I'm on Linux Manjaro and when I press the button on the IDE to upload the code to the Arduino UNO board I get this error:
avrdude: ser_open(): can't open device "/dev/ttyACM0": Permission denied
I tried to fix the problem using the following command:
sudo chmod a+rw /dev/ttyACM0
except that after a few hours the initial problem returns and I don't feel like running this command every time.
Arduino IDE version: 2.2.1
Is your user a member of the dialout group?
If I use the command ls -l /dev/ttyACM0 I get this:
crw-rw-rw- 1 root uucp 166, 0 9 ott 00.49 /dev/ttyACM0
so the correct group should be uucp but I tried using the command sudo usermod -a -G uucp $USER and it still doesn't work correctly. (Now there are the right permissions because I used the command sudo chmod a+rw /dev/ttyACM0)
Did you log out and back in again after adding your user to the group?
I just tried it and it seems to work, thanks so much for the help!
