio_sync2 - 12;
  if (sync_current < 0) {
    sync_current = abs(sync_current);
  } else if (sync_current > 0) {
    sync_current = -sync_current;
  display.print("     ");
  display.print(sync_current);
  display.display();
void startOrStop() {
  if (!playing) {
    MIDI.sendRealTime(midi::Start);
  //    all_off();
    MIDI.sendRealTime(midi::Stop);
  playing = !playing;
int oldPosition;
void loop(void) {      //___________________ LOOP START ___________________LOOP START _______________________ LOOP START ______________________________
  byte i = 0;
  byte p = 0;
  int newPosition = (myEnc.read()/4);
  if (newPosition != oldPosition) {
    if (oldPosition < newPosition) {   i = 2;  }
    else if (oldPosition > newPosition) {   i = 1;  }
    oldPosition = newPosition; }
  if (!sync_editing) {
      if (i == 2) {     bpm++;      if (bpm > MAXIMUM_BPM) {     bpm = MAXIMUM_BPM;  }   bpm_display();     }
  else if (i == 1) {     bpm--;     if (bpm < MINIMUM_BPM) {     bpm = MINIMUM_BPM;  }     bpm_display();   }
  else if (p == 1) {    sync_display();    sync_editing = true;     }          //rotary.resetPush();
  } else  { // 2nd jack audio sync speed
           if (p == 1) {            bpm_display();     sync_editing = false;    }
      else if (i == 1) {       audio_sync2++;    if (audio_sync2 > 64)   { audio_sync2 = 64; }     sync_display();    }
      else if (i == 2) {       audio_sync2--;    if (audio_sync2 < 2)    { audio_sync2 = 2;  }     sync_display();    }
    if (kpd.getKeys())     //     _________________KEYPAD ___________________________KEYPAD___________________________________________________
    {     for (int i=0; i<LIST_MAX; i++)       {     byte mykey = kpd.key[i].kchar ;
            if (( kpd.key[i].stateChanged )  &&  (mykey == 1))  // -------------------KEY_1----------------------------
            {      switch (kpd.key[i].kstate) {
                    case PRESSED:
                    MIDI.sendNoteOn(60 ,127 ,1 );  //   Note=48, velocity=127, channal=1     MIDI.sendNoteOn(Note,Velocity,Channal)
                 case RELEASED:
                    MIDI.sendNoteOff(60 ,0 ,1 );   //
                            if (( kpd.key[i].stateChanged )  &&  (mykey == 2))  // -------------------KEY_2----------------------------
                    case PRESSED:
                    MIDI.sendNoteOn(61 ,127,1 );  //   Note=48, velocity=127, channal=1     MIDI.sendNoteOn(Note,Velocity,Channal)
                 case RELEASED:
                    MIDI.sendNoteOff( 61, 0, 1);   //
                            if (( kpd.key[i].stateChanged )  &&  (mykey == 3))  // -------------------KEY_3----------------------------
                    case PRESSED:
                    MIDI.sendNoteOn( 62, 127, 1);  //   Note=48, velocity=127, channal=1     MIDI.sendNoteOn(Note,Velocity,Channal)
                 case RELEASED:
                    MIDI.sendNoteOff( 62, 0, 1);   //
                            if (( kpd.key[i].stateChanged )  &&  (mykey == 4))  // -------------------KEY_4----------------------------
                    case PRESSED:
                    MIDI.sendNoteOn( 63, 127, 1);  //   Note=48, velocity=127, channal=1     MIDI.sendNoteOn(Note,Velocity,Channal)
                 case RELEASED:
                    MIDI.sendNoteOff( 63, 0, 1);   //
                            if (( kpd.key[i].stateChanged )  &&  (mykey == 5))  // -------------------KEY_5----------------------------
                    case PRESSED:
                    MIDI.sendNoteOn( 64, 127, 1);  //   Note=48, velocity=127, channal=1     MIDI.sendNoteOn(Note,Velocity,Channal)
                 case RELEASED:
                    MIDI.sendNoteOff( 64, 0, 1);   //
                            if (( kpd.key[i].stateChanged )  &&  (mykey == 6))  // -------------------KEY_6----------------------------
                    case PRESSED:
                    MIDI.sendNoteOn( 65, 127, 1);  //   Note=48, velocity=127, channal=1     MIDI.sendNoteOn(Note,Velocity,Channal)
                 case RELEASED:
                    MIDI.sendNoteOff( 65, 0, 1);   //
                            if (( kpd.key[i].stateChanged )  &&  (mykey == 7))  // -------------------KEY_7----------------------------
                    case PRESSED:
                    MIDI.sendNoteOn( 66, 127, 1);  //   Note=48, velocity=127, channal=1     MIDI.sendNoteOn(Note,Velocity,Channal)
                 case RELEASED:
                    MIDI.sendNoteOff( 66, 0, 1);   //
                 if (( kpd.key[i].stateChanged )  &&  (mykey == 8))  // -------------------KEY_8----------------------------
                    case PRESSED:
                    MIDI.sendNoteOn( 67, 127, 1);  //   Note=48, velocity=127, channal=1     MIDI.sendNoteOn(Note,Velocity,Channal)
                 case RELEASED:
                    MIDI.sendNoteOff( 67, 0, 1);   //
                 if (( kpd.key[i].stateChanged )  &&  (mykey == 9))  // -------------------KEY_9----------------------------
                    case PRESSED:
                    MIDI.sendNoteOn( 68, 127, 1);  //   Note=48, velocity=127, channal=1     MIDI.sendNoteOn(Note,Velocity,Channal)
                 case RELEASED:
                    MIDI.sendNoteOff( 68, 0, 1);   //
                 if (( kpd.key[i].stateChanged )  &&  (mykey == 10))  // -------------------KEY_10----------------------------
                    case PRESSED:
                    STOP_CUT = 1;
                 case RELEASED:
                    STOP_CUT = 0;
                 if (( kpd.key[i].stateChanged )  &&  (mykey == 11))  // -------------------KEY_11----------------------------
                    case PRESSED:
                    MIDI.sendNoteOn( 69, 127, 1);  //   Note=48, velocity=127, channal=1     MIDI.sendNoteOn(Note,Velocity,Channal) ________TRIG-1
                     if (STOP_CUT ==1) {
                      MIDI.sendControlChange(123,0,1);
                      MIDI.sendNoteOn( 69, 127, 1);   }
                 case RELEASED:
                    MIDI.sendNoteOff( 69, 0, 1);   //
                 if (( kpd.key[i].stateChanged )  &&  (mykey == 12))  // -------------------KEY_12----------------------------
                    case PRESSED:                              //   TRIG 2
                    MIDI.sendNoteOn( 70, 127, 1);  //   Note=48, velocity=127, channal=1     MIDI.sendNoteOn(Note,Velocity,Channal)  _________TRIG-2
                    if (STOP_CUT ==1) {
                      MIDI.sendNoteOn( 70, 127, 1);   }
                 case RELEASED:
                    MIDI.sendNoteOff( 70, 0, 1);   //
                 if (( kpd.key[i].stateChanged )  &&  (mykey == 13))  // -------------------KEY_13----------------------------
                    case PRESSED:
                     MIDI.sendNoteOn( 71, 127, 1);  //   Note=48, velocity=127, channal=1     MIDI.sendNoteOn(Note,Velocity,Channal)  _________TRIG-3
                    if (STOP_CUT ==1) {
                      MIDI.sendNoteOn( 71, 127, 1);   }
                 case RELEASED:
                        MIDI.sendNoteOff( 71, 0, 1);   //
                 if (( kpd.key[i].stateChanged )  &&  (mykey == 14))  // -------------------KEY_14----------------------------
                    case PRESSED:
                      MIDI.sendNoteOn( 72, 127, 1);  //   Note=48, velocity=127, channal=1     MIDI.sendNoteOn(Note,Velocity,Channal)  _________TRIG-4
                    if (STOP_CUT ==1) {
                      MIDI.sendNoteOn( 72, 127, 1);   }
                 case RELEASED:
                        MIDI.sendNoteOff( 72, 0, 1);   //
                 if (( kpd.key[i].stateChanged )  &&  (mykey == 15))  // -------------------KEY_15----------------------------
                    case PRESSED:
                       Mark_B = micros();         Gap = Mark_B - Mark_A;       Mark_A = micros();    //  Tempo Taping
                         if (Gap<1000000) { bpm = 60000000/Gap; bpm_display();  }
                 case RELEASED:
                 if (( kpd.key[i].stateChanged )  &&  (mykey == 16))  // -------------------KEY_16----------------------------
                    case PRESSED:
                 case RELEASED:
                 if (( kpd.key[i].stateChanged )  &&  (mykey == 17))  // -------------------KEY_17----------------------------
                    case PRESSED:
                      Patch++;
                          MIDI.sendProgramChange(Patch, 1);
                 case HOLD:
                     SHIFT_UP = 1;
                 case RELEASED:
                     SHIFT_UP = 0;
                 if (( kpd.key[i].stateChanged )  &&  (mykey == 18))  // -------------------KEY_18----------------------------
                    case PRESSED:
                    Patch--;
                 case HOLD:
                     SHIFT_DOWN = 1;
                 case RELEASED:
                     SHIFT_DOWN = 0;
                 if (( kpd.key[i].stateChanged )  &&  (mykey == 19))  // -------------------KEY_19----------------------------
                    case PRESSED:
                        MIDI.sendProgramChange(91, 1);
                 case RELEASED:
                 if (( kpd.key[i].stateChanged )  &&  (mykey == 20))  // -------------------KEY_20----------------------------
                    case PRESSED:
                        MIDI.sendProgramChange(92, 1);
                 case RELEASED:
                 if (( kpd.key[i].stateChanged )  &&  (mykey == 21))  // -------------------KEY_21----------------------------
                    case PRESSED:
                        MIDI.sendProgramChange(93, 1);
                 case RELEASED:
                 if (( kpd.key[i].stateChanged )  &&  (mykey == 22))  // -------------------KEY_22----------------------------
                    case PRESSED:
                        MIDI.sendProgramChange(94, 1);
                 case RELEASED:
                 if (( kpd.key[i].stateChanged )  &&  (mykey == 23))  // -------------------KEY_23----------------------------
                    case PRESSED:
                        MIDI.sendProgramChange(95, 1);
                 case RELEASED:
                 if (( kpd.key[i].stateChanged )  &&  (mykey ==24))  // -------------------KEY_24----------------------------
                    case PRESSED:
                        MIDI.sendProgramChange(96, 1);
                 case RELEASED:
                }}  //   __________________KEYPAD END _______________KEYPAD END_____________________________________________________________
if (SHIFT_UP ==1)  {     Patch++;    MIDI.sendProgramChange(Patch, 1);  }
if (SHIFT_DOWN ==1)  {      Patch--;    MIDI.sendProgramChange(Patch, 1);  }
}        //___________________ LOOP END ___________________LOOP END_______________________ LOOP END ______________________________________________________________________________________
void all_off() { // make sure all sync, led pin stat to low
//  digitalWrite(SYNC_OUTPUT_PIN, LOW);
//  digitalWrite(SYNC_OUTPUT_PIN2, LOW);
//  digitalWrite(LED_PIN1, LOW);
  if (playing) {
  if (AudioSyncCount == 0) {      digitalWrite(SYNC_OUTPUT_PIN, HIGH);    }
  else {          if (AudioSyncCount == 1) {       digitalWrite(SYNC_OUTPUT_PIN, LOW);   } }
  if (AudioSyncCount2 == 0) {   digitalWrite(SYNC_OUTPUT_PIN2, HIGH);   }
  else {          if (AudioSyncCount2 == 1) {   digitalWrite(SYNC_OUTPUT_PIN2, LOW);   }  }
  if (blinkCount == 0) {   digitalWrite(LED_PIN1, HIGH);    }
  else {    if (blinkCount == BLINK_TIME) {   digitalWrite(LED_PIN1, LOW);   }  }  } // if playing
   void Tap  ()  {       //   For Tempo TAP BUtton
   void BPM_100 ()   {  bpm = 100;  ; bpm_display();    }
    void  START_STOP ()  {   startOrStop(); }  // for START Button
  void MIDI_Functions ()    {
                                           MIDI.sendNoteOn(48 ,127, 1);  //   Note=48, velocity=127, channal=1
                                             MIDI.sendNoteOff(48 ,127, 1);   //
                                               MIDI.sendControlChange(123,64,1);  // controller number=123, cc_value=64, channal=1
                                               MIDI.sendProgramChange(41, 1);   //     Prog=41,  channal=1
                                                   MIDI.sendRealTime(midi::Start); // sending midi Start
                                                     MIDI.sendRealTime(midi::Stop); // sending midi Stop
Please describe here to solve issue
This error related to upload process. It has nothing to do with "global variables and dynamic memory" and with code at all.
First, turn on detail output in IDE preferences and show it in the forum.
You have an upload issue, seems the compilation went fine
I noticed this
Have you tried the « new » bootloader?
Also, follow that suggestion, and report the (more detailed) messages that you get.
Your topic has been moved to the more suitably category, because the question has nothing to do with programming.
Personaly I think that for an upload error it's a silly suggestion. Might be wrong but my advise is always to disable it for upload errors.
thank you all my senior for reply.
as you suggest. ---- "Show verbose output during compilation"
i am getting these messege during uploading
C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Users\acer\AppData\Local\Arduino15\packages -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Users\acer\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\acer\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\acer\AppData\Local\Temp\arduino_build_292687 -warnings=none -build-cache C:\Users\acer\AppData\Local\Temp\arduino_cache_215479 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Users\acer\Documents\Arduino\Simplifying__Clock_tempo_code\Simplifying__Clock_tempo_code_2\Simplifying__Clock_tempo_code_2.ino
C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Users\acer\AppData\Local\Arduino15\packages -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Users\acer\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Users\acer\Documents\Arduino\libraries -fqbn=arduino:avr:nano:cpu=atmega328old -vid-pid=1A86_7523 -ide-version=10813 -build-path C:\Users\acer\AppData\Local\Temp\arduino_build_292687 -warnings=none -build-cache C:\Users\acer\AppData\Local\Temp\arduino_cache_215479 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\arduinoOTA\1.3.0 -prefs=runtime.tools.avrdude.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17 -prefs=runtime.tools.avr-gcc.path=C:\Program Files\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files\Arduino\hardware\tools\avr -verbose C:\Users\acer\Documents\Arduino\Simplifying__Clock_tempo_code\Simplifying__Clock_tempo_code_2\Simplifying__Clock_tempo_code_2.ino
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\sketch\\Simplifying__Clock_tempo_code_2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Adafruit_SSD1306.h: [Adafruit_SSD1306@2.2.0]
ResolveLibrary(Adafruit_SSD1306.h)
  -> candidates: [Adafruit_SSD1306@2.2.0]
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\sketch\\Simplifying__Clock_tempo_code_2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Wire.h: [Wire@1.0]
ResolveLibrary(Wire.h)
  -> candidates: [Wire@1.0]
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\sketch\\Simplifying__Clock_tempo_code_2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
  -> candidates: [SPI@1.0]
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\sketch\\Simplifying__Clock_tempo_code_2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Adafruit_GFX.h: [Adafruit_GFX_Library@1.7.5]
ResolveLibrary(Adafruit_GFX.h)
  -> candidates: [Adafruit_GFX_Library@1.7.5]
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\sketch\\Simplifying__Clock_tempo_code_2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for TimerOne.h: [TimerOne@1.1]
ResolveLibrary(TimerOne.h)
  -> candidates: [TimerOne@1.1]
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\TimerOne" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\sketch\\Simplifying__Clock_tempo_code_2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for EEPROM.h: [EEPROM@2.0]
ResolveLibrary(EEPROM.h)
  -> candidates: [EEPROM@2.0]
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\TimerOne" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\sketch\\Simplifying__Clock_tempo_code_2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Encoder.h: [Encoder-1.4.2@1.4.2]
ResolveLibrary(Encoder.h)
  -> candidates: [Encoder-1.4.2@1.4.2]
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\TimerOne" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Encoder-1.4.2" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\sketch\\Simplifying__Clock_tempo_code_2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for MIDI.h: [MIDI_Library-5.0.2@5.0.2]
ResolveLibrary(MIDI.h)
  -> candidates: [MIDI_Library-5.0.2@5.0.2]
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\TimerOne" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Encoder-1.4.2" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\MIDI_Library-5.0.2\\src" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\sketch\\Simplifying__Clock_tempo_code_2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Keypad.h: [Keypad-3.1.1@3.1.1]
ResolveLibrary(Keypad.h)
  -> candidates: [Keypad-3.1.1@3.1.1]
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\TimerOne" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Encoder-1.4.2" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\MIDI_Library-5.0.2\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Keypad-3.1.1\\src" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\sketch\\Simplifying__Clock_tempo_code_2.ino.cpp" -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp
Using cached library dependencies for file: C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src\Wire.cpp
Using cached library dependencies for file: C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire\src\utility\twi.c
Using cached library dependencies for file: C:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI\src\SPI.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\Adafruit_GFX_Library\glcdfont.c
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\TimerOne\TimerOne.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\Encoder-1.4.2\Encoder.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\MIDI_Library-5.0.2\src\MIDI.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\Keypad-3.1.1\src\Key.cpp
Using cached library dependencies for file: C:\Users\acer\Documents\Arduino\libraries\Keypad-3.1.1\src\Keypad.cpp
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\TimerOne" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Encoder-1.4.2" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\MIDI_Library-5.0.2\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Keypad-3.1.1\\src" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\sketch\\Simplifying__Clock_tempo_code_2.ino.cpp" -o "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\preproc\\ctags_target_for_gcc_minus_e.cpp" -DARDUINO_LIB_DISCOVERY_PHASE
"C:\\Program Files\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10813 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\variants\\eightanaloginputs" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_SSD1306" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\Wire\\src" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\SPI\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Adafruit_GFX_Library" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\TimerOne" "-IC:\\Program Files\\Arduino\\hardware\\arduino\\avr\\libraries\\EEPROM\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Encoder-1.4.2" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\MIDI_Library-5.0.2\\src" "-IC:\\Users\\acer\\Documents\\Arduino\\libraries\\Keypad-3.1.1\\src" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\sketch\\Simplifying__Clock_tempo_code_2.ino.cpp" -o "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\sketch\\Simplifying__Clock_tempo_code_2.ino.cpp.o"
Compiling library "Adafruit_SSD1306"
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_292687\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp.o
Compiling library "Wire"
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_292687\libraries\Wire\Wire.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_292687\libraries\Wire\utility\twi.c.o
Compiling library "SPI"
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_292687\libraries\SPI\SPI.cpp.o
Compiling library "Adafruit_GFX_Library"
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_292687\libraries\Adafruit_GFX_Library\glcdfont.c.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_292687\libraries\Adafruit_GFX_Library\Adafruit_GFX.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_292687\libraries\Adafruit_GFX_Library\Adafruit_SPITFT.cpp.o
Compiling library "TimerOne"
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_292687\libraries\TimerOne\TimerOne.cpp.o
Compiling library "EEPROM"
Compiling library "Encoder-1.4.2"
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_292687\libraries\Encoder-1.4.2\Encoder.cpp.o
Compiling library "MIDI_Library-5.0.2"
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_292687\libraries\MIDI_Library-5.0.2\MIDI.cpp.o
Compiling library "Keypad-3.1.1"
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_292687\libraries\Keypad-3.1.1\Keypad.cpp.o
Using previously compiled file: C:\Users\acer\AppData\Local\Temp\arduino_build_292687\libraries\Keypad-3.1.1\Key.cpp.o
Compiling core...
Using precompiled core: C:\Users\acer\AppData\Local\Temp\arduino_cache_215479\core\core_arduino_avr_nano_cpu_atmega328old_5638c217b04eda8279099c4937887265.a
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687/Simplifying__Clock_tempo_code_2.ino.elf" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\sketch\\Simplifying__Clock_tempo_code_2.ino.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\libraries\\Adafruit_SSD1306\\Adafruit_SSD1306.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\libraries\\Wire\\Wire.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\libraries\\Wire\\utility\\twi.c.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\libraries\\SPI\\SPI.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\libraries\\Adafruit_GFX_Library\\glcdfont.c.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\libraries\\Adafruit_GFX_Library\\Adafruit_GFX.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\libraries\\Adafruit_GFX_Library\\Adafruit_SPITFT.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\libraries\\TimerOne\\TimerOne.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\libraries\\Encoder-1.4.2\\Encoder.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\libraries\\MIDI_Library-5.0.2\\MIDI.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\libraries\\Keypad-3.1.1\\Key.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687\\libraries\\Keypad-3.1.1\\Keypad.cpp.o" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687/..\\arduino_cache_215479\\core\\core_arduino_avr_nano_cpu_atmega328old_5638c217b04eda8279099c4937887265.a" "-LC:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687" -lm
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xb9
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687/Simplifying__Clock_tempo_code_2.ino.elf" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687/Simplifying__Clock_tempo_code_2.ino.eep"
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687/Simplifying__Clock_tempo_code_2.ino.elf" "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687/Simplifying__Clock_tempo_code_2.ino.hex"
Using library Adafruit_SSD1306 at version 2.2.0 in folder: C:\Users\acer\Documents\Arduino\libraries\Adafruit_SSD1306
Using library Wire at version 1.0 in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\Wire
Using library SPI at version 1.0 in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\SPI
Using library Adafruit_GFX_Library at version 1.7.5 in folder: C:\Users\acer\Documents\Arduino\libraries\Adafruit_GFX_Library
Using library TimerOne at version 1.1 in folder: C:\Users\acer\Documents\Arduino\libraries\TimerOne
Using library EEPROM at version 2.0 in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\EEPROM
Using library Encoder-1.4.2 at version 1.4.2 in folder: C:\Users\acer\Documents\Arduino\libraries\Encoder-1.4.2
Using library MIDI_Library-5.0.2 at version 5.0.2 in folder: C:\Users\acer\Documents\Arduino\libraries\MIDI_Library-5.0.2
Using library Keypad-3.1.1 at version 3.1.1 in folder: C:\Users\acer\Documents\Arduino\libraries\Keypad-3.1.1
"C:\\Program Files\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\acer\\AppData\\Local\\Temp\\arduino_build_292687/Simplifying__Clock_tempo_code_2.ino.elf"
C:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\acer\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b57600 -D -Uflash:w:C:\Users\acer\AppData\Local\Temp\arduino_build_292687/Simplifying__Clock_tempo_code_2.ino.hex:i
         Using Port                    : COM6
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xb3
today i am getting same messege also during upload my previous sketches.which was working fine before 6 monthes. And now led on my nano board also being flashing continously.
as you look at above detailed error msg , what should i do next to solve it.......
How your midi hardware is connected?
Please provide the schematic with designating the pin numbers
Wiring is same as It
But error coming during uploading.
Is there any file missing in windows directory???
Try with nothing connected anything to pins 0 and 1
