Posting pictures of code makes it very hard to see, better to post the code and copy/paste the actual error message. (also, better to not show your actual ssid and password)
For your particular problem, for some reason WiFI.begin does not want the ssid to be a const char*, but instead a char*.
//replace this line
const char* ssid = "your_SSID";
//with
char ssid[] = "your_SSID";
What WiFi library is that? arduino one takes const char *
int begin(const char* ssid, const char *passphrase);
but ESP also has overload to take const char *, maybe your library needs updating?
Thank u that helped me clear my error but still I am getting one more please help me out
In file included from C:\Users\Pavithra\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi\src/WiFiClientSecure.h:41:0,
from C:\Users\Pavithra\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi\src/WiFiServerSecure.h:20,
from C:\Users\Pavithra\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi\src/ESP8266WiFi.h:41,
from C:\Users\Pavithra\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266HTTPClient\src\ESP8266HTTPClient.cpp:29:
C:\Users\Pavithra\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:38:5: error: 'BearSSL::WiFiClientSecure::~WiFiClientSecure()' marked override, but does not override
~WiFiClientSecure() override;
C:\Users\Pavithra\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:43:9: error: 'int BearSSL::WiFiClientSecure::connect(const String&, uint16_t)' marked override, but does not override
int connect(const String& host, uint16_t port) override;
C:\Users\Pavithra\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:48:12: error: 'size_t BearSSL::WiFiClientSecure::write_P(const char*, size_t)' marked override, but does not override
size_t write_P(PGM_P buf, size_t size) override;
C:\Users\Pavithra\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi\src/WiFiClientSecureBearSSL.h:60:12: error: 'size_t BearSSL::WiFiClientSecure::peekBytes(uint8_t*, size_t)' marked override, but does not override
size_t peekBytes(uint8_t buffer, size_t length) override;
In file included from C:\Users\Pavithra\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266HTTPClient\src\ESP8266HTTPClient.cpp:30:0:
C:\Users\Pavithra\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi\src/WiFiClientSecureAxTLS.h:36:3: error: 'axTLS::WiFiClientSecure::~WiFiClientSecure()' marked override, but does not override
C:\Users\Pavithra\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi\src/WiFiClientSecureAxTLS.h:39:7: error: 'int axTLS::WiFiClientSecure::connect(const String&, uint16_t)' marked override, but does not override
C:\Users\Pavithra\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi\src/WiFiClientSecureAxTLS.h:47:10: error: 'size_t axTLS::WiFiClientSecure::write_P(const char, size_t)' marked override, but does not override
C:\Users\Pavithra\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266WiFi\src/WiFiClientSecureAxTLS.h:53:10: error: 'size_t axTLS::WiFiClientSecure::peekBytes(uint8_t*, size_t)' marked override, but does not override
size_t peekBytes(uint8_t *buffer, size_t length) override;
C:\Users\Pavithra\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266HTTPClient\src\ESP8266HTTPClient.cpp: In member function 'bool HTTPClient::connect()':
C:\Users\Pavithra\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4\libraries\ESP8266HTTPClient\src\ESP8266HTTPClient.cpp:1252:14: error: 'class WiFiClient' has no member named 'setNoDelay'
_client->setNoDelay(true);
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module)
