Error with Serial does not name a type
What did you have to change in order for it to c0mpile without errors?
What fixed the "Serial does not name a type" error?
I'm having the same problem with my code:
#include <Brain.h>
#include <Servo.h>
// mindflexservo
myservo.attach(9); // attaches the servo on pin 9 to the servo object
pinMode(12, OUTPUT);
pinMode(11, OUTPUT);
void loop() { // Expect packets about once per second.
// The .readCSV() function returns a string (well, char*) listing
//the most recent brain data, in the following format:
// "signal strength, attention, meditation, delta, theta, low // alpha, high alpha, low beta, high beta, low gamma, // high gamma"
if (brain.update()) {
 // Serial.println(brain.readErrors());
 // Serial.println(brain.readCSV());
 //sprintf(a, "%c",brain.readCSV());
a = brain.readCSV();
v = a.indexOf(',');
v = a.indexOf(',',v+1);
z = a.indexOf(',',v+1);
a1 = a.substring(v+1,z);
num = a1.toInt();
v=a.indexOf(',',z+1);
a = a.substring(z+1,v);
num1 = a.toInt();
Serial.print("alpha =  ");
Serial.println(num1);
output = map(num,0,999999,0,180);
myservo.write(output); 	// tell servo to go to position in variable 'pos'
delay(15);
 // analogWrite(12,output);
//brain.readCS).toCharArray(a,200);
And I m receiving the following compile errors
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino:8:1: error: 'Serial' does not name a type
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino:11:1: error: 'myservo' does not name a type; did you mean 'Servo'?
Servo
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino:12:8: error: expected constructor, destructor, or type conversion before '(' token
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino:13:8: error: expected constructor, destructor, or type conversion before '(' token
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino: In function 'void loop()':
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino:22:7: error: 'brain' was not declared in this scope
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino:22:7: note: suggested alternative: 'Brain'
Brain
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino:28:5: error: 'a' was not declared in this scope
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino:30:5: error: 'v' was not declared in this scope
v = a.indexOf(',');
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino:34:5: error: 'z' was not declared in this scope
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino:36:5: error: 'a1' was not declared in this scope
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino:36:5: note: suggested alternative: 'A1'
A1
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino:37:5: error: 'num' was not declared in this scope
num = a1.toInt();
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino:37:5: note: suggested alternative: 'enum'
num = a1.toInt();
enum
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino:42:5: error: 'num1' was not declared in this scope
num1 = a.toInt();
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino:42:5: note: suggested alternative: 'enum'
num1 = a.toInt();
enum
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino:46:5: error: 'output' was not declared in this scope
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino:48:5: error: 'myservo' was not declared in this scope
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino:48:5: note: suggested alternative: 'Servo'
Servo
C:\Users\Japper\Documents\Arduino\mindflexservo\mindflexservo.ino:56:3: error: expected '}' at end of input
exit status 1
Compilation error: 'Serial' does not name a type
Thanks!
What fixed the Serial does not name a type error?
Iam having the same problem with my code
#include <Brain.h>
#include <Servo.h>
// mindflexservo
v = a.indexOf(',');
num = a1.toInt();
num1 = a.toInt();
delay(15);
Iam receiving the following compile errors:
Servo
Brain
v = a.indexOf(',');
A1
num = a1.toInt();
num = a1.toInt();
enum
num1 = a.toInt();
num1 = a.toInt();
enum
Servo
exit status 1
#include <Brain.h>
#include <Servo.h>
// mindflexservo
v = a.indexOf(',');
num = a1.toInt();
num1 = a.toInt();
delay(15);
You forgot to put your code inside setup().
Outside function declarations you can only have variable declarations.
@iamiretheo
Hijacking the others thread is violation of the forum rules. Please create the new topic and put your question to it.
Topic split from another topic. Please do not add your own questions to the end of other people's topics.
Could you take a few moments to Learn How To Use The Forum
Thank you.
