I am trying to use my adafruit LSM9DS1 sensor and calibrate it. However, Adafruit_Sensor_Calibration.h does not exist. I already installed the adafruit unified sensor library. I am following instructions from Magnetic Calibration with MotionCal | How to Fuse Motion Sensor Data into AHRS Orientation (Euler/Quaternions) | Adafruit Learning System
This is an example for the Adafruit AHRS library
It will look for a supported magnetometer and output
PJRC Motion Sensor Calibration Tool-compatible serial data
PJRC & Adafruit invest time and resources providing this open source code,
please support PJRC and open-source hardware by purchasing products
from PJRC!
Written by PJRC, adapted by Limor Fried for Adafruit Industries.
#include <Adafruit_Sensor_Calibration.h>
Adafruit_Sensor *accelerometer, *gyroscope, *magnetometer;
// uncomment one combo 9-DoF!
//#include "LSM6DS_LIS3MDL.h" // can adjust to LSM6DS33, LSM6DS3U, LSM6DSOX...
#include "LSM9DS.h" // LSM9DS1 or LSM9DS0
//#include "NXP_FXOS_FXAS.h" // NXP 9-DoF breakout
// select either EEPROM or SPI FLASH storage:
#ifdef ADAFRUIT_SENSOR_CALIBRATION_USE_EEPROM
Adafruit_Sensor_Calibration_EEPROM cal;
#else
Adafruit_Sensor_Calibration_SDFat cal;
#endif
sensors_event_t mag_event, gyro_event, accel_event;
int loopcount = 0;
void setup(void) {
while (!Serial) delay(10); // will pause Zero, Leonardo, etc until serial console opens
Serial.println(F("Adafruit AHRS - IMU Calibration!"));
Serial.println("Calibration filesys test");
if (!cal.begin()) {
Serial.println("Failed to initialize calibration helper");
while (1) yield();
if (! cal.loadCalibration()) {
Serial.println("No calibration loaded/found... will start with defaults");
Serial.println("Loaded existing calibration");
if (!init_sensors()) {
Serial.println("Failed to find sensors");
while (1) delay(10);
accelerometer->printSensorDetails();
gyroscope->printSensorDetails();
magnetometer->printSensorDetails();
setup_sensors();
Wire.setClock(400000); // 400KHz
magnetometer->getEvent(&mag_event);
gyroscope->getEvent(&gyro_event);
accelerometer->getEvent(&accel_event);
// 'Raw' values to match expectation of MotionCal
Serial.print("Raw:");
Serial.print(int(accel_event.acceleration.x*8192/9.8)); Serial.print(",");
Serial.print(int(accel_event.acceleration.y*8192/9.8)); Serial.print(",");
Serial.print(int(accel_event.acceleration.z*8192/9.8)); Serial.print(",");
Serial.print(int(gyro_event.gyro.x*SENSORS_RADS_TO_DPS*16)); Serial.print(",");
Serial.print(int(gyro_event.gyro.y*SENSORS_RADS_TO_DPS*16)); Serial.print(",");
Serial.print(int(gyro_event.gyro.z*SENSORS_RADS_TO_DPS*16)); Serial.print(",");
Serial.print(int(mag_event.magnetic.x*10)); Serial.print(",");
Serial.print(int(mag_event.magnetic.y*10)); Serial.print(",");
Serial.print(int(mag_event.magnetic.z*10)); Serial.println("");
// unified data
Serial.print("Uni:");
Serial.print(accel_event.acceleration.x); Serial.print(",");
Serial.print(accel_event.acceleration.y); Serial.print(",");
Serial.print(accel_event.acceleration.z); Serial.print(",");
Serial.print(gyro_event.gyro.x, 4); Serial.print(",");
Serial.print(gyro_event.gyro.y, 4); Serial.print(",");
Serial.print(gyro_event.gyro.z, 4); Serial.print(",");
Serial.print(mag_event.magnetic.x); Serial.print(",");
Serial.print(mag_event.magnetic.y); Serial.print(",");
Serial.print(mag_event.magnetic.z); Serial.println("");
loopcount++;
receiveCalibration();
// occasionally print calibration
if (loopcount == 50 || loopcount > 100) {
Serial.print("Cal1:");
for (int i=0; i<3; i++) {
Serial.print(cal.accel_zerog[i], 3);
Serial.print(",");
Serial.print(cal.gyro_zerorate[i], 3);
Serial.print(",");
Serial.print(cal.mag_hardiron[i], 3);
Serial.print(",");
Serial.println(cal.mag_field, 3);
loopcount++;
if (loopcount >= 100) {
Serial.print("Cal2:");
for (int i=0; i<9; i++) {
Serial.print(cal.mag_softiron[i], 4);
if (i < 8) Serial.print(',');
loopcount = 0;
delay(10);
byte caldata[68]; // buffer to receive magnetic calibration data
byte calcount=0;
void receiveCalibration() {
uint16_t crc;
byte b, i;
while (Serial.available()) {
b = Serial.read();
if (calcount == 0 && b != 117) {
// first byte must be 117
return;
if (calcount == 1 && b != 84) {
// second byte must be 84
calcount = 0;
return;
// store this byte
caldata[calcount++] = b;
if (calcount < 68) {
// full calibration message is 68 bytes
return;
// verify the crc16 check
crc = 0xFFFF;
for (i=0; i < 68; i++) {
crc = crc16_update(crc, caldata[i]);
if (crc == 0) {
// data looks good, use it
float offsets[16];
memcpy(offsets, caldata+2, 16*4);
cal.accel_zerog[0] = offsets[0];
cal.accel_zerog[1] = offsets[1];
cal.accel_zerog[2] = offsets[2];
cal.gyro_zerorate[0] = offsets[3];
cal.gyro_zerorate[1] = offsets[4];
cal.gyro_zerorate[2] = offsets[5];
cal.mag_hardiron[0] = offsets[6];
cal.mag_hardiron[1] = offsets[7];
cal.mag_hardiron[2] = offsets[8];
cal.mag_field = offsets[9];
cal.mag_softiron[0] = offsets[10];
cal.mag_softiron[1] = offsets[13];
cal.mag_softiron[2] = offsets[14];
cal.mag_softiron[3] = offsets[13];
cal.mag_softiron[4] = offsets[11];
cal.mag_softiron[5] = offsets[15];
cal.mag_softiron[6] = offsets[14];
cal.mag_softiron[7] = offsets[15];
cal.mag_softiron[8] = offsets[12];
if (! cal.saveCalibration()) {
Serial.println("**WARNING** Couldn't save calibration");
Serial.println("Wrote calibration");
cal.printSavedCalibration();
calcount = 0;
return;
// look for the 117,84 in the data, before discarding
for (i=2; i < 67; i++) {
if (caldata[i] == 117 && caldata[i+1] == 84) {
// found possible start within data
calcount = 68 - i;
memmove(caldata, caldata + i, calcount);
return;
// look for 117 in last byte
if (caldata[67] == 117) {
caldata[0] = 117;
calcount = 1;
calcount = 0;
uint16_t crc16_update(uint16_t crc, uint8_t a)
int i;
crc ^= a;
for (i = 0; i < 8; i++) {
if (crc & 1) {
crc = (crc >> 1) ^ 0xA001;
crc = (crc >> 1);
return crc;
Error message:
calibration:13:10: fatal error: Adafruit_Sensor_Calibration.h: No such file or directory
compilation terminated.
exit status 1
