Error Messages code problem
Arduino: 1.8.8 (Windows 10), Board: "Arduino Nano, ATmega328P"
C:\Program Files (x86)\Arduino\libraries\Robot_Control\examples\explore\R02_Line_Follow\R02_Line_Follow.ino: In function 'void setup()':
C:\Program Files (x86)\Arduino\libraries\Robot_Control\examples\explore\R02_Line_Follow\R02_Line_Follow.ino:35:31: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
Robot.drawBMP("lf.bmp", 0, 0); // display background image
C:\Program Files (x86)\Arduino\libraries\Robot_Control\examples\explore\R02_Line_Follow\R02_Line_Follow.ino:37:29: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
Robot.playFile("chase.sqm"); // play a song from the SD card
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp: In member function 'void RobotControl::analogWrite(uint8_t, uint8_t)':
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:65:11: error: 'TKD4' was not declared in this scope
if(port==TKD4)
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp: In member function 'uint8_t RobotControl::_getTypeCode(uint8_t)':
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:82:8: error: 'TKD0' was not declared in this scope
case TKD0:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:83:8: error: 'TKD1' was not declared in this scope
case TKD1:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:84:8: error: 'TKD2' was not declared in this scope
case TKD2:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:85:8: error: 'TKD3' was not declared in this scope
case TKD3:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:86:8: error: 'TKD4' was not declared in this scope
case TKD4:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:87:8: error: 'TKD5' was not declared in this scope
case TKD5:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp: In member function 'uint8_t RobotControl::_topDPortToAPort(uint8_t)':
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:122:8: error: 'TKD0' was not declared in this scope
case TKD0:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:124:8: error: 'TKD1' was not declared in this scope
case TKD1:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:126:8: error: 'TKD2' was not declared in this scope
case TKD2:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:128:8: error: 'TKD3' was not declared in this scope
case TKD3:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:130:8: error: 'TKD4' was not declared in this scope
case TKD4:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:132:8: error: 'TKD5' was not declared in this scope
case TKD5:
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:133:12: error: 'A11' was not declared in this scope
return A11;
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp: In member function 'int RobotControl::knobRead()':
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\Sensors.cpp:254:22: error: 'POT' was not declared in this scope
return ::analogRead(POT);
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp: In constructor 'RobotControl::RobotControl()':
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:26:42: error: 'LCD_CS' was not declared in this scope
RobotControl::RobotControl():Arduino_LCD(LCD_CS,DC_LCD,RST_LCD){
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:26:49: error: 'DC_LCD' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:26:56: error: 'RST_LCD' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp: In member function 'void RobotControl::begin()':
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:36:21: error: 'MUXA' was not declared in this scope
uint8_t MuxPins[]={MUXA,MUXB,MUXC,MUXD};
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:36:26: error: 'MUXB' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:36:31: error: 'MUXC' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:36:36: error: 'MUXD' was not declared in this scope
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:37:29: error: 'MUX_IN' was not declared in this scope
Multiplexer::begin(MuxPins,MUX_IN,4);
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:40:10: error: 'BUZZ' was not declared in this scope
pinMode(BUZZ,OUTPUT);
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\ArduinoRobot.cpp:43:2: error: 'Serial1' was not declared in this scope
Serial1.begin(9600);
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\keyboard.cpp: In member function 'int8_t RobotControl::keyboardRead()':
C:\Program Files (x86)\Arduino\libraries\Robot_Control\src\keyboard.cpp:49:42: error: 'KEY' was not declared in this scope
lectura_pul = this->averageAnalogInput(KEY);
exit status 1
Error compiling for board Arduino Nano.
option enabled in File -> Preferences.
Please READ THIS POST to help you get the best out of the forum.
SIMPLE TROUBLESHOOTING.
These steps may also save you some unnecessary time and effort in the forum.
  • Always provide as much detail as possible to your issue it may be important.
  • If applicable provide your SKETCH inside CODE TAGS ( </> ) or a CREATE share link.
  • If applicable provide a schematic even if hand drawn.
  • How to insert a picture into your post
  • If applicable provide a proper LINK to the hardware / sensors etc. you are using.
    COMMON ISSUES
  • Check you have a COMMON GROUND where required.
  • Where possible use USB 2.0 ports or a USB 2.0 POWERED HUB to rule out USB 3.0 issues.
  • Try other computers where possible.
  • Try other USB leads where possible.
  • You may not have the correct driver installed. CH340/341 or CP2102
  • There may be a problem with the board check your wiring first.
  • Remove any items connected to pins 0 and 1.
    COMPUTER RELATED
  • close any other serial programs before opening the IDE.
  • Ensure you turn off any additional security / antivirus just to test.
  • There may be a problem with the PC try RESTARTING it.
  • You may be selecting the wrong COM port.
  • Avoid cloud/network based installations where possible OR ensure your Network/Cloud software is RUNNING.
  • Clear your browsers CACHE.
  • Close the IDE before using any other serial programs.
  • Preferably install IDE's as ADMINISTRATOR or your OS equivalent
    Arduino specific boards
  • NANO (Old Types) some require you to use the OLD BOOTLOADER option.
  • NANO (New Types) See the specific sections lower in the forum.
  • NANO (New Types) Install your board CORE's.
    CREATE editor install locations.
  • On macOs ~/Applications/ArduinoCreateAgent-1.1/ArduinoCreateAgent.app/Contents/MacOS/config.ini
  • On Linux ~/ArduinoCreateAgent-1.1/config.ini
  • On Windows C:\Users[your user]\AppData\Roaming\ArduinoCreateAgent-1.1
Performing the above actions may help resolve your problem without further help.
Language problem ?
Try a language closer to your native language:
Thanks to all those who helped and added to this list.
Bob.
Right there.
