avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc0
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc0
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xc0
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xc0
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc0
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xc0
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xc0
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xc0
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xc0
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xc0
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
Hi, @echgo2
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
This will help with advice on how to present your code and problems.
Thanks.. Tom...
Hi @echgo2. In order to gather more information that might help us to troubleshoot your problem, I'm going to ask you to post the full output from an upload attempt when in verbose mode.
Please do this:
- Select File > Preferences from the Arduino IDE menus.
- Uncheck the checkbox next to "Show verbose output during:
☑compilation". - Check the checkbox next to "Show verbose output during: ☐ upload".
- Click the OK button.
- Attempt an upload, as you did before.
- After the upload fails, you'll see a button on the right side of the orange bar in the Arduino IDE: Copy error messages. Click that button.
This copies the full output to the clipboard. - Open a forum reply here by clicking the Reply button.
- Click the
</>icon on the post composer toolbar.
This will add the forum's code block markup (```) to your reply to make sure the error messages are correctly formatted.
- Press Ctrl+V.
This will paste the error output from the upload into the code block. - Move the cursor outside of the code tags before you add any additional text to your reply.
- Click the Reply button to post the output.
- Stop any monitor.
- Restart the IDE.
- Check IDE for TOOLS >> PORT and TOOLS >> BOARD
- Re-move, re-insert your Arduino.
My boards go to sleep, too. Maybe it is my USB port going to sleep.
What model Arduino are you usings?
Can you upload "Blink without delay" example succesfully?
Thanks.. Tom...
