Error in code expected unqualified-id before '{' token
Hi
I have the following error coming up on my code and cannot find the solution, any help would be very much appreciated
error is "expected unqualified-id before '{' token", this appears after the following line of code
while (Serial.available());
Full program shown below
const int A1_PIN = 7;
const int A2_PIN = 6;
const int A3_PIN = 4;
const int A4_PIN = 3;
const int trigPin = 9;
const int echoPin = 10;
long duration;
int distance;
int speed=255;
String ch = "";
delay(random(500,2000));
pinMode(A1_PIN, OUTPUT);
pinMode(A2_PIN, OUTPUT);
pinMode(A3_PIN, OUTPUT);
pinMode(A4_PIN, OUTPUT);
pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
pinMode(echoPin, INPUT); // Sets the echoPin as an Input
while (! Serial);
Serial.print("Please enter F, B, S");
// Clears the trigPin
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
// Sets the trigPin on HIGH state for 10 micro seconds
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Reads the echoPin, returns the sound wave travel time in microseconds
duration = pulseIn(echoPin, HIGH);
// Calculating the distance
distance= duration*0.034/2;
// Prints the distance on the Serial Monitor
Serial.print("Distance: ");
Serial.println(distance);
analogWrite(8, speed);
ch=Serial.readstring();
if (ch=="F")
digitalWrite (A1_PIN, HIGH);
digitalWrite (A2_PIN, LOW);
digitalWrite (A3_PIN, LOW);
digitalWrite (A4_PIN, HIGH);
Serial.println("Motor go Forwards");
else if (ch=="B")
digitalWrite (A3_PIN, HIGH);
digitalWrite (A4_PIN, LOW);
Serial.println("Motor go Bachwards");
else if (ch=="S")
digitalWrite (A1_PIN, LOW);
Serial.println("Motor Stop");
else if (ch=="L")
digitalWrite (A2_PIN, HIGH);
Serial.println("Motor Turn Left");
else if (ch=="R")
Serial.println("Motor Turn Right");
else if (ch=="G")
Serial.println("Motor go Forwards Left");
else if (ch=="H")
Serial.println("Motor go Backwards Left");
else if (ch=="I")
Serial.println("Motor go Forwards Right");
else if (ch=="J")
Serial.println("Motor GO Backwards Right");
else if (ch=="1")
speed=25.5;
Serial.println("Speed 10%");
else if (distance > 3000)
digitalWrite (A1_PIN, LOW); //Stop
//movebackword
delay(100);
Try this. You had some syntax errors, with these ( ) when these { } were needed instead.
You had { & } in what looked like incorrect places, take a look and see how I cleaned them up.
You had Serial.readstring(), which the compiler didn't like.
Next time you make changes, use CTRL-T to align the code like I did, it makes the { } syntax errors a lot easier to spot.
const int A1_PIN = 7;  // these could all be byte, no value is above 255
long duration;
int distance;  // should this be a float?
int speed = 255;
String ch = "";
void setup ()
  delay (random (500, 2000));
  pinMode (A1_PIN, OUTPUT);
  pinMode (A2_PIN, OUTPUT);
  pinMode (A3_PIN, OUTPUT);
  pinMode (A4_PIN, OUTPUT);
  pinMode (trigPin, OUTPUT); // Sets the trigPin as an Output
  pinMode (echoPin, INPUT); // Sets the echoPin as an Input
  Serial.begin (9600);
  while (! Serial);
  Serial.print ("Please enter F, B, S");
void loop ()
  digitalWrite (trigPin, LOW);
  delayMicroseconds (2); // this should be multiples of 4
  digitalWrite (trigPin, HIGH);
  delayMicroseconds (10); // make this a multpiple of 4
  duration = pulseIn (echoPin, HIGH);
  distance = duration * 0.034 / 2;  // is result to be a float? Or 'rounded' off to have no decimal point data?
  Serial.print ("Distance:");
  Serial.println (distance);
  analogWrite (8, speed);
  while (Serial.available ())
    ch = Serial.read (); // need to fix this line - how many characters are coming in?
    if (ch == "F")
      Serial.println ("Motor go Forwards");
    else if (ch == "B")
      Serial.println ("Motor go Bachwards");
    else if (ch == "S")
      Serial.println ("Motor Stop");
    else if (ch == "L") // directions ask user to "Please enter F, B, S"
      Serial.println ("Motor Turn Left");
    else if (ch == "R") {
      Serial.println ("Motor Turn Right");
    else if (ch == "G")
      Serial.println ("Motor go Forwards Left");
    else if (ch == "H")
      Serial.println ("Motor go Backwards Left");
    else if (ch == "I")  // missing this one??? some other character?
      Serial.println ("Motor go Forwards Right");
    else if (ch == "J")
      Serial.println ("Motor GO Backwards Right");
    else if (ch == "1")
      speed = 25.5; // analog write only supports 0 to 255, not floats
      Serial.println ("Speed 10%");
      digitalWrite (A1_PIN, LOW); // Stop
      delay (500);
      // movebackword
      delay (500);
      delay (100);
      delay (500);
