Help with a compilation error in Arduino
Hello! I have a code that says expected primary - expression before " = " token. I have written the code within asteriks where the mistake occurs. Could someone please help me figure out what the mistake is? Thanks
  **if ((x >=20 || x < = -20) && (y >=20 || y <= -20) && (z >= 20 || z < = -20)**
    & ((millis()/1000) - endTimer - sleepTimerInterruption > 8) )
The compiler told exactly where the problem is - why didn't you share that obvious item of information?
Right there
this is where the error occurrs
What changes should I make to not get the error? I don't understand why I am getting the error
That one is correct.
See the difference?
Oh is it the spacing?
Yup
Oh alright. Thank you so much!!
Just a heads-up for any beginners following…
C based languages regard ‘white space’ (or the lack of) very strictly.
It is used to delimit fields, operators etc, so a stray space or tab can impact your code without being immediately visible.
C whitespace
Thank you for the clarification
