Please post the whole code. Read the how to use this forum-please read sticky to see how to properly post code and some advice on how to ask an effective question. Remove useless white space and format the code with the IDE autoformat tool (crtl-t or Tools, Auto Format) before posting code.
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
im trying to make a new LCD chip (RA8835) for the library openGLCD,
i managd to fix that error but now it gives me the same error just for a different line
if you want to try this code you need to save the device in the devices inside the opensGLCD library
as RA8835_device
and save the configuration as ManualConfig_RA8835_panel.h*
// the RA8835 device
RA8835_Device.h - openGLCD library support for graphic LCDs
vi:ts=4
This is a device template file that shows what needs to be
in a device header for a glcd.
The following lcd primitives must be defined
glcdDev_SelectChip(chip)
glcdDev_ENstrobeHi(chip)
glcdDev_ENstrobeLo(chip)
glcdDev_Xval2Chip(x)
glcdDev_Xval2ChipCol(x)
For devices that split set column into to 2 commands of hi/lo:
glcdDev_Col2addrlo(x) (x & 0xf) // lo nibble
glcdDev_Col2addrhi(x) (x & 0xf0) // hi nibble
#ifndef GLCD_PANEL_DEVICE_H
#define GLCD_PANEL_DEVICE_H
* define name for Device
#define glcdDev_DeviceName "RA8835"
* LCD commands -------------------------------------------------------------
#define LCD_ON 0x59
#define LCD_OFF 0x58
#define LCD_DISP_START 0x00
#define LCD_SET_PAGE 0x44
#define LCD_SET_ADDLO 0x00
#define LCD_SET_ADDHI 0x00
/*definitions for specific LCD settings as well as the
command codes for various function
RA8835, LCD drivers */
//Commands
#define LCD_SYSTEM_SET 0x40
#define LCD_SYS_P1 0x10 | (LCD_IV << 5) | (LCD_WS << 3) | (LCD_M2 << 2) | (LCD_M1 << 1) | LCD_M0 //SYSTEM SET Parameter P1 byte
#define LCD_M0 0
#define LCD_M1 0
#define LCD_M2 0
#define LCD_WS 0
#define LCD_IV 1
#define LCD_SYS_P2 0x00 | (LCD_WF << 7) | LCD_FX
#define LCD_FX 7
#define LCD_WF 1
#define LCD_FY 7
#define LCD_CR 39
#define LCD_TCR 90
#define LCD_LF 239
#define LCD_APL 40
#define LCD_APH 0 // P8 - AP High byte,
#define LCD_SLEEP_IN 0x53
#define LCD_DISP_OFF 0x58 // Display On/Off C control byte (C + P1) , display off
#define LCD_DISP_ON 0x59 // Display On/Off C control byte (C + P1) , display on
#define LCD_DISP_P1 // DISP P1 byte
#define LCD_FC
#define LCD_FP_1st
#define LCD_FP_2cd
#define LCD_FP_3rd
#define LCD_SCROLL 0x44
#define LCD_SAD1L 0
#define LCD_SAD1H 0
#define LCD_SL1 0xEF
#define LCD_SAD2L 0xB0
#define LCD_SAD2H 0x04
#define LCD_SL2 0xEF
#define LCD_SAD3L 0
#define LCD_SAD3H 0
#define LCD_SAD4L 0
#define LCD_SAD4H 0
#define LCD_TEXTSIZE ((LCD_SAD2H << 8) + LCD_SAD2L)
#define LCD_GRAPHICSTART ((LCD_SAD2H << 8) + LCD_SAD2L)
#define LCD_GRAPHICSIZE ((LCD_SL2+1) * (LCD_SCR_WIDTH+1))>>3
#define LCD_CSRFORM 0x5d
#define LCD_CRX 0x04
#define LCD_CSRF_P2 0x00 | (LCD_CM << 7) | LCD_CRY // CSRFORM P2
#define LCD_CRY 0x07
#define LCD_CM 0
#define LCD_CSRDIR_U 0x4e
#define LCD_CSRDIR_D 0x4f
#define LCD_CSRDIR_L 0x4d
#define LCD_CSRDIR_R 0x4c
#define LCD_OVLAY 0x5b
#define LCD_OVLAY_P1 0x00 | (LCD_OV << 4) | (LCD_DM2 << 3) | (LCD_DM1 << 2) | (LCD_MX1 << 1) | LCD_MX0 // OVLAY P1
#define LCD_MX0 1
#define LCD_MX1 0
#define LCD_DM1 0
#define LCD_DM2 0
#define LCD_OV 0
#define LCD_CGRAM_ADR 0x5c
#define LCD_SAGL 0
#define LCD_SAGH 0x70
#define LCD_HDOT_SCR 0x5a
#define LCD_D
#define LCD_CSRW 0x46
#define LCD_WADR_L
#define LCD_WADR_H
#define LCD_CSRR 0x47
#define LCD_RADR_L
#define LCD_RADR_H
#define LCD_MWRITE 0x42
#define LCD_MREAD 0x43
#define LCD_SCR_WIDTH 319
#define LCD_LINES 30
#define LCD_SCRD 0
#define LCD_FLASH 0x16
#define LCD_MEM_END 10800
* Status register bits/flags -----------------------------------------------
#define LCD_BUSY_FLAG 0x80
#define LCD_BUSY_BIT 7
#define LCD_RESET_BIT 4
#define LCD_RESET_FLAG 0x10
* Define primitives used by glcd_Device.cpp --------------------------------
#define glcdDev_SelectChip(chip)
* Define how to strob EN signals
#define glcdDev_ENstrobeHi(chip) glcdio_WritePin(glcdPinEN, 0)
#define glcdDev_ENstrobeLo(chip) glcdio_WritePin(glcdPinEN, 1)
* Convert X & Y coordinates to chip values
#if CHIP_HEIGHT < DISPLAY_HEIGHT
#define glcdDev_XYval2Chip(x, y) (((y) < CHIP_HEIGHT) ? 0 : 1)
#else
#define glcdDev_XYval2Chip(x, y) (((x) < CHIP_WIDTH) ? 0 : 1)
#endif
#define glcdDev_Xval2ChipCol(x)
#define glcdDev_Col2addrlo(x)
#define glcdDev_Col2addrhi(x)
#define glcdDev_Init(chip) (\
uint8_t status;\
do {\
digitalWrite(glcdPinCSEL1, 1);\
digitalWrite(glcdPinRW, 1);\
digitalWrite(glcdPinEN, 1);\
digitalWrite(glcdPinDI, 1);\
digitalWrite(glcdPinRST, 1);\
pinMode(glcdPinCSEL1, OUTPUT);\
pinMode(glcdPinRST, OUTPUT);\
pinMode(glcdPinDI, OUTPUT);\
pinMode(glcdPinRW, OUTPUT);\
pinMode(glcdPinEN, OUTPUT);\
digitalWrite(glcdPinRST, 0);\
delay(50);\
delay(50);\
WriteCommand(LCD_SYSTEM_SET, chip);\
delayMicroseconds(1000);\
WriteData(LCD_SYS_P1);\
delayMicroseconds(1);\
WriteData(LCD_SYS_P2);\
WriteData(LCD_FY);\
WriteData(LCD_CR);\
WriteData(LCD_TCR);\
WriteData(LCD_LF);\
WriteData(LCD_APL);\
WriteData(LCD_APH);\
WriteCommand(LCD_SCROLL, chip);\
WriteData(LCD_SAD1L);\
WriteData(LCD_SAD1H);\
WriteData(LCD_SL1);\
WriteData(LCD_SAD2L);\
WriteData(LCD_SAD2H);\
WriteData(LCD_SL2);\
WriteData(LCD_SAD3L);\
WriteData(LCD_SAD3H);\
WriteData(LCD_SAD4L);\
WriteData(LCD_SAD4H);\
WriteCommand(LCD_CSRFORM, chip);\
WriteData(LCD_CRX);\
WriteData(LCD_CSRF_P2);\
WriteCommand(LCD_CGRAM_ADR, chip);\
WriteData(LCD_SAGL);\
WriteData(LCD_SAGH);\
WriteCommand(LCD_CSRDIR_R, chip);\
WriteCommand(LCD_HDOT_SCR, chip);\
WriteData(LCD_SCRD);\
WriteCommand(LCD_OVLAY, chip);\
WriteData(LCD_OVLAY_P1);\
WriteCommand(LCD_DISP_ON, chip);\
WriteData(LCD_FLASH);\
while (0);\
status = GLCD_ENOERR;\
status; /* return value of macro */\
#endif //GLCD_PANEL_DEVICE_H
// the RA8835 manual config
#ifndef GLCD_PANEL_CONFIG_H
#define GLCD_PANEL_CONFIG_H
* define name for panel configuration
#define glcd_ConfigName "RA8835-Manual"
#define DISPLAY_WIDTH 240
#define DISPLAY_HEIGHT 160
// panel controller chips
#define CHIP_WIDTH 240 // pixels per chip
#define CHIP_HEIGHT 160 // pixels per chip
// calculate number of chips & round up if width is not evenly divisable
#define glcd_CHIP_COUNT (1)
#define glcdPinData0 37
#define glcdPinData1 36
#define glcdPinData2 35
#define glcdPinData3 34
#define glcdPinData4 33
#define glcdPinData5 32
#define glcdPinData6 31
#define glcdPinData7 30
#define glcdPinRW 9 // this is the WR pin of the panel
#define glcdPinDI 10 // this is the A0 pin of the panel
#define glcdPinRST 12 // this is the reset pin of the panel
#define glcdPinCSEL1 11 // this is the CS pin of the panel
#define glcdPinEN 8 // this is the RD pin of the panel
#define glcd_BLactlevel HIGH
#define GLCD_tDDR 85 /* tACC6: Data Delay time (E high to valid read data) */
#define GLCD_tAS 0 /* tAW6: Address setup time (ctrl line changes to E high) */
#define GLCD_tDSW 100 /* tDS6: Data setup time (Write data lines setup to dropping E) */
#define GLCD_tWH 120 /* tEW: E hi level width (minimum E hi pulse width) */
#define GLCD_tWL 250 /* E lo level width (minimum E lo pulse width) */
#include "device/RA8835_Device.h"
#endif //GLCD_PANEL_CONFIG_H
Please post the entire text of the error message. It is easy to do. There is a "copy error message" button. Copy the error message and paste to a new post.
I've seen that error when there is a misplace or mismatched curly-bracket.
The complier doesn't really know what the error is or exactly where the error is, it just knows that what you've written doesn't make sense to the compiler.
Sometimes you can zero-in on the problem by commenting-out sections of code. But of course, you have to do that in a way that makes sense too. For example you can comment-out almost everything in a function and perhaps make it return a dummy value. Then bring-back a few lines of code at a time until you find the code that's causing the error.
...And it helps if you develop your code a little at a time, testing as you go so you always know where to look for the error.
D:\Arduino\libraries\openGLCD\glcd_Device.cpp: In member function 'void glcd_Device::GotoXY(uint8_t, uint8_t)':
D:\Arduino\libraries\openGLCD\glcd_Device.cpp:303:29: error: expected primary-expression before ';' token
x = glcdDev_Xval2ChipCol(x);
D:\Arduino\libraries\openGLCD\glcd_Device.cpp:315:46: error: expected primary-expression before ';' token
cmd = LCD_SET_ADDLO | glcdDev_Col2addrlo(x);
D:\Arduino\libraries\openGLCD\glcd_Device.cpp:318:46: error: expected primary-expression before ';' token
cmd = LCD_SET_ADDHI | glcdDev_Col2addrhi(x);
exit status 1
Error compiling for board Arduino Mega or Mega 2560.
