error: expected primary-expression before '<' token
what is wrong with this code
Board Wemos D1 R1
Windows 10 64bit
Arduino IDE 1.8.12
code is copied of other script with different information that works fine so wy is this not working ? what im not seeing or what did i wrong cant figure it out
if ( temp =< 0.0 )
  tmpString.replace("%imgtemp%", "thermometer -10_0.png"); // Temp color
else if ( temp => 0.0 && =< 10.0 )
  tmpString.replace("%imgtemp%", "thermometer 0_10.png"); // Temp color
else if ( temp => 10.0 && =< 20.0 )
  tmpString.replace("%imgtemp%", "thermometer 10_20.png"); // Temp color
else if ( temp => 20.0 && =< 30.0 )
  tmpString.replace("%imgtemp%", "thermometer 20_30.png"); // Temp color
else if ( temp => 30.0 && =< 40.0 )
  tmpString.replace("%imgtemp%", "thermometer 30_40.png"); // Temp color
this error is given by ide
Wemos___website_clean.ino:335:12: error: expected primary-expression before '<' token
 if ( temp =< 0.0 )
Wemos___website_clean.ino:339:17: error: expected primary-expression before '>' token
Wemos___website_clean.ino:339:26: error: expected primary-expression before '=' token
Wemos___website_clean.ino:339:27: error: expected primary-expression before '<' token
Wemos___website_clean.ino:343:17: error: expected primary-expression before '>' token
Wemos___website_clean.ino:343:27: error: expected primary-expression before '=' token
Wemos___website_clean.ino:343:28: error: expected primary-expression before '<' token
Wemos___website_clean.ino:347:17: error: expected primary-expression before '>' token
Wemos___website_clean.ino:347:27: error: expected primary-expression before '=' token
Wemos___website_clean.ino:347:28: error: expected primary-expression before '<' token
Wemos___website_clean.ino:351:17: error: expected primary-expression before '>' token
Wemos___website_clean.ino:351:27: error: expected primary-expression before '=' token
Wemos___website_clean.ino:351:28: error: expected primary-expression before '<' token
exit status 1
The less-than-or-equal symbol is <= but you've put =<
(That's not the only error I see in your code btw)
As well as the syntax errors pointed out by GypsumFantastic the comparisons need to be "complete".
else if ( temp => 0.0 && temp = < 10.0 )
See also:
thanks for your quick respond i found the problem yeah
thank you all !!
if (temp < 0.0)
  tmpString.replace("%imgtemp%", "thermometer -10_0.png"); // dagstatus
else if (temp >= 0 && temp <= 10 )
  tmpString.replace("%imgtemp%", "thermometer 0_10.png"); // dagstatus
else if ( temp >= 10 && temp <= 20 )
  tmpString.replace("%imgtemp%", "thermometer 10_20.png"); // dagstatus
else if ( temp >= 20 && temp <= 30 )
  tmpString.replace("%imgtemp%", "thermometer 20_30.png"); // dagstatus
else if ( temp >= 30 && temp <= 40 )
  tmpString.replace("%imgtemp%", "thermometer 30_40.png"); // dagstatus
Do you actually read the responses given to your questions?
GypsumFantastic gave you the answer and I linked the references for those operators. Your comparison operators are backwards. You cannot make up your own syntax.
It is >= for greater than operator, not =>.
It is <= for less than operator, not =<.
Did you read #1? '= <' is very definitely not the same as '<='.
Steve
