Error: 'serial' does not name a type
Hi all
im using arduino uno and L293D(motor driver shield) and this error appears when im verifying could someone help me?
here is code:
#include "L293D.h"
#include <Servo.h>
Servo myservo;
char dataIn='S';
char determinant;
char det;
int vel = 200; //Bluetooth Stuff
int overdrive = 13; //Press Toggle Switch #1, the pin13 LED will light up
motor.attach(2, 3, 4, 5);
Serial.begin(9600);md.init();
myservo.attach(6);delay(100);
myservo.write(90);delay(100);
void loop(){ det = check(); // You'll need to reconstruct this if your not using the Pololu Dual VNH5019
 while (det == 'F')   // F, move forward
motor.setSpeeds(vel, vel);
det = check();
while (det == 'B') // B, move back
motor.setSpeeds(-vel, -vel);
det = check();
while (det == 'L') // L, move wheels left
motor.setSpeeds(-vel, vel);
det = check();
while (det == 'R') // R, move wheels right
motor.setSpeeds(vel, -vel);
det = check();
while (det == 'I') // I, turn right forward
motor.setSpeeds(vel, vel / 2);
det = check();
while (det == 'J') // J, turn right back
motor.setSpeeds(-vel, -vel / 2);
det = check();
while (det == 'G') // G, turn left forward
motor.setSpeeds(vel / 2, vel);
det = check();
while (det == 'H') // H, turn left back
motor.setSpeeds(-vel / 2, -vel);
det = check();
while (det == 'S') // S, stop
motor.setSpeeds(0, 0);
det = check();
  //---------------------Toggle switch code------------------//
  /*while (det == 'W'){myservo.write(180);delay(100);det = check();}
  while (det == 'w'){myservo.write(90);delay(100);det = check();}
  while (det == 'U'){myservo.write(0);delay(100);det = check();}
  while (det == 'u'){myservo.write(90);delay(100);det = check();}
char check()
if (Serial.available() > 0)
char dataIn = Serial.read();
return dataIn;
return 'S'; // default to stop if no data received
here are errors:
C:\Users\User\AppData\Local\Temp.arduinoIDE-unsaved2023229-8236-1w1t94e.qjp1\sketch_mar29a\sketch_mar29a.ino:15:1: error: expected initializer before 'motor'
C:\Users\User\AppData\Local\Temp.arduinoIDE-unsaved2023229-8236-1w1t94e.qjp1\sketch_mar29a\sketch_mar29a.ino:16:1: error: 'Serial' does not name a type
C:\Users\User\AppData\Local\Temp.arduinoIDE-unsaved2023229-8236-1w1t94e.qjp1\sketch_mar29a\sketch_mar29a.ino:16:20: error: 'md' does not name a type
Where are the curly braces ({})?
Perhaps try the following:
  md.init();
Furthermore, neither motor nor md are defined.
Read the forum guidelines to see how to properly post code and some good information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags. Auto-format will show the missing curly brackets of the setup() function.
Please go back and fix your original post.
Please post the entire error message(s). Paraphrasing leaves out important information. Copy the entire error message and paste into a post.
where are motor and md defined?
Where did you get the L293D.h library? Did you run library examples to see how to use the library?
i updated
yes i runned actually. library in arduino ide 2.0.5
oh, right i forgot ill add to code and try again,thanks
yes i forgot to type define,thanks
