I'm getting odd results trying to update the Adafruit INA219 software for their breakboard board in the Adafruit_INA219 library to measure 10A for a 0.01ohm resistor. This is using an Arduino Uno Rev2 Wifi.
V_expected = 16.8V
V_max = 32V
current_expected = 10A
current_max = 32A
I am trying to update the calibration function setCalibration_32V_1A() to allow 10A instead of 1A.
I build a resistive load to test the original, unaltered sensor. I wanted around 100mA draw to test, so I built a resistive divider with four 680 OHM 1/2W resistors in parallel, which gave an expected current flow of 96mA with the battery pack voltage at 16.3V.
The original sensor with 0.1 Ohm worked well within the margins I wanted. The results are below.
Bus : 16.19V
Shunt : 10.88mV
Load : 16.2V
Current: 108.6mA
Power : 1760mW
I then unsoldered and resolderwd with this 0.01OHM 1W resistor
https://www.digikey.com/en/products/det ... 1L/2178323
I then build a new function and updated the code in the manner shown below, following the process outlined in the library step-by-step:
void Adafruit_INA219::setCalibration_32V_10A() {
// By default we use a pretty huge range for the input voltage,
// which probably isn't the most appropriate choice for system
// that don't use a lot of power. But all of the calculations
// are shown below if you want to change the settings. You will
// also need to change any relevant register settings, such as
// setting the VBUS_MAX to 16V instead of 32V, etc.
// VBUS_MAX = 32V (Assumes 32V, can also be set to 16V)
// VSHUNT_MAX = 0.32 (Assumes Gain 8, 320mV, can also be 0.16, 0.08, 0.04)
// RSHUNT = 0.01 (Resistor value in ohms)
// 1. Determine max possible current
// MaxPossible_I = VSHUNT_MAX / RSHUNT
// MaxPossible_I = 32A
// 2. Determine max expected current
// MaxExpected_I = 10.0A
// 3. Calculate possible range of LSBs (Min = 15-bit, Max = 12-bit)
// MinimumLSB = MaxExpected_I/32767
// MinimumLSB = 0.000305 (305uA per bit)
// MaximumLSB = MaxExpected_I/4096
// MaximumLSB = 0.00244 (2.44 mA per bit)
// 4. Choose an LSB between the min and max values
// CurrentLSB = 0.000400 (400uA per bit)
// 5. Compute the calibration register
// Cal = trunc (0.04096 / (Current_LSB * RSHUNT))
// Cal = 10240 (0x2800)
ina219_calValue = 10240;
// 6. Calculate the power LSB
// PowerLSB = 20 * CurrentLSB
// PowerLSB = 0.008 (8mW per bit)
// 7. Compute the maximum current and shunt voltage values before overflow
// Max_Current = Current_LSB * 32767
// Max_Current = 13.1068A before overflow
// If Max_Current > Max_Possible_I then
// Max_Current_Before_Overflow = MaxPossible_I
// Else
// Max_Current_Before_Overflow = Max_Current
// End If
// ... In this case, we're good though since Max_Current is less than
// MaxPossible_I
// Max_ShuntVoltage = Max_Current_Before_Overflow * RSHUNT
// Max_ShuntVoltage = 0.131068V
// If Max_ShuntVoltage >= VSHUNT_MAX
// Max_ShuntVoltage_Before_Overflow = VSHUNT_MAX
// Else
// Max_ShuntVoltage_Before_Overflow = Max_ShuntVoltage
// End If
// 8. Compute the Maximum Power
// MaximumPower = Max_Current_Before_Overflow * VBUS_MAX
// MaximumPower = 13.1068 * 32V
// MaximumPower = 419.4176W
// Set multipliers to convert raw current/power values
ina219_currentDivider_mA = 2.5; // Current LSB = 400uA per bit (1000/400 = 2.5)
ina219_powerMultiplier_mW = 8.0f; // Power LSB = 8mW per bit
// Set Calibration register to 'Cal' calculated above
Adafruit_BusIO_Register calibration_reg =
Adafruit_BusIO_Register(i2c_dev, INA219_REG_CALIBRATION, 2, MSBFIRST);
calibration_reg.write(ina219_calValue, 2);
// Set Config register to take into account the settings above
uint16_t config = INA219_CONFIG_BVOLTAGERANGE_32V |
INA219_CONFIG_GAIN_8_320MV | INA219_CONFIG_BADCRES_12BIT |
INA219_CONFIG_SADCRES_12BIT_1S_532US |
INA219_CONFIG_MODE_SANDBVOLT_CONTINUOUS;
Adafruit_BusIO_Register config_reg =
Adafruit_BusIO_Register(i2c_dev, INA219_REG_CONFIG, 2, MSBFIRST);
_success = config_reg.write(config, 2);
I placed this sensor in the test rig in exactly the same spot using exactly the same wiring, and received these results.
Bus : 16.22V
Shunt : 2.10mV
Load : 16.22V
Current : 262.50mA
Power : 3426mW
The current values and power values seem to be almost double what they need to be, with an expected shunt drop of 1mV for the 0.01ohm resistor. I had hoped I could simply divide by 2 and call it a day, however this same exact circuit was then tested on a battery analyzer, and the current for a 3000mA draw was measured at 3992mA.
Something in the software setup seems to be incorrect. Can anyone point me in the correct direction?
Update: to rule out the resistor used itself as an issue, I soldered a 0.01OHM 5W radial resistor onto the same spot.
The resistor https://www.digikey.com/en/products/detail/riedon/MSR5-0R01F1/1641093
I got the exact same outputs as I had for the 0.01 1W smd component, within a small margin. This tells me the issue is definitely in the code itself and not the hardware.
I am going crazy trying to figure out why this isn't working, and would appreciate any input.
