Error: no matching function for call to 'HardwareSerial::HardwareSerial(int)'
Hello.
I have a Wroom 32 module programming error in the hardwareserial.
can anyone help me please!
ERROR:
testGPS:4:27: error: no matching function for call to 'HardwareSerial::HardwareSerial(int)'
 HardwareSerial GPSSerial(1);
In file included from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:233:0,
                 from sketch\testGPS.ino.cpp:1:
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:117:12: note: candidate: HardwareSerial::HardwareSerial(volatile uint8_t*, volatile uint8_t*, volatile uint8_t*, volatile uint8_t*, volatile uint8_t*, volatile uint8_t*)
     inline HardwareSerial(
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:117:12: note:   candidate expects 6 arguments, 1 provided
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:93:7: note: candidate: constexpr HardwareSerial::HardwareSerial(const HardwareSerial&)
 class HardwareSerial : public Stream
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:93:7: note:   no known conversion for argument 1 from 'int' to 'const HardwareSerial&'
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:93:7: note: candidate: constexpr HardwareSerial::HardwareSerial(HardwareSerial&&)
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:93:7: note:   no known conversion for argument 1 from 'int' to 'HardwareSerial&&'
C:\Users\DELL\Documents\Arduino\testGPS\testGPS.ino: In function 'void setup()':
testGPS:10:38: error: no matching function for call to 'HardwareSerial::begin(int, int, int, int)'
   GPSSerial.begin(9600,SERIAL_8N1,3,1);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:121:10: note: candidate: void HardwareSerial::begin(long unsigned int)
     void begin(unsigned long baud) { begin(baud, SERIAL_8N1); }
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:121:10: note:   candidate expects 1 argument, 4 provided
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:122:10: note: candidate: void HardwareSerial::begin(long unsigned int, uint8_t)
     void begin(unsigned long, uint8_t);
C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:122:10: note:   candidate expects 2 arguments, 4 provided
exit status 1
Do you have the board type set correctly in the IDE? You should not be pulling from avr/cores.
Is this your sketch name?
Thank you very much
I did not notice the type of board selected in the ide, the error is gone
But after upload the code , I did not receive anything from the GPS
If you can help me, here is the code:
#include <HardwareSerial.h>
#include <TinyGPS++.h>
TinyGPSPlus gps;
String b;
  Serial.println("gps start");
  while(GPSSerial.available()>0)
    Serial.println("data received");
    gps.encode(GPSSerial.read());
  if(gps.location.isUpdated()){
    Serial.print("Latitude:");
    Serial.println(gps.location.lat(), 6);
    Serial.print("Longitude:");
    Serial.println(gps.location.lng(), 6);
I have not used a Wroom 32 or a GPS module so I can't really help there. However, I don't even see the "gps start" message in the serial console so there may be a more fundamental issue going on.
