error message with frequency counter library
dear
above code to calculate anemometer wind speed using frequency counter library ,i receive below error message
windspeedcode2:15: error: 'FreqCount' is not a class, namespace, or enumeration
 FreqCount::f_comp= 8;             // Set compensation to 12
windspeedcode2:16: error: 'FreqCount' is not a class, namespace, or enumeration
  FreqCount::start(100);            // Start counting with gatetime of 100ms
windspeedcode2:17: error: 'FreqCounter' has not been declared
  while (FreqCounter::f_ready == 0)         // wait until counter ready
windspeedcode2:19: error: 'FreqCount' is not a class, namespace, or enumeration
  freq=FreqCount::f_freq;//read frequency value
exit status 1
option enabled in File -> Preferences.
You are using the FreqCount library incorrectly (in fact, I don't think that syntax is valid outside of a class definition...). See the documentation/examples that come with it. You didn't post a link to where you got it (ideally the github so we can see the code w/out downloading anything), so I couldn't help further.
Note that the name of a library is insufficient to identify what library you're using. There are often many versions of a library with subtle (or not so subtle) differences, but the same name, thanks in part to how easy github makes it to fork a repo (often these forks don't even change the readme)
Please don't post pictures of code, post it in code tags directly in your post
thank you
please any link to download frequency counter library
saif221984:
thank you
You seem to have done that. Mr. Google CAN help you, if you haven't.
