I can't get any libraries to import, even ones that come packaged with arduino. When I do #include to any library, the text stays gray instead of turning a shade of orange and if I try to compile it it'll throw up a buttload of errors.
Arduino: 1.0.6 (Mac OS X), Board: "Arduino Uno"
/Users/jsiekmann/Downloads/Arduino.app/Contents/Resources/Java/libraries/Robot_Motor/ArduinoRobotMotorBoard.cpp: In member function 'void RobotMotorBoard::begin()':
/Users/jsiekmann/Downloads/Arduino.app/Contents/Resources/Java/libraries/Robot_Motor/ArduinoRobotMotorBoard.cpp:14: error: 'Serial1' was not declared in this scope
/Users/jsiekmann/Downloads/Arduino.app/Contents/Resources/Java/libraries/Robot_Motor/ArduinoRobotMotorBoard.cpp:19: error: 'MUXA' was not declared in this scope
...and so on. This happens with any library. It was working before, it was only when I tried to install the LSM9DS0 library that something got messed up.
I've deleted my arduino workspace and the application several times, updated the app, and rebooted my computer. What's going on?
It's got something to do with if the libraries are in the Arduino install folder or if you made a library folder in the sketchbook. I'm hazy on the details but give that a try...
Ok, that works for a few of the libraries. Not for the one I'm trying to work with though. Here's the code for the sketch I'm trying to compile:
(By the way, this is all copied more or less from the Adafruit page on getting this gyroscope to work with an Arduino uno)
#include <Wire.h>
#include <SPI.h>
#include "Adafruit_LSM9DS0.h"
#include "Adafruit_Sensor.h"
// i2c
Adafruit_LSM9DS0 lsm = Adafruit_LSM9DS0();
void setupSensor()
// 1.) Set the accelerometer range
lsm.setupAccel(lsm.LSM9DS0_ACCELRANGE_2G);
// 2.) Set the magnetometer sensitivity
lsm.setupMag(lsm.LSM9DS0_MAGGAIN_2GAUSS);
// 3.) Setup the gyroscope
lsm.setupGyro(lsm.LSM9DS0_GYROSCALE_245DPS);
while (!Serial); // flora & leonardo
Serial.println("LSM raw read demo");
// Try to initialise and warn if we couldn't detect the chip
if (!lsm.begin())
Serial.println("Oops ... unable to initialize the LSM9DS0. Check your wiring!");
while (1);
Serial.println("Found LSM9DS0 9DOF");
Serial.println("");
Serial.println("");
lsm.read();
Serial.print("Accel X: "); Serial.print((int)lsm.accelData.x); Serial.print(" ");
Serial.print("Y: "); Serial.print((int)lsm.accelData.y); Serial.print(" ");
Serial.print("Z: "); Serial.println((int)lsm.accelData.z); Serial.print(" ");
Serial.print("Mag X: "); Serial.print((int)lsm.magData.x); Serial.print(" ");
Serial.print("Y: "); Serial.print((int)lsm.magData.y); Serial.print(" ");
Serial.print("Z: "); Serial.println((int)lsm.magData.z); Serial.print(" ");
Serial.print("Gyro X: "); Serial.print((int)lsm.gyroData.x); Serial.print(" ");
Serial.print("Y: "); Serial.print((int)lsm.gyroData.y); Serial.print(" ");
Serial.print("Z: "); Serial.println((int)lsm.gyroData.z); Serial.println(" ");
Serial.print("Temp: "); Serial.print((int)lsm.temperature); Serial.println(" ");
delay(200);
And here is the error I'm getting:
enabled in File > Preferences.
In file included from lsm9doftest.ino:3:
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:63: error: cannot declare pointer to 'void' member
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:63: error: typedef 'lsm9ds0_get_event_func' is initialized (use __typeof__ instead)
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:63: error: 'sensors_event_t' was not declared in this scope
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:63: error: expected primary-expression before ',' token
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:63: error: expected primary-expression before ')' token
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:64: error: cannot declare pointer to 'void' member
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:64: error: typedef 'lsm9ds0_get_sensor_func' is initialized (use __typeof__ instead)
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:64: error: 'sensor_t' was not declared in this scope
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:64: error: expected primary-expression before ')' token
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:192: error: 'sensors_event_t' has not been declared
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:193: error: 'sensor_t' has not been declared
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:196: error: expected class-name before '{' token
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:206: error: 'lsm9ds0_get_event_func' has not been declared
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:206: error: 'lsm9ds0_get_sensor_func' has not been declared
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:212: error: 'sensors_event_t' has not been declared
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:218: error: 'sensor_t' has not been declared
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:226: error: 'lsm9ds0_get_event_func' does not name a type
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:227: error: 'lsm9ds0_get_sensor_func' does not name a type
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:256: error: 'sensors_event_t' has not been declared
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:257: error: 'sensors_event_t' has not been declared
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:258: error: 'sensors_event_t' has not been declared
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:259: error: 'sensors_event_t' has not been declared
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:260: error: 'sensor_t' has not been declared
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:261: error: 'sensor_t' has not been declared
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:262: error: 'sensor_t' has not been declared
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:263: error: 'sensor_t' has not been declared
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h: In copy constructor 'Adafruit_LSM9DS0::Sensor::Sensor(const Adafruit_LSM9DS0::Sensor&)':
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:202: error: class 'Adafruit_LSM9DS0::Sensor' does not have any field named '_eventFunc'
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:202: error: 'const class Adafruit_LSM9DS0::Sensor' has no member named '_eventFunc'
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:203: error: class 'Adafruit_LSM9DS0::Sensor' does not have any field named '_sensorFunc'
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:203: error: 'const class Adafruit_LSM9DS0::Sensor' has no member named '_sensorFunc'
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h: In constructor 'Adafruit_LSM9DS0::Sensor::Sensor(Adafruit_LSM9DS0*, void (Adafruit_LSM9DS0::*)(), int, int)':
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:209: error: class 'Adafruit_LSM9DS0::Sensor' does not have any field named '_eventFunc'
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:210: error: class 'Adafruit_LSM9DS0::Sensor' does not have any field named '_sensorFunc'
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h: In member function 'virtual void Adafruit_LSM9DS0::Sensor::getEvent(int*)':
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:216: error: '_eventFunc' was not declared in this scope
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h: In member function 'virtual void Adafruit_LSM9DS0::Sensor::getSensor(int*)':
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:220: error: '_sensorFunc' was not declared in this scope
The IDE expects to find library folders as follows :
(1) User installed libraries #include <aLibrary.h> //there should be a folder named aLibrary in the libraries folder of the Arduino sketches folder and it should contain at least a file named aLibrary.h
(2) System (core) libraries #include <aLibrary.h> //there should be a folder named aLibrary in the libraries folder of the Arduino installation folder and it should contain at least a file named aLibrary.h
(3) Local libraries #include "aLibrary.h" //there should be a file named aLibrary.h in the same folder as the sketch.
After installing a new library it is necessary to stop and restart the IDE. Do all of your library folders and files meet those requirements ?
Ok, I've tried it both ways. Here are some screenshots comparing them and showing my Arduino folder. And I've restarted and reinstalled the arduino app multiple times and rebooted my computer, so it's (hopefully?) not a problem with needing to read the library on startup.
Here is the error with the imported libraries (I just copied the first line or so from the example included in the LSM9DS0 library):
Use <> for libararies in libraries directory.
You cannot omit the ".h" on the end of the filename like this:
#include "Adafruit_LSM9DS0"
You need
#include <Adafruit_LSM9DS0.h>
And case must match exactly, which includes not putting O for 0, for instance. Use
copy and paste to get names right if your computer has a poor choice of font for
distinguishing numerals from letters.
There are actually 3 ways as explained in my previous post.
In example 1 you have #included the Adafruit_LSM9050 as if it were a local library in the same folder as your sketch but it is actually in your Arduino installation libraries folder.
In example 2 you have #included the Adafruit_LSM9050 as if it were a user contributed library in the libraries folder of your sketches folder but it is actually in your Arduino installation libraries folder.
Move the library folder to the libraries folder of your sketches folder and try example 2 again but make sure that you include the .h extension of the filename.
Thanks Mark, I fixed that mistake, but now I'm getting an even larger error:
In file included from sketch_nov13b.ino:1:
/Users/jsiekmann/Documents/Arduino/libraries/Adafruit_LSM9DS0/Adafruit_LSM9DS0.h:23:18: error: Wire.h: No such file or directory
UKHeliBob - I'm not sure what you mean. My libraries folder is in the Arduino folder along with all my sketches. To my knowledge, it isn't in my Arduino installation libraries folder.
Never mind, I'm an idiot. I forgot to install the second library that the ADAFRUIT_LSM9DS0.h library depends on (Adafruit_Sensor.h). Works now, but I'm having a different issue with the arduino freezing up while executing the code from the library. Made a new thread for it.
