I down loaded the latest version from https://Arduino.cc today 13, February, 2020/ it was for a Raspberry Pi Version 4 with an Arm 64 bit processor. There was no no boards manager under Tools-boards. I need to add a MKR 1000 board, which was not on the list of boards.
pert
February 13, 2020, 9:20pm
2
Which download link on the Software page did you use: "Linux ARM 32 bits" or "Linux ARM 64 bits"?
I down loaded Linux ARM 64 bits.
pert
February 13, 2020, 9:47pm
4
If I remember correctly, I think you're still supposed to use the Linux ARM 32 bits version even with the Raspberry Pi 4. Give that a try.
I tried ARM 32 bit and got with that I got the 1.8.12 version. I kept getting 1.9.20 when I selected the ARM 64 version. The 1.9.20 version did not have the boards manager. the 1.8.12 version had the boards manager and all the usual good stuff.
As a further note I just downloaded version 1.8.12 on my Windows 10 machine. I used Windows Installer, for Windows XP and up at the top of the right hand pane on the download page. if you go to the Windows store page it just tells you already have the Arduino IDE and won't do an upgrade from there.
pert
February 15, 2020, 1:48am
8
urlonz14:
Interesting. I don't own a 64 bit ARM system, so I've never used that version of the Arduino IDE. The beta version of the Arduino IDE is versioned as 1.9.0-beta, but it has Library and Boards Manager. I haven't heard of this 1.9.20 version before.
urlonz14:
At least with the Linux ARM 32 bits version of Arduino IDE 1.8.11, Library and Boards Manager didn't work:
opened 07:18PM - 04 Feb 20 UTC
Type: Bug
Component: Board/Lib Manager
OS: Linux ARM
OpenJDK
Using Arduino IDE 1.8.11 Hourly Build 2020/02/03 07:20 on Raspbian 9.4 (stretch)… and Raspbian 10.2 (buster)
1. Delete `~/.arduino15/cache` (because if the Arduino IDE uses the cached indexes, it won't trigger the bug)
1. (OPTIONAL) If you want to avoid waiting over 5 minutes for Library Manager to open (due to https://github.com/arduino/Arduino/issues/9701), delete `~/.arduino15/library_index.json`. The bug occurs with or without it, it just occurs a lot faster without.
1. Start the Arduino IDE
1. **Sketch > Include Library > Manage Libraries...**
The index download fails:
Error downloading https://downloads.arduino.cc/libraries/library_index.json
java.lang.RuntimeException: java.lang.Exception: Error downloading https://downloads.arduino.cc/libraries/library_index.json
at cc.arduino.contributions.libraries.ui.LibraryManagerUI.lambda$onUpdatePressed$2(LibraryManagerUI.java:207)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.Exception: Error downloading https://downloads.arduino.cc/libraries/library_index.json
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:149)
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:130)
at cc.arduino.contributions.JsonDownloader.download(JsonDownloader.java:49)
at cc.arduino.contributions.GZippedJsonDownloader.download(GZippedJsonDownloader.java:66)
at cc.arduino.contributions.libraries.LibraryInstaller.updateIndex(LibraryInstaller.java:84)
at cc.arduino.contributions.libraries.ui.LibraryManagerUI.lambda$onUpdatePressed$2(LibraryManagerUI.java:203)
... 1 more
Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path validation failed: java.security.cert.CertPathValidatorException: signature check failed
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1946)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:316)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:310)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1639)
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:223)
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1037)
at sun.security.ssl.Handshaker.process_record(Handshaker.java:965)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1064)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1367)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1395)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1379)
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.connect(HttpsURLConnectionImpl.java:167)
at cc.arduino.utils.network.HttpConnectionManager.makeConnection(HttpConnectionManager.java:150)
at cc.arduino.utils.network.HttpConnectionManager.makeConnection(HttpConnectionManager.java:106)
at cc.arduino.utils.network.FileDownloaderCache.updateCacheInfo(FileDownloaderCache.java:184)
at cc.arduino.utils.network.FileDownloaderCache.getFileCached(FileDownloaderCache.java:153)
at cc.arduino.utils.network.FileDownloader.downloadFile(FileDownloader.java:167)
at cc.arduino.utils.network.FileDownloader.download(FileDownloader.java:129)
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:147)
... 6 more
Caused by: sun.security.validator.ValidatorException: PKIX path validation failed: java.security.cert.CertPathValidatorException: signature check failed
at sun.security.validator.PKIXValidator.doValidate(PKIXValidator.java:362)
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:259)
at sun.security.validator.Validator.validate(Validator.java:262)
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:330)
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:237)
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:132)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1621)
... 23 more
Caused by: java.security.cert.CertPathValidatorException: signature check failed
at sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(PKIXMasterCertPathValidator.java:135)
at sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:233)
at sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:141)
at sun.security.provider.certpath.PKIXCertPathValidator.engineValidate(PKIXCertPathValidator.java:80)
at java.security.cert.CertPathValidator.validate(CertPathValidator.java:292)
at sun.security.validator.PKIXValidator.doValidate(PKIXValidator.java:357)
... 29 more
Caused by: java.security.SignatureException: Signature does not match.
at sun.security.x509.X509CertImpl.verify(X509CertImpl.java:424)
at sun.security.provider.certpath.BasicChecker.verifySignature(BasicChecker.java:166)
at sun.security.provider.certpath.BasicChecker.check(BasicChecker.java:147)
at sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(PKIXMasterCertPathValidator.java:125)
... 34 more
<details>
<summary>Click for contents of `~/.arduino15/logs/application.log`:</summary>
2020-02-04T15:27:04.290Z INFO c.a.u.n.FileDownloaderCache:92 [LibraryManager Update Thread] Cache folder /home/pi/.arduino15/cache
2020-02-04T15:27:04.688Z INFO c.a.u.n.FileDownloaderCache:149 [LibraryManager Update Thread] Get file cached is expire true, exist false, info FileCached{eTag='null', lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.gz', localPath='/home/pi/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.gz', md5='null', createdAt='2020-02-04T07:27:04.544', cacheControl=null}
2020-02-04T15:27:04.731Z DEBUG c.a.u.n.HttpConnectionManager:125 [LibraryManager Update Thread] Using proxy DIRECT
2020-02-04T15:27:04.738Z INFO c.a.u.n.HttpConnectionManager:148 [LibraryManager Update Thread] Connect to https://downloads.arduino.cc/libraries/library_index.json.gz, method=HEAD, request id=BDF785772AFB4855
2020-02-04T15:27:05.066Z ERROR c.a.u.n.FileDownloader:199 [LibraryManager Update Thread] The request stop
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192) ~[?:1.8.0_232]
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1946) ~[?:1.8.0_232]
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:316) ~[?:1.8.0_232]
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:310) ~[?:1.8.0_232]
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1639) ~[?:1.8.0_232]
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:223) ~[?:1.8.0_232]
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1037) ~[?:1.8.0_232]
at sun.security.ssl.Handshaker.process_record(Handshaker.java:965) ~[?:1.8.0_232]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1064) ~[?:1.8.0_232]
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1367) ~[?:1.8.0_232]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1395) ~[?:1.8.0_232]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1379) ~[?:1.8.0_232]
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559) ~[?:1.8.0_232]
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185) ~[?:1.8.0_232]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.connect(HttpsURLConnectionImpl.java:167) ~[?:1.8.0_232]
at cc.arduino.utils.network.HttpConnectionManager.makeConnection(HttpConnectionManager.java:150) ~[arduino-core.jar:?]
at cc.arduino.utils.network.HttpConnectionManager.makeConnection(HttpConnectionManager.java:106) ~[arduino-core.jar:?]
at cc.arduino.utils.network.FileDownloaderCache.updateCacheInfo(FileDownloaderCache.java:184) ~[arduino-core.jar:?]
at cc.arduino.utils.network.FileDownloaderCache.getFileCached(FileDownloaderCache.java:153) ~[arduino-core.jar:?]
at cc.arduino.utils.network.FileDownloader.downloadFile(FileDownloader.java:167) ~[arduino-core.jar:?]
at cc.arduino.utils.network.FileDownloader.download(FileDownloader.java:129) ~[arduino-core.jar:?]
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:147) ~[arduino-core.jar:?]
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:130) ~[arduino-core.jar:?]
at cc.arduino.contributions.JsonDownloader.download(JsonDownloader.java:49) ~[arduino-core.jar:?]
at cc.arduino.contributions.GZippedJsonDownloader.download(GZippedJsonDownloader.java:63) ~[arduino-core.jar:?]
at cc.arduino.contributions.libraries.LibraryInstaller.updateIndex(LibraryInstaller.java:84) ~[arduino-core.jar:?]
at cc.arduino.contributions.libraries.ui.LibraryManagerUI.lambda$onUpdatePressed$2(LibraryManagerUI.java:203) ~[pde.jar:?]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
at sun.security.validator.PKIXValidator.doValidate(PKIXValidator.java:362) ~[?:1.8.0_232]
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:259) ~[?:1.8.0_232]
at sun.security.validator.Validator.validate(Validator.java:262) ~[?:1.8.0_232]
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:330) ~[?:1.8.0_232]
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:237) ~[?:1.8.0_232]
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:132) ~[?:1.8.0_232]
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1621) ~[?:1.8.0_232]
... 23 more
at sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(PKIXMasterCertPathValidator.java:135) ~[?:1.8.0_232]
at sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:233) ~[?:1.8.0_232]
at sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:141) ~[?:1.8.0_232]
at sun.security.provider.certpath.PKIXCertPathValidator.engineValidate(PKIXCertPathValidator.java:80) ~[?:1.8.0_232]
at java.security.cert.CertPathValidator.validate(CertPathValidator.java:292) ~[?:1.8.0_232]
at sun.security.validator.PKIXValidator.doValidate(PKIXValidator.java:357) ~[?:1.8.0_232]
... 23 more
at sun.security.x509.X509CertImpl.verify(X509CertImpl.java:424) ~[?:1.8.0_232]
at sun.security.provider.certpath.BasicChecker.verifySignature(BasicChecker.java:166) ~[?:1.8.0_232]
at sun.security.provider.certpath.BasicChecker.check(BasicChecker.java:147) ~[?:1.8.0_232]
at sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(PKIXMasterCertPathValidator.java:125) ~[?:1.8.0_232]
... 23 more
2020-02-04T15:27:05.181Z INFO c.a.u.n.FileDownloaderCache:149 [LibraryManager Update Thread] Get file cached is expire true, exist false, info FileCached{eTag='null', lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json', localPath='/home/pi/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json', md5='null', createdAt='2020-02-04T07:27:05.178', cacheControl=null}
2020-02-04T15:27:05.195Z DEBUG c.a.u.n.HttpConnectionManager:125 [LibraryManager Update Thread] Using proxy DIRECT
2020-02-04T15:27:05.200Z INFO c.a.u.n.HttpConnectionManager:148 [LibraryManager Update Thread] Connect to https://downloads.arduino.cc/libraries/library_index.json, method=HEAD, request id=190BCD07864C4353
2020-02-04T15:27:05.493Z ERROR c.a.u.n.FileDownloader:199 [LibraryManager Update Thread] The request stop
at cc.arduino.contributions.GZippedJsonDownloader.download(GZippedJsonDownloader.java:66) ~[arduino-core.jar:?]
... 23 more
... 23 more
... 23 more
</details>
1. **Tools > Board > Boards Manager...**
Error downloading https://downloads.arduino.cc/packages/package_index.json
<details>
2020-02-04T15:28:32.274Z INFO c.a.c.p.ContributionInstaller:305 [ContributionManager Update Thread] Start download and signature check of=[https://downloads.arduino.cc/packages/package_index.json]
2020-02-04T15:28:32.371Z INFO c.a.u.n.FileDownloaderCache:92 [ContributionManager Update Thread] Cache folder /home/pi/.arduino15/cache
2020-02-04T15:28:32.688Z INFO c.a.u.n.FileDownloaderCache:149 [ContributionManager Update Thread] Get file cached is expire true, exist false, info FileCached{eTag='null', lastETag='null', remoteURL='https://downloads.arduino.cc/packages/package_index.json', localPath='/home/pi/.arduino15/cache/downloads.arduino.cc/packages/package_index.json', md5='null', createdAt='2020-02-04T07:28:32.534', cacheControl=null}
2020-02-04T15:28:32.720Z DEBUG c.a.u.n.HttpConnectionManager:125 [ContributionManager Update Thread] Using proxy DIRECT
2020-02-04T15:28:32.726Z INFO c.a.u.n.HttpConnectionManager:148 [ContributionManager Update Thread] Connect to https://downloads.arduino.cc/packages/package_index.json, method=HEAD, request id=E70C709971754A2C
2020-02-04T15:28:33.081Z ERROR c.a.u.n.FileDownloader:199 [ContributionManager Update Thread] The request stop
at cc.arduino.contributions.DownloadableContributionsDownloader.downloadIndexAndSignature(DownloadableContributionsDownloader.java:165) ~[arduino-core.jar:?]
at cc.arduino.contributions.packages.ContributionInstaller.updateIndex(ContributionInstaller.java:306) ~[arduino-core.jar:?]
at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onUpdatePressed$1(ContributionManagerUI.java:146) ~[pde.jar:?]
... 21 more
... 21 more
... 21 more
2020-02-04T15:28:33.194Z ERROR c.a.c.DownloadableContributionsDownloader:181 [ContributionManager Update Thread] Cannot download the package index from https://downloads.arduino.cc/packages/package_index.json the package will be discard
java.lang.Exception: Error downloading https://downloads.arduino.cc/packages/package_index.json
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:149) ~[arduino-core.jar:?]
... 4 more
... 4 more
... 4 more
... 4 more
2020-02-04T15:28:33.263Z ERROR c.a.c.p.ContributionInstaller:308 [ContributionManager Update Thread] Error downloading https://downloads.arduino.cc/packages/package_index.json
... 4 more
... 4 more
... 4 more
... 4 more
2020-02-04T15:28:33.339Z INFO c.a.c.p.ContributionInstaller:314 [ContributionManager Update Thread] Downloaded package index URL=[https://downloads.arduino.cc/packages/package_index.json]
2020-02-04T15:28:33.345Z INFO c.a.c.p.ContributionInstaller:324 [ContributionManager Update Thread] Check unknown files. Additional package index folder files=[package_index.json], Additional package index url downloaded=[]
</details>
The issue does not occur with Arduino IDE 1.8.10.
The issue does occur with Arduino IDE 1.8.11.
The issue does not occur with Windows 10 64 bit or Linux 64 bit versions of the Arduino IDE.
Originally reported at:
- https://forum.arduino.cc/index.php?topic=661984
- https://forum.arduino.cc/index.php?topic=662241
- https://forum.arduino.cc/index.php?topic=661342.msg4464663#msg4464663
- https://forum.arduino.cc/index.php?topic=664430
- And I believe also: https://github.com/arduino/Arduino/issues/8474#issuecomment-580869254, where @twling reported the results of their investigation
I couldn't check whether the same problem occurred with the Linux ARM 64 bits version of the Arduino IDE. In the Arduino IDE 1.8.12 release, they reverted to using the Oracle JRE instead of OpenJDK to fix this bug, and other bugs, but they couldn't do that for the Linux ARM 64 bit version. I guess it's possible that they just disabled Library and Boards Manager in the Linux ARM 64 bit version, since they didn't work anyway. I don't see anything about that in the commit history though.
urlonz14:
I'm glad to hear that!
urlonz14:
I don't know what the situation is with the Microsoft store releases. They never did a Microsoft Store release for Arduino IDE 1.8.10. They actually did two releases for 1.8.11. Maybe they just haven't had the time to do the 1.8.12 Microsoft Store release yet. Fortunately, we can use the standard Windows versions of the Arduino IDE, so we have an alternative.
