Rnold
February 12, 2020, 9:09pm
1
I am trying to install the Arduino ide on my raspberry pi 3. Downloaded the ARM32 package, untarred and installed it. When starting the ide I get the message: "https://downloads.arduino.cc/packages/package_index.json ". I need this file for my MKR1000 board. I installed the Arduino ide on ubuntu yesterday (for an x86 system) and that worked flawless.
The error message from Java is very long. I can copy it if needed in but it ends with:
Error downloading https://downloads.arduino.cc/packages/package_index.json
2020-02-12T20:48:03.326Z INFO c.a.c.p.ContributionInstaller:314 [ContributionManager Update Thread] Downloaded package index URL=[https://downloads.arduino.cc/packages/package_index.json ]
2020-02-12T20:48:03.335Z INFO c.a.c.p.ContributionInstaller:324 [ContributionManager Update Thread] Check unknown files. Additional package index folder files=[package_index.json], Additional package index url downloaded=[]
I am not aware of unknown files. I found this package at the designated URL. I can download it by hand if necessary but than I still don't know where to install it.
Anybody any idea?
pert
February 12, 2020, 9:27pm
2
This is a known bug with the Linux ARM version of Arduino IDE 1.8.11:
opened 07:18PM - 04 Feb 20 UTC
Type: Bug
Component: Board/Lib Manager
OS: Linux ARM
OpenJDK
Using Arduino IDE 1.8.11 Hourly Build 2020/02/03 07:20 on Raspbian 9.4 (stretch)… and Raspbian 10.2 (buster)
1. Delete `~/.arduino15/cache` (because if the Arduino IDE uses the cached indexes, it won't trigger the bug)
1. (OPTIONAL) If you want to avoid waiting over 5 minutes for Library Manager to open (due to https://github.com/arduino/Arduino/issues/9701), delete `~/.arduino15/library_index.json`. The bug occurs with or without it, it just occurs a lot faster without.
1. Start the Arduino IDE
1. **Sketch > Include Library > Manage Libraries...**
The index download fails:
Error downloading https://downloads.arduino.cc/libraries/library_index.json
java.lang.RuntimeException: java.lang.Exception: Error downloading https://downloads.arduino.cc/libraries/library_index.json
at cc.arduino.contributions.libraries.ui.LibraryManagerUI.lambda$onUpdatePressed$2(LibraryManagerUI.java:207)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.Exception: Error downloading https://downloads.arduino.cc/libraries/library_index.json
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:149)
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:130)
at cc.arduino.contributions.JsonDownloader.download(JsonDownloader.java:49)
at cc.arduino.contributions.GZippedJsonDownloader.download(GZippedJsonDownloader.java:66)
at cc.arduino.contributions.libraries.LibraryInstaller.updateIndex(LibraryInstaller.java:84)
at cc.arduino.contributions.libraries.ui.LibraryManagerUI.lambda$onUpdatePressed$2(LibraryManagerUI.java:203)
... 1 more
Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path validation failed: java.security.cert.CertPathValidatorException: signature check failed
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1946)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:316)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:310)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1639)
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:223)
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1037)
at sun.security.ssl.Handshaker.process_record(Handshaker.java:965)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1064)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1367)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1395)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1379)
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.connect(HttpsURLConnectionImpl.java:167)
at cc.arduino.utils.network.HttpConnectionManager.makeConnection(HttpConnectionManager.java:150)
at cc.arduino.utils.network.HttpConnectionManager.makeConnection(HttpConnectionManager.java:106)
at cc.arduino.utils.network.FileDownloaderCache.updateCacheInfo(FileDownloaderCache.java:184)
at cc.arduino.utils.network.FileDownloaderCache.getFileCached(FileDownloaderCache.java:153)
at cc.arduino.utils.network.FileDownloader.downloadFile(FileDownloader.java:167)
at cc.arduino.utils.network.FileDownloader.download(FileDownloader.java:129)
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:147)
... 6 more
Caused by: sun.security.validator.ValidatorException: PKIX path validation failed: java.security.cert.CertPathValidatorException: signature check failed
at sun.security.validator.PKIXValidator.doValidate(PKIXValidator.java:362)
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:259)
at sun.security.validator.Validator.validate(Validator.java:262)
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:330)
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:237)
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:132)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1621)
... 23 more
Caused by: java.security.cert.CertPathValidatorException: signature check failed
at sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(PKIXMasterCertPathValidator.java:135)
at sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:233)
at sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:141)
at sun.security.provider.certpath.PKIXCertPathValidator.engineValidate(PKIXCertPathValidator.java:80)
at java.security.cert.CertPathValidator.validate(CertPathValidator.java:292)
at sun.security.validator.PKIXValidator.doValidate(PKIXValidator.java:357)
... 29 more
Caused by: java.security.SignatureException: Signature does not match.
at sun.security.x509.X509CertImpl.verify(X509CertImpl.java:424)
at sun.security.provider.certpath.BasicChecker.verifySignature(BasicChecker.java:166)
at sun.security.provider.certpath.BasicChecker.check(BasicChecker.java:147)
at sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(PKIXMasterCertPathValidator.java:125)
... 34 more
<details>
<summary>Click for contents of `~/.arduino15/logs/application.log`:</summary>
2020-02-04T15:27:04.290Z INFO c.a.u.n.FileDownloaderCache:92 [LibraryManager Update Thread] Cache folder /home/pi/.arduino15/cache
2020-02-04T15:27:04.688Z INFO c.a.u.n.FileDownloaderCache:149 [LibraryManager Update Thread] Get file cached is expire true, exist false, info FileCached{eTag='null', lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.gz', localPath='/home/pi/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.gz', md5='null', createdAt='2020-02-04T07:27:04.544', cacheControl=null}
2020-02-04T15:27:04.731Z DEBUG c.a.u.n.HttpConnectionManager:125 [LibraryManager Update Thread] Using proxy DIRECT
2020-02-04T15:27:04.738Z INFO c.a.u.n.HttpConnectionManager:148 [LibraryManager Update Thread] Connect to https://downloads.arduino.cc/libraries/library_index.json.gz, method=HEAD, request id=BDF785772AFB4855
2020-02-04T15:27:05.066Z ERROR c.a.u.n.FileDownloader:199 [LibraryManager Update Thread] The request stop
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192) ~[?:1.8.0_232]
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1946) ~[?:1.8.0_232]
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:316) ~[?:1.8.0_232]
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:310) ~[?:1.8.0_232]
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1639) ~[?:1.8.0_232]
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:223) ~[?:1.8.0_232]
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1037) ~[?:1.8.0_232]
at sun.security.ssl.Handshaker.process_record(Handshaker.java:965) ~[?:1.8.0_232]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1064) ~[?:1.8.0_232]
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1367) ~[?:1.8.0_232]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1395) ~[?:1.8.0_232]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1379) ~[?:1.8.0_232]
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559) ~[?:1.8.0_232]
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185) ~[?:1.8.0_232]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.connect(HttpsURLConnectionImpl.java:167) ~[?:1.8.0_232]
at cc.arduino.utils.network.HttpConnectionManager.makeConnection(HttpConnectionManager.java:150) ~[arduino-core.jar:?]
at cc.arduino.utils.network.HttpConnectionManager.makeConnection(HttpConnectionManager.java:106) ~[arduino-core.jar:?]
at cc.arduino.utils.network.FileDownloaderCache.updateCacheInfo(FileDownloaderCache.java:184) ~[arduino-core.jar:?]
at cc.arduino.utils.network.FileDownloaderCache.getFileCached(FileDownloaderCache.java:153) ~[arduino-core.jar:?]
at cc.arduino.utils.network.FileDownloader.downloadFile(FileDownloader.java:167) ~[arduino-core.jar:?]
at cc.arduino.utils.network.FileDownloader.download(FileDownloader.java:129) ~[arduino-core.jar:?]
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:147) ~[arduino-core.jar:?]
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:130) ~[arduino-core.jar:?]
at cc.arduino.contributions.JsonDownloader.download(JsonDownloader.java:49) ~[arduino-core.jar:?]
at cc.arduino.contributions.GZippedJsonDownloader.download(GZippedJsonDownloader.java:63) ~[arduino-core.jar:?]
at cc.arduino.contributions.libraries.LibraryInstaller.updateIndex(LibraryInstaller.java:84) ~[arduino-core.jar:?]
at cc.arduino.contributions.libraries.ui.LibraryManagerUI.lambda$onUpdatePressed$2(LibraryManagerUI.java:203) ~[pde.jar:?]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
at sun.security.validator.PKIXValidator.doValidate(PKIXValidator.java:362) ~[?:1.8.0_232]
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:259) ~[?:1.8.0_232]
at sun.security.validator.Validator.validate(Validator.java:262) ~[?:1.8.0_232]
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:330) ~[?:1.8.0_232]
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:237) ~[?:1.8.0_232]
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:132) ~[?:1.8.0_232]
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1621) ~[?:1.8.0_232]
... 23 more
at sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(PKIXMasterCertPathValidator.java:135) ~[?:1.8.0_232]
at sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:233) ~[?:1.8.0_232]
at sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:141) ~[?:1.8.0_232]
at sun.security.provider.certpath.PKIXCertPathValidator.engineValidate(PKIXCertPathValidator.java:80) ~[?:1.8.0_232]
at java.security.cert.CertPathValidator.validate(CertPathValidator.java:292) ~[?:1.8.0_232]
at sun.security.validator.PKIXValidator.doValidate(PKIXValidator.java:357) ~[?:1.8.0_232]
... 23 more
at sun.security.x509.X509CertImpl.verify(X509CertImpl.java:424) ~[?:1.8.0_232]
at sun.security.provider.certpath.BasicChecker.verifySignature(BasicChecker.java:166) ~[?:1.8.0_232]
at sun.security.provider.certpath.BasicChecker.check(BasicChecker.java:147) ~[?:1.8.0_232]
at sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(PKIXMasterCertPathValidator.java:125) ~[?:1.8.0_232]
... 23 more
2020-02-04T15:27:05.181Z INFO c.a.u.n.FileDownloaderCache:149 [LibraryManager Update Thread] Get file cached is expire true, exist false, info FileCached{eTag='null', lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json', localPath='/home/pi/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json', md5='null', createdAt='2020-02-04T07:27:05.178', cacheControl=null}
2020-02-04T15:27:05.195Z DEBUG c.a.u.n.HttpConnectionManager:125 [LibraryManager Update Thread] Using proxy DIRECT
2020-02-04T15:27:05.200Z INFO c.a.u.n.HttpConnectionManager:148 [LibraryManager Update Thread] Connect to https://downloads.arduino.cc/libraries/library_index.json, method=HEAD, request id=190BCD07864C4353
2020-02-04T15:27:05.493Z ERROR c.a.u.n.FileDownloader:199 [LibraryManager Update Thread] The request stop
at cc.arduino.contributions.GZippedJsonDownloader.download(GZippedJsonDownloader.java:66) ~[arduino-core.jar:?]
... 23 more
... 23 more
... 23 more
</details>
1. **Tools > Board > Boards Manager...**
<details>
2020-02-04T15:28:32.274Z INFO c.a.c.p.ContributionInstaller:305 [ContributionManager Update Thread] Start download and signature check of=[https://downloads.arduino.cc/packages/package_index.json]
2020-02-04T15:28:32.371Z INFO c.a.u.n.FileDownloaderCache:92 [ContributionManager Update Thread] Cache folder /home/pi/.arduino15/cache
2020-02-04T15:28:32.688Z INFO c.a.u.n.FileDownloaderCache:149 [ContributionManager Update Thread] Get file cached is expire true, exist false, info FileCached{eTag='null', lastETag='null', remoteURL='https://downloads.arduino.cc/packages/package_index.json', localPath='/home/pi/.arduino15/cache/downloads.arduino.cc/packages/package_index.json', md5='null', createdAt='2020-02-04T07:28:32.534', cacheControl=null}
2020-02-04T15:28:32.720Z DEBUG c.a.u.n.HttpConnectionManager:125 [ContributionManager Update Thread] Using proxy DIRECT
2020-02-04T15:28:32.726Z INFO c.a.u.n.HttpConnectionManager:148 [ContributionManager Update Thread] Connect to https://downloads.arduino.cc/packages/package_index.json, method=HEAD, request id=E70C709971754A2C
2020-02-04T15:28:33.081Z ERROR c.a.u.n.FileDownloader:199 [ContributionManager Update Thread] The request stop
at cc.arduino.contributions.DownloadableContributionsDownloader.downloadIndexAndSignature(DownloadableContributionsDownloader.java:165) ~[arduino-core.jar:?]
at cc.arduino.contributions.packages.ContributionInstaller.updateIndex(ContributionInstaller.java:306) ~[arduino-core.jar:?]
at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onUpdatePressed$1(ContributionManagerUI.java:146) ~[pde.jar:?]
... 21 more
... 21 more
... 21 more
2020-02-04T15:28:33.194Z ERROR c.a.c.DownloadableContributionsDownloader:181 [ContributionManager Update Thread] Cannot download the package index from https://downloads.arduino.cc/packages/package_index.json the package will be discard
java.lang.Exception: Error downloading https://downloads.arduino.cc/packages/package_index.json
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:149) ~[arduino-core.jar:?]
... 4 more
... 4 more
... 4 more
... 4 more
2020-02-04T15:28:33.263Z ERROR c.a.c.p.ContributionInstaller:308 [ContributionManager Update Thread] Error downloading https://downloads.arduino.cc/packages/package_index.json
... 4 more
... 4 more
... 4 more
... 4 more
2020-02-04T15:28:33.339Z INFO c.a.c.p.ContributionInstaller:314 [ContributionManager Update Thread] Downloaded package index URL=[https://downloads.arduino.cc/packages/package_index.json]
2020-02-04T15:28:33.345Z INFO c.a.c.p.ContributionInstaller:324 [ContributionManager Update Thread] Check unknown files. Additional package index folder files=[package_index.json], Additional package index url downloaded=[]
</details>
The issue does not occur with Arduino IDE 1.8.10.
The issue does occur with Arduino IDE 1.8.11.
The issue does not occur with Windows 10 64 bit or Linux 64 bit versions of the Arduino IDE.
Originally reported at:
- https://forum.arduino.cc/index.php?topic=661984
- https://forum.arduino.cc/index.php?topic=662241
- https://forum.arduino.cc/index.php?topic=661342.msg4464663#msg4464663
- https://forum.arduino.cc/index.php?topic=664430
- And I believe also: https://github.com/arduino/Arduino/issues/8474#issuecomment-580869254, where @twling reported the results of their investigation
Please use Arduino IDE 1.8.10 until Arduino IDE 1.8.12 comes out with the bug fixed. You can download Arduino IDE 1.8.10 here:
Rnold
February 13, 2020, 8:14pm
3
Thanks! I now have version 1.8.10 installed. Alas this version has its own problems. When I try to compile the Blink example I get the error that libfl.so.2 does not exist. I installed and updated the recommended libraries and boards, removed and reinstalled the SAMD library, rebooted each time but the error persists. What did I do wrong? The exact message is:
/home/arnold/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-ar: error while loading shared libraries: libfl.so.2: cannot open shared object file: No such file or directory
exit status 127
Error compiling for board Arduino MKR1000.
I could not include the verbose compiler output because the message is too long.
Raspberry 3B
Raspbian version 10
Kernel version 4.19.93-v7+
Arduino: 1.8.10 (Linux), Board: "Arduino MKR1000"
pert
February 13, 2020, 8:20pm
4
FYI, Arduino IDE 1.8.12 was just released a few hours ago, and it should have the original bug you reported fixed.
But using Arduino IDE 1.8.12 won't fix this new error. I think the solution to that error is described starting here:
opened 12:42AM - 04 Dec 19 UTC
waiting for feedback
Raspberry Pi 4 running Raspbian buster.
`Linux rpi44gb 4.19.75-v7l+ #1270 SMP… Tue Sep 24 18:51:41 BST 2019 armv7l GNU/Linux`
Arduino: 1.8.10 (Linux), Board: "Arduino Nano 33 BLE"
/home/pi/arduino-1.8.10/arduino-builder -dump-prefs -logger=machine -hardware /home/pi/arduino-1.8.10/hardware -hardware /home/pi/.arduino15/packages -tools /home/pi/arduino-1.8.10/tools-builder -tools /home/pi/arduino-1.8.10/hardware/tools/avr -tools /home/pi/.arduino15/packages -built-in-libraries /home/pi/arduino-1.8.10/libraries -libraries /home/pi/Arduino/libraries -fqbn=arduino:mbed:nano33ble -vid-pid=0000_0000 -ide-version=10810 -build-path /tmp/arduino_build_113679 -warnings=none -build-cache /tmp/arduino_cache_994791 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.bossac.path=/home/pi/.arduino15/packages/arduino/tools/bossac/1.9.1-arduino1 -prefs=runtime.tools.bossac-1.9.1-arduino1.path=/home/pi/.arduino15/packages/arduino/tools/bossac/1.9.1-arduino1 -prefs=runtime.tools.arm-none-eabi-gcc.path=/home/pi/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=/home/pi/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs=runtime.tools.openocd.path=/home/pi/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino9 -prefs=runtime.tools.openocd-0.10.0-arduino9.path=/home/pi/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino9 -verbose /home/pi/Arduino/blink/blink.ino
/home/pi/arduino-1.8.10/arduino-builder -compile -logger=machine -hardware /home/pi/arduino-1.8.10/hardware -hardware /home/pi/.arduino15/packages -tools /home/pi/arduino-1.8.10/tools-builder -tools /home/pi/arduino-1.8.10/hardware/tools/avr -tools /home/pi/.arduino15/packages -built-in-libraries /home/pi/arduino-1.8.10/libraries -libraries /home/pi/Arduino/libraries -fqbn=arduino:mbed:nano33ble -vid-pid=0000_0000 -ide-version=10810 -build-path /tmp/arduino_build_113679 -warnings=none -build-cache /tmp/arduino_cache_994791 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.bossac.path=/home/pi/.arduino15/packages/arduino/tools/bossac/1.9.1-arduino1 -prefs=runtime.tools.bossac-1.9.1-arduino1.path=/home/pi/.arduino15/packages/arduino/tools/bossac/1.9.1-arduino1 -prefs=runtime.tools.arm-none-eabi-gcc.path=/home/pi/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=/home/pi/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs=runtime.tools.openocd.path=/home/pi/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino9 -prefs=runtime.tools.openocd-0.10.0-arduino9.path=/home/pi/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino9 -verbose /home/pi/Arduino/blink/blink.ino
Using board 'nano33ble' from platform in folder: /home/pi/.arduino15/packages/arduino/hardware/mbed/1.1.3
Using core 'arduino' from platform in folder: /home/pi/.arduino15/packages/arduino/hardware/mbed/1.1.3
Detecting libraries used...
/home/pi/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -g -Os -nostdlib @/home/pi/.arduino15/packages/arduino/hardware/mbed/1.1.3/variants/ARDUINO_NANO33BLE/defines.txt @/home/pi/.arduino15/packages/arduino/hardware/mbed/1.1.3/variants/ARDUINO_NANO33BLE/cxxflags.txt -DARDUINO_ARCH_NRF52840 -mcpu=cortex-m4 -w -x c++ -E -CC -DARDUINO=10810 -DARDUINO_ARDUINO_NANO33BLE -DARDUINO_ARCH_MBED -I/home/pi/.arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/mbed/1.1.3/variants/ARDUINO_NANO33BLE -I/home/pi/.arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino/api/deprecated -iprefix/home/pi/.arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino @/home/pi/.arduino15/packages/arduino/hardware/mbed/1.1.3/variants/ARDUINO_NANO33BLE/includes.txt /tmp/arduino_build_113679/sketch/blink.ino.cpp -o /dev/null
Error while detecting libraries included by /tmp/arduino_build_113679/sketch/blink.ino.cpp
Generating function prototypes...
/home/pi/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -c -w -g -Os -nostdlib @/home/pi/.arduino15/packages/arduino/hardware/mbed/1.1.3/variants/ARDUINO_NANO33BLE/defines.txt @/home/pi/.arduino15/packages/arduino/hardware/mbed/1.1.3/variants/ARDUINO_NANO33BLE/cxxflags.txt -DARDUINO_ARCH_NRF52840 -mcpu=cortex-m4 -w -x c++ -E -CC -DARDUINO=10810 -DARDUINO_ARDUINO_NANO33BLE -DARDUINO_ARCH_MBED -I/home/pi/.arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/mbed/1.1.3/variants/ARDUINO_NANO33BLE -I/home/pi/.arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino/api/deprecated -iprefix/home/pi/.arduino15/packages/arduino/hardware/mbed/1.1.3/cores/arduino @/home/pi/.arduino15/packages/arduino/hardware/mbed/1.1.3/variants/ARDUINO_NANO33BLE/includes.txt /tmp/arduino_build_113679/sketch/blink.ino.cpp -o /tmp/arduino_build_113679/preproc/ctags_target_for_gcc_minus_e.cpp
arm-none-eabi-g++: error: unrecognized command line option '-std=gnu++14'
exit status 1
Error compiling for board Arduino Nano 33 BLE.
Rnold
February 13, 2020, 8:55pm
5
Yes, this did the trick! I'd forgotten to mention that I had tried to apt install libfl.so.2 (which of course didn't work) so I was happy with your suggestion. 1.8.10 worked ok. Next I installed 1.8.12 and that worked immediately (libfl2 was already installed). The blink sketch now works out of the box from Raspberry to MKR1000.
Thanks for your help!
pert
February 13, 2020, 9:16pm
6
You're welcome. I'm glad to hear it's working now. Enjoy!
Per
