I'm new op the Arduino PLC and OPTA system.
I have downloaded Arduino PLC IDE and installed it as an Administrator.
Then I run the software as an Adminitrator to and start a new project.
When the OPTA is connected, COM7 and COM8 are shown.
When I still have to connect the OPTA, they are missing and don't appear at al.
Also no after 30 minutes or so.
In OTHER I sellect COM7, all others are not working, and click DOWNLOAD.
According the manual, I now should see the connected OPTA.
When I disconnect and try connecting again the PLC-IDE software crashes.
What am I doing wrong?
I have tried several times and also removed and reinstalled the software.
Still no result.
Please let me know how to solve this.
After lots and lots of tests, finaly there is a connection.
I'm not sure what the solution was, I have tried many versions and tips.
However, now it seems to run.
Next step, some standard I/O tests to get used to te IDE.
I'm like walbeek but I don't get out of ERROR in the lower right part.
I think it detects the port and I think it loads the firewall, but when I connect it doesn't go beyond the error and doesn't give me any more information.
I have reinstalled the software and it still gives an error
Any ideas?
Thank you
The first step in configuring Opta with the PLC IDE is to download the runtime.
If the error message mentioned by @walbeek appears in the status bar when connecting, it is recommended to implement the memory partitioning tutorial. Please ensure that the code execution is completed successfully by following the serial monitor output.
Then, you can follow the steps indicated in this tutorial to set up the board:
