wd8tim
January 31, 2020, 6:49am
1
hi i im using a Raspberry Pi i have Arduino IDE 1.8.11 installed, im not getting updates i keep getting errors. can someone help? here is the errors, thanks in advance.
Error downloading https://downloads.arduino.cc/packages/package_index.json
Error downloading https://downloads.arduino.cc/libraries/library_index.json
java.lang.RuntimeException: java.lang.Exception: Error downloading https://downloads.arduino.cc/libraries/library_index.json
at cc.arduino.contributions.libraries.ui.LibraryManagerUI.lambda$onUpdatePressed$2(LibraryManagerUI.java:207)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.Exception: Error downloading https://downloads.arduino.cc/libraries/library_index.json
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:149)
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:130)
at cc.arduino.contributions.JsonDownloader.download(JsonDownloader.java:49)
at cc.arduino.contributions.GZippedJsonDownloader.download(GZippedJsonDownloader.java:66)
at cc.arduino.contributions.libraries.LibraryInstaller.updateIndex(LibraryInstaller.java:84)
at cc.arduino.contributions.libraries.ui.LibraryManagerUI.lambda$onUpdatePressed$2(LibraryManagerUI.java:203)
... 1 more
Caused by: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path validation failed: java.security.cert.CertPathValidatorException: signature check failed
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1946)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:316)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:310)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1639)
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:223)
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1037)
at sun.security.ssl.Handshaker.process_record(Handshaker.java:965)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1064)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1367)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1395)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1379)
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.connect(HttpsURLConnectionImpl.java:167)
at cc.arduino.utils.network.HttpConnectionManager.makeConnection(HttpConnectionManager.java:150)
at cc.arduino.utils.network.HttpConnectionManager.makeConnection(HttpConnectionManager.java:106)
at cc.arduino.utils.network.FileDownloaderCache.updateCacheInfo(FileDownloaderCache.java:184)
at cc.arduino.utils.network.FileDownloaderCache.getFileCached(FileDownloaderCache.java:153)
at cc.arduino.utils.network.FileDownloader.downloadFile(FileDownloader.java:167)
at cc.arduino.utils.network.FileDownloader.download(FileDownloader.java:129)
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:147)
... 6 more
Caused by: sun.security.validator.ValidatorException: PKIX path validation failed: java.security.cert.CertPathValidatorException: signature check failed
at sun.security.validator.PKIXValidator.doValidate(PKIXValidator.java:362)
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:259)
at sun.security.validator.Validator.validate(Validator.java:262)
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:330)
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:237)
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:132)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1621)
... 23 more
Caused by: java.security.cert.CertPathValidatorException: signature check failed
at sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(PKIXMasterCertPathValidator.java:135)
at sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:233)
at sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:141)
at sun.security.provider.certpath.PKIXCertPathValidator.engineValidate(PKIXCertPathValidator.java:80)
at java.security.cert.CertPathValidator.validate(CertPathValidator.java:292)
at sun.security.validator.PKIXValidator.doValidate(PKIXValidator.java:357)
... 29 more
Caused by: java.security.SignatureException: Signature does not match.
at sun.security.x509.X509CertImpl.verify(X509CertImpl.java:424)
at sun.security.provider.certpath.BasicChecker.verifySignature(BasicChecker.java:166)
at sun.security.provider.certpath.BasicChecker.check(BasicChecker.java:147)
at sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(PKIXMasterCertPathValidator.java:125)
... 34 more
wd8tim
January 31, 2020, 7:26am
3
hi there i did that, i researched it all day and that's one thing i did and it didn't help but thanks any other ideas? also this is on Raspberry PI not Windows
pert
January 31, 2020, 9:46am
4
Can you open this link in the browser on your Raspberry Pi?
wd8tim
January 31, 2020, 1:44pm
5
yes i can i even installed ide 2 times no luck
pert
January 31, 2020, 2:00pm
6
Here are a couple other things you can try:
TEMPORARILY disable your antivirus software.
(In the Arduino IDE) Close the Boards Manager window if it's open.
Tools > Board > Boards Manager
Wait for the downloads to finish.
Re-enable your antivirus software immediately.
Did the error still occur when the antivirus was disabled? If not, you'll need to whitelist the appropriate folder, file, or process in your antivirus software's settings.
list type=decimal]
Connect to the Internet through a different network. If you're currently using the network at your work, try your home network. You can try connecting via the WiFi hotspot on your phone.
Does the "file signature verification failed" error still occur? If not, the issue may be caused by the firewall or other security restrictions on the original network.
wd8tim
January 31, 2020, 3:22pm
7
ok i did all that again with no luck, is there a firewall on Raspberry Pi? from the Pi i can get to the link from a browser, if there is a firewall on Pi this could be the problem?
wd8tim
January 31, 2020, 5:30pm
8
well! i uninstalled 1.8.11 reinstalled 1.8.10 all works fine! so i think it has to do with 1.8.11 any thoughts?
pert
February 4, 2020, 7:26pm
9
I can reproduce the bug and have submitted a bug report:
opened 07:18PM - 04 Feb 20 UTC
Type: Bug
Component: Board/Lib Manager
OS: Linux ARM
OpenJDK
Using Arduino IDE 1.8.11 Hourly Build 2020/02/03 07:20 on Raspbian 9.4 (stretch)… and Raspbian 10.2 (buster)
1. Delete `~/.arduino15/cache` (because if the Arduino IDE uses the cached indexes, it won't trigger the bug)
1. (OPTIONAL) If you want to avoid waiting over 5 minutes for Library Manager to open (due to https://github.com/arduino/Arduino/issues/9701), delete `~/.arduino15/library_index.json`. The bug occurs with or without it, it just occurs a lot faster without.
1. Start the Arduino IDE
1. **Sketch > Include Library > Manage Libraries...**
The index download fails:
... 1 more
... 6 more
... 23 more
... 29 more
... 34 more
<details>
<summary>Click for contents of `~/.arduino15/logs/application.log`:</summary>
2020-02-04T15:27:04.290Z INFO c.a.u.n.FileDownloaderCache:92 [LibraryManager Update Thread] Cache folder /home/pi/.arduino15/cache
2020-02-04T15:27:04.688Z INFO c.a.u.n.FileDownloaderCache:149 [LibraryManager Update Thread] Get file cached is expire true, exist false, info FileCached{eTag='null', lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json.gz', localPath='/home/pi/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json.gz', md5='null', createdAt='2020-02-04T07:27:04.544', cacheControl=null}
2020-02-04T15:27:04.731Z DEBUG c.a.u.n.HttpConnectionManager:125 [LibraryManager Update Thread] Using proxy DIRECT
2020-02-04T15:27:04.738Z INFO c.a.u.n.HttpConnectionManager:148 [LibraryManager Update Thread] Connect to https://downloads.arduino.cc/libraries/library_index.json.gz, method=HEAD, request id=BDF785772AFB4855
2020-02-04T15:27:05.066Z ERROR c.a.u.n.FileDownloader:199 [LibraryManager Update Thread] The request stop
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192) ~[?:1.8.0_232]
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1946) ~[?:1.8.0_232]
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:316) ~[?:1.8.0_232]
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:310) ~[?:1.8.0_232]
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1639) ~[?:1.8.0_232]
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:223) ~[?:1.8.0_232]
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:1037) ~[?:1.8.0_232]
at sun.security.ssl.Handshaker.process_record(Handshaker.java:965) ~[?:1.8.0_232]
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1064) ~[?:1.8.0_232]
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1367) ~[?:1.8.0_232]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1395) ~[?:1.8.0_232]
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1379) ~[?:1.8.0_232]
at sun.net.www.protocol.https.HttpsClient.afterConnect(HttpsClient.java:559) ~[?:1.8.0_232]
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:185) ~[?:1.8.0_232]
at sun.net.www.protocol.https.HttpsURLConnectionImpl.connect(HttpsURLConnectionImpl.java:167) ~[?:1.8.0_232]
at cc.arduino.utils.network.HttpConnectionManager.makeConnection(HttpConnectionManager.java:150) ~[arduino-core.jar:?]
at cc.arduino.utils.network.HttpConnectionManager.makeConnection(HttpConnectionManager.java:106) ~[arduino-core.jar:?]
at cc.arduino.utils.network.FileDownloaderCache.updateCacheInfo(FileDownloaderCache.java:184) ~[arduino-core.jar:?]
at cc.arduino.utils.network.FileDownloaderCache.getFileCached(FileDownloaderCache.java:153) ~[arduino-core.jar:?]
at cc.arduino.utils.network.FileDownloader.downloadFile(FileDownloader.java:167) ~[arduino-core.jar:?]
at cc.arduino.utils.network.FileDownloader.download(FileDownloader.java:129) ~[arduino-core.jar:?]
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:147) ~[arduino-core.jar:?]
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:130) ~[arduino-core.jar:?]
at cc.arduino.contributions.JsonDownloader.download(JsonDownloader.java:49) ~[arduino-core.jar:?]
at cc.arduino.contributions.GZippedJsonDownloader.download(GZippedJsonDownloader.java:63) ~[arduino-core.jar:?]
at cc.arduino.contributions.libraries.LibraryInstaller.updateIndex(LibraryInstaller.java:84) ~[arduino-core.jar:?]
at cc.arduino.contributions.libraries.ui.LibraryManagerUI.lambda$onUpdatePressed$2(LibraryManagerUI.java:203) ~[pde.jar:?]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
at sun.security.validator.PKIXValidator.doValidate(PKIXValidator.java:362) ~[?:1.8.0_232]
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:259) ~[?:1.8.0_232]
at sun.security.validator.Validator.validate(Validator.java:262) ~[?:1.8.0_232]
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:330) ~[?:1.8.0_232]
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:237) ~[?:1.8.0_232]
at sun.security.ssl.X509TrustManagerImpl.checkServerTrusted(X509TrustManagerImpl.java:132) ~[?:1.8.0_232]
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1621) ~[?:1.8.0_232]
... 23 more
at sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(PKIXMasterCertPathValidator.java:135) ~[?:1.8.0_232]
at sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:233) ~[?:1.8.0_232]
at sun.security.provider.certpath.PKIXCertPathValidator.validate(PKIXCertPathValidator.java:141) ~[?:1.8.0_232]
at sun.security.provider.certpath.PKIXCertPathValidator.engineValidate(PKIXCertPathValidator.java:80) ~[?:1.8.0_232]
at java.security.cert.CertPathValidator.validate(CertPathValidator.java:292) ~[?:1.8.0_232]
at sun.security.validator.PKIXValidator.doValidate(PKIXValidator.java:357) ~[?:1.8.0_232]
... 23 more
at sun.security.x509.X509CertImpl.verify(X509CertImpl.java:424) ~[?:1.8.0_232]
at sun.security.provider.certpath.BasicChecker.verifySignature(BasicChecker.java:166) ~[?:1.8.0_232]
at sun.security.provider.certpath.BasicChecker.check(BasicChecker.java:147) ~[?:1.8.0_232]
at sun.security.provider.certpath.PKIXMasterCertPathValidator.validate(PKIXMasterCertPathValidator.java:125) ~[?:1.8.0_232]
... 23 more
2020-02-04T15:27:05.181Z INFO c.a.u.n.FileDownloaderCache:149 [LibraryManager Update Thread] Get file cached is expire true, exist false, info FileCached{eTag='null', lastETag='null', remoteURL='https://downloads.arduino.cc/libraries/library_index.json', localPath='/home/pi/.arduino15/cache/downloads.arduino.cc/libraries/library_index.json', md5='null', createdAt='2020-02-04T07:27:05.178', cacheControl=null}
2020-02-04T15:27:05.195Z DEBUG c.a.u.n.HttpConnectionManager:125 [LibraryManager Update Thread] Using proxy DIRECT
2020-02-04T15:27:05.200Z INFO c.a.u.n.HttpConnectionManager:148 [LibraryManager Update Thread] Connect to https://downloads.arduino.cc/libraries/library_index.json, method=HEAD, request id=190BCD07864C4353
2020-02-04T15:27:05.493Z ERROR c.a.u.n.FileDownloader:199 [LibraryManager Update Thread] The request stop
at cc.arduino.contributions.GZippedJsonDownloader.download(GZippedJsonDownloader.java:66) ~[arduino-core.jar:?]
... 23 more
... 23 more
... 23 more
</details>
1. **Tools > Board > Boards Manager...**
<details>
2020-02-04T15:28:32.274Z INFO c.a.c.p.ContributionInstaller:305 [ContributionManager Update Thread] Start download and signature check of=[https://downloads.arduino.cc/packages/package_index.json]
2020-02-04T15:28:32.371Z INFO c.a.u.n.FileDownloaderCache:92 [ContributionManager Update Thread] Cache folder /home/pi/.arduino15/cache
2020-02-04T15:28:32.688Z INFO c.a.u.n.FileDownloaderCache:149 [ContributionManager Update Thread] Get file cached is expire true, exist false, info FileCached{eTag='null', lastETag='null', remoteURL='https://downloads.arduino.cc/packages/package_index.json', localPath='/home/pi/.arduino15/cache/downloads.arduino.cc/packages/package_index.json', md5='null', createdAt='2020-02-04T07:28:32.534', cacheControl=null}
2020-02-04T15:28:32.720Z DEBUG c.a.u.n.HttpConnectionManager:125 [ContributionManager Update Thread] Using proxy DIRECT
2020-02-04T15:28:32.726Z INFO c.a.u.n.HttpConnectionManager:148 [ContributionManager Update Thread] Connect to https://downloads.arduino.cc/packages/package_index.json, method=HEAD, request id=E70C709971754A2C
2020-02-04T15:28:33.081Z ERROR c.a.u.n.FileDownloader:199 [ContributionManager Update Thread] The request stop
at cc.arduino.contributions.DownloadableContributionsDownloader.downloadIndexAndSignature(DownloadableContributionsDownloader.java:165) ~[arduino-core.jar:?]
at cc.arduino.contributions.packages.ContributionInstaller.updateIndex(ContributionInstaller.java:306) ~[arduino-core.jar:?]
at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onUpdatePressed$1(ContributionManagerUI.java:146) ~[pde.jar:?]
... 21 more
... 21 more
... 21 more
2020-02-04T15:28:33.194Z ERROR c.a.c.DownloadableContributionsDownloader:181 [ContributionManager Update Thread] Cannot download the package index from https://downloads.arduino.cc/packages/package_index.json the package will be discard
java.lang.Exception: Error downloading https://downloads.arduino.cc/packages/package_index.json
at cc.arduino.contributions.DownloadableContributionsDownloader.download(DownloadableContributionsDownloader.java:149) ~[arduino-core.jar:?]
... 4 more
... 4 more
... 4 more
... 4 more
2020-02-04T15:28:33.263Z ERROR c.a.c.p.ContributionInstaller:308 [ContributionManager Update Thread] Error downloading https://downloads.arduino.cc/packages/package_index.json
... 4 more
... 4 more
... 4 more
... 4 more
2020-02-04T15:28:33.339Z INFO c.a.c.p.ContributionInstaller:314 [ContributionManager Update Thread] Downloaded package index URL=[https://downloads.arduino.cc/packages/package_index.json]
2020-02-04T15:28:33.345Z INFO c.a.c.p.ContributionInstaller:324 [ContributionManager Update Thread] Check unknown files. Additional package index folder files=[package_index.json], Additional package index url downloaded=[]
</details>
The issue does not occur with Arduino IDE 1.8.10.
The issue does occur with Arduino IDE 1.8.11.
The issue does not occur with Windows 10 64 bit or Linux 64 bit versions of the Arduino IDE.
Originally reported at:
- https://forum.arduino.cc/index.php?topic=661984
- https://forum.arduino.cc/index.php?topic=662241
- https://forum.arduino.cc/index.php?topic=661342.msg4464663#msg4464663
- https://forum.arduino.cc/index.php?topic=664430
- And I believe also: https://github.com/arduino/Arduino/issues/8474#issuecomment-580869254, where @twling reported the results of their investigation
Thanks for reporting this @wd8tim !
